Fitted towbar - impact on rear parking sensors
Hello, welcome to the forum. So far as I am aware, with the correct towbar pack installed and a trailer is hitched, the reversing sensors are disabled and changes are made to the vehicles stability settings. My understanding is that this is done via the trailer electrical connections.
Only one Key
That sounds like the 'keyless ignition' type rather than the full KESSY version.
Only one Key
PS. some branches of Timpsons are able to supply new, correctly coded Skoda keys. I was quoted approx. £120 a few years back.
Strange 'beep' coming from the satnav/infomation unit when driving.
Hello, welcome to the forum. @PetrolDave was referring to speed camera position data being loaded as POIs onto the MIB unit itself. Are you able to post an image of the dangling control panel you removed?
Only one Key
Hello, welcome to the forum. I'd suggest taking your vehicle to a VAG independent garage for servicing. My MY16 Octavia oil service and coolant change (I supplied fluids) cost me £146.00, inc. vat last month.
Frayed cambelt on 2017 Vrs 55,000 miles
It took a fair bit of searching - but the information I found suggests that the 2017 vRS 230 has a cam chain, not belt.
Are you sure your engine has a belt, not chain - what is your engine code? Depending on the circumstances when the chain or belt let go, you most likely will get away with a top end rebuild provided the piston tops have not been too badly damaged.
Sudden error codes on my Kodiaq
Was the replacement battery you fitted exactly the same type and capacity as the original?
Oil and filter change
Hmmmm, more BS 101.
Trouble starting on cold mornings: ASR Error
Hello, welcome to the forum. Considering the vehicle is not in motion, I suspect the ASR fault report may be a red herring. I suggest getting a check done for any fault codes.
Hello, welcome to the forum. It depends on your annual mileage and whether your vehicle is on fixed or flexible service plan. If your annual mileage is Low (much less than 10K per year) it is normally recommended to change oil annually - (fixed)
Slight judder then smoke everywhere
Unless an injector has failed, resulting in uncontrolled fuel supply to engine, the most likely cause is as Paws4 says.
- Has the coolant specification changed for the 2021 Fabia 3 range?
Hello, welcome to the forum. You say the oil level is 'fine' - are you certain that it's not lower than when you last checked, before this runaway event? Had you recently topped up oil before this happened?
Battery replacement - DIY?
Hello, there will be no issue with infotainment coding when replacing the battery. You do need to adapt (code) the new battery into the vehicles system - especially if you change from EFB to AGM type. You may be ok if only replacing exactly like for like - but it is always better to get the replacement battery adapted, this will require access to VCDS tool.
Amundsen MIB2 Firmware Update
Hello, welcome to the forum. I believe your unit is Amundsen MIB2.
Maximum engine speed 4000rpm
Found from other VAG site search - EPC error lamp lit while 4K RPM limit is displayed, fault could be caused by oil pressor sensor fault, or coolant issue. Suggest taking a look for DTC error codes.
I did a search on some Audi and VW sites - Is your EPC fault light lit on the instrument panel? Is there any indication of high coolant temperature?
Hello, not sure that's limp mode - I thought limp mode revs were considerably lower than that.
Inside wear on one front tyre
I think that even with the TB rear suspension, there is some, limited alignment possible (camber?) - but nothing like as much as the IRS.
- Massive coolant leak into passenger floor carpet
The 1.4/1.5 has torsion bar rear suspension, VRS has full IRS.
2014 Octavia Scout Mk III 4x4 issues
I'm wondering if that epoxy repair is actually hiding a crack in the casing suffered when the fin was broken off.
Or a little too much negative camber on the affected wheel?
Car won't start Immobalizer active?
They shouldn't charge you for giving confirmation that the battery was installed correctly - but it is quite possible that they do not know unless they plug a code reader into the vehicle to check - IMO, they should not charge for this either, but they might.
