Problem with SoundSystem.
I'd suggest you do the same as the video you posted. Remove the door card and inspect the speaker for any damage. While it's off, add some sound deadening to anything that might vibrate and refit the door card. Pretty common for anyone that's looking to improve the sound. If you don't want to do it yourself, I'm sure a local car audio place will do it
It's hard to tell but I think they might have distorted bass or vibration? At a guess, you're pushing the stock speakers too hard or something in the drivers door panel is vibrating. Consider upgrading your speakers or adding sound deadening to the doors to reduce vibrations.
Risk of failure using coolant g13
Some variants of the silica bag (silikat) tend to split which can cause various blockages within the coolant system. I've never seen anything about G13 and silica causing corrosion on metal parts. A common mod is to either remove the silica bag or replace the expansion bottle for one that is not 'mit silikat'
Coolant temp low
Just to point out, even if the gauge is reporting 90'C, it doesn't mean the coolant is anywhere near. Many modern cars lie as drivers expect to see a stable temperature. If I remember rightly, the coolant gauge will report 90'C anywhere between 75'C and 105'C. If you really want to know the coolant temperature, you'll need a OBD diagnostic device to see what the ECU is reporting. When my 2.0l CR140 had a cool running issue, I logged a drive before and after the thermostat replacement and it make quite a difference:
Coolant temp low
The thermostat isn't a service item so I wouldn't expect it to have been replaced with a timing belt
Side lights where are they ?
Welcome to the forums. Side light (parking light) bulb replacement looks to be covered in the owners manual on page 228.
What models fits this touchscreen?
It's exactly as I said previously, a 5E0919605M is originally fitted to a facelift MK3 Octavia with a MIB2.5 Amundsen. I believe it will also work with the MIB2 Amundsen and MIB2 Columbus but not the MIB2.5 Columbus. It will only fit in a MK3 Octavia Unless you got it super cheap, why not return it? There might be a small 'restocking fee' but it may still be the quickest/easiest way to get your money back.
Turn it over and tell us what the part number is...
The part number will confirm it but at a guess, it's a MK3 FL Octavia Amundsen display (MIB2.5).
Are rear coils for 2010 VRS different to normal please? Octy
Yes, a vRS gets different springs and dampers to a standard Octavia 👍
Massage function for the driver’s seat
The buttons don't tend to have a wire for each function, instead it's probably a resistor ladder so the resistance changes depending which button is pressed. That's probably why you have to press set then seat position rather than both together If so, then it's entirely possible that by changing a single resistor you can convert between 'massage' and '3' buttons. It's also possible that it's part of the electric seat module parameter data...
Coding Clues?
They are called PR-codes. The sticker in the handbook (and the boot) only has a small subset of the full list. There are plenty of online decoders, for instance this: http://prsearch.planetvag.com/ A friendly dealer might give you a full PR-code list if you give them a VIN/number plate.
What's the colour temperature of the headlight / light beams?
Over time the xenons colour-shift so even if you buy an identical matched xenon, there is a good chance it won't be the same colour. As both have likely had the same amount of use, the second may fail soon too. Therefore, I would suggest you replace both at the same time If you're happy with the stock performance, I'd replace both with either of the following: - https://www.powerbulbs.com/product/osram-xenarc-classic-d1s-single - https://www.powerbulbs.com/product/osram-xenarc-d1s-xenon-hid-bulb-single As a warning, there are lots of fake, low quality xenon bubs so always buy from a reputable, authorized supplier.
How much are 19 Xtremes worth?
Last full set to sell on eBay were £600: https://www.ebay.co.uk/itm/254745903542 There are some on for £500 per pair: https://www.ebay.co.uk/itm/362555898054 Singles seem to be in the £200-£250 range? As John999boy suggests, if you become a freedom member you can advertise them here
I'll give you a tenner for them There tends to be a few on eBay to give you a rough idea of value if it helps.
Which version?
