HEAVY STEERING
These days it's a parameter upload rather than an adaption/coding change. It's very unlikely a garage could accidentally change it during a service
HEAVY STEERING
I assume you mean an '18 or '68 plate car? There is a power steering software update for vehicles of this age and one of the symptoms is "Power assisted steering efficiency decreased". A scan with VCDS or similar to check for fault codes will confirm if it's applicable. Bit more info here:
Discounted Skoda Connect Licences
My thoughts exactly after having a similar free trial a few months ago... It might be more useful on newer cars? Certainly on a MY18 car, it added nothing worth paying for.
Mirrors have stopped folding
The rear windows should also support one touch. From the drivers panel, with the windows shut, press and hold up for 5-10s. Then press and hold down until the window is fully open and wait 5-10s before releasing. Finally press and hold up until the window is fully closed and wait 5-10s. It's the same procedure on all four windows and the order doesn't matter. You can also try folding the mirrors using the switch to see if that works. If at this point, it still doesn't work then I'd suggest a scan with VCDS or similar for fault codes
EVs? No thanks not when.
Alas, I'll need to refill early as I've got a trip along unfamiliar roads with a full boot 😞 I'll leave it as an aim for a future tank!
Excessive ABS, low speeds?
Assuming the ABS light illuminates during startup and then turns off, the system is typically happy and working. You could get the car scanned for fault codes with VCDS. If there are no fault codes, you can also use VCDS to monitor the wheel speed sensors to check for any obvious glitches whilst you attempt to provoke the problem. You could also pop to a garage and have them do a brake check to make sure they are working with the prescribed limits. Your initial post states damp (rain) conditions at 20-25mph. I would definitely expect ABS to kick in at those speeds if the tyres lost traction. Given the Sumitomo BC100 review specially mentions "Long braking in the dry and wet, low wet grip and oversteer balance" it seems an entirely plausible explanation. What were your old tyres? Maybe this is down to expecting premium/mid range performance from (in my opinion) a budget tyre.
Just to see what happens, I've been accelerating more gently and using a more sedate driving style on this tank... The car believes 500 miles is possible, just
Converting headlights from LHD to RHD
Plenty of info online Just for example:
There are plenty of suggestions online that older systems only worked at high speeds. I can't see any confirmation regarding the speed ABS works down to on modern VAG vehicles. I'd expect it to work down to almost zero given it'll have various accelerometers, yaw, roll sensors etc and know when the vehicle is actually at a standstill. Thinks have moved on quite a bit since the earlier ABS systems
What state are your tyres in? Maybe they have very little grip causing them to lock sooner than you'd expect and ABS to kick in
Simplest way to enable Traffic Sign Recognition with VCDS?
Pretty sure on a '22 car TSR is now a FeC/SWaP/parameter issue so enabling it with VCDS is no longer an option. You probably need a specialist with the correct tools, @East_Yorkshire_Retrofits might be able to advise further
USB port and bluetooth not working
Pulling the fuse or unplugging it would be the easiest way. A few minutes should be plenty of time, no need for overnight. A fault code scan might give some clues 🤔
USB and Bluetooth will both be powered by the headunit, there won't be a separate fuse. As the other headunit functions are fine, it's either some kind of hardware failure or if you're lucky, a hard power cycle of the headunit might work if it's a software glitch?
The garage are correct. The 5L1 vs 5L2 is the LHD/RHD thing. I imagine someone needed a replacement and bought a more available, cheaper version from abroad 🤔
I'm not sure which projector the Yeti headlights use. Most aren't sold to normal consumers but you might find a used example on eBay or something with compatible mounting holes. Otherwise, a damaged RHD Yeti xenon could be a good starting point. Just be careful, headlights of this vintage may be 'perma-sealed' so the standard oven trick might not soften the sealant up enough to split the headlight easily. I don't know enough about the Yeti headlight to say whether splitting is necessary.
Electric auxiliary air heater
Exactly that... It's a ~1KW PTC heater element that sits in the HVAC system to provide 'some' warmth until the coolant warms up enough. I retrofitted one to a MK2 TDi Octavia and it did make a difference
I'm afraid that setting doesn't actually change the cut-off from RHD to LHD or vice-versa... Instead, it just disables the AFS functionallity, drops both headlights slightly to avoid glare and adjusts one (passenger side?) inwards to make up some of the lost light coverage. If Derek does indeed have the wrong cut-off pattern, they will likely need a new headlight... A xenon projector is a precision device, you might be able to flip and bend the shield to convert it but I doubt many have tried
towing function settings
From a 2012 Octavia owners manual in the towing section: Given a 2013 vRS will have ESP so assuming it's a suitable towing kit along with appropriate coding, then yes, you'll get trailer stabilisation
400+ miles between fillups isn't unusual for mine, longest was 430 miles. Worse tank was 33.0 mpg, best was 42.2, average is 37.8. Just depends how you drive it
Looking for download link for mst2_eu_vw_zr_p0478t
@pab567 is normally the chap for firmware 👍
VCDS Light Coding
You might want to read DV52's guide to the Leuchte channels, not sure where the original is but there is a copy here: https://pdfcoffee.com/vw-mqb-golf-mk7-lighting-explanation-pdf-free.html Otherwise, read some of the many common light tweaks to get an idea how this stuff works. It's not really possible to give instructions or coding without seeing an adaption map and autoscan as even similar cars can be coded quite differently. Based on your previous posts, you might have a MK2 Octavia? If so, it doesn't use Leuchte channels
Boot won't open except via key remote
If the boot handle has suddenly stopped working, then it's probably the microswitch that's failed The only setting that's related is this: So I'd check that before replacing the boot handle
Off-road display on MIB2
A VCDS autoscan might give some clues, or at least confirm which ECU and SW version you currently have.
A quick google suggests you probably need to update the ECU firmware, assuming an upgrade exists
VCDS Light Coding
Nor what country you're in... At least in the UK, I very much doubt that is counted as road worthy...