Welcome to the forums Rather than 'best', you should be looking for the option best suited to you... - If you do short journeys with a low yearly mileage, I'd suggest a petrol - If you're covering 20k+ a year with longer journeys, then a diesel is better - Are you planning to tow anything, if so, what and how frequently Manual vs DSG is trickier, personally, I like having a manual but may prefer DSG gearboxes so it's whichever you're most comfortable with
Scout is going in for Firmware updates (and a service)
As I mentioned above, I wouldn't trust the OBDeleven 'there is new firmware' message, especially given the CAN-gateway suggested firmware. If it also get a valid TPI then it would be a much more useful thing rather than a firmware version seemingly pulled out of thin air. You should use erwin and grab the TPI/TSB's for your VIN. There are some examples below that apply to my VIN. The first relates to the ECU and had been applied (could be by the dealer or factory?) when I bought the car: The second relates to the headunit and not been applied despite being released almost six months before my purchase. This gave me the extra push to apply the updates offered by Pab given there was a valid reason: Finally, the only outstanding update I'm aware of is the electric seat controller: Even if I reported that my seat had issues, without the 'no basic settings' fault, the dealer still might not apply the update I've got someone who will hopefully be doing some more remote work with ODIS for me so I'll see if they can update/parameterise the module for me. If you really want the dealer to perform updates, give them the info they need to find and perform the update or even claim to be having the symptoms in the TPI. Most even have an amount of workunits the dealer can claim from Skoda for performing it.... Don't get me wrong, I fully agree that if there is an update, I'd much rather have it applied at my convenience (service etc) rather than waiting for the problem to crop up and wasting time playing the 'please fix it' game but that's not how the system currently works I'm afraid On a side note, I like TPI 2051234/5, it's basically about faulty MIB screens with vertical lines amongst other faults. The 'fix' is to replace the screen which explains why there are so many on eBay that are 'new' with a warning about vertical lines I'd be interested to here OBDelevens response to where they source the update info from and if your dealer would be happy to update with a valid TPI against your VIN.
"hacked" MIB2 unit with wrong part number/firmware?
Maybe ask the seller for the contact details of whoever did the hack?
What source are you using to confirm updates are needed? Few that I'm aware of: - Flash file name in the latest VAG flash data - OBDeleven 'suggests' updates - TPI/TSB from VAG for your VIN Guessing from the flash file name is risky, it might work but unless others have done it successfully without issue, I wouldn't use just the name as a source of truth. I think OBDeleven also guesses from the flash data. The OBDeleven screenshot you shared recently showed the CAN-gateway was running 4366 but suggesting 5366 was newer/available. This is not an upgrade I would suggest as the 4xxx and 5xxx software versions are for different manufactures of CAN-gateways... The TPI/TSB route is by far the best as it's a 'VAG approved' upgrade path. You can check in erwin against your VIN for a small fee Unless it's safety or regulation related, I wouldn't expect updates to be offered or applied automatically. On my car, it looks like the ECU has been updated but the headunit/radio and seat controller haven't been updated despite their being valid TPIs against my VIN.
How to enable Traffic Sign recognition
I'm afraid not. That's a lowline camera so it can only do high beam assist 😟
Bolero for Amundsen+, straight swap? Worth it?
You'd be much better posting this in the MK3 Octavia section - the MK2 and MK3 are based on different platforms so this thread won't help you. That aside, quick few answers: - The 'dummy front' in the glove compartment is the radio, the part in the middle of the car is just a display and touchscreen/buttons. - I don't think there are any options for a CD player, you'll need to move your granddaughters music to MP3 (or similar) on a USB stick or SD card. - It is possible to upgrade from a Bolero to an Amundsen/Columbus but it might be more expensive than you think.
2007 Factory TPMS - Anyone happy with it & problem free?
Welcome @justwilliam80 I wouldn't advise posting your email address on a public forum, it's likely to make you a target for spam and phishing emails. I've asked a mod to remove it for you. It's not clear from your message if you're having a problem, looking for help or just saying hello If you are having issues, give us a brief description and if someone can help, I'm sure they will.
The best person around here to answer your questions is probably @pab567. If you flash new software, you'll probably lose the CP and FEC patches so they'll need doing again. Have you contacted the seller?
Octy VRS buying tips
If you read Maggle's other posts, it appears they haven't got an VAQ/e-diff as there is nothing showing on the CAN-bus at that address. I can only imagine the menu item is changing the EDL via the ABS pump
An example of both cameras are shown in this post:
