  1. The failure of the aux. belt could very likely be the source of your original 'burning rubber smell' - did you not notice the alternator failure warning light?
  2. Your latest fault is almost certainly battery condition or SOC related. How old is your battery? There should be a date stamp on the top surface of the negative terminal (WWYY)
  3. Hello, welcome to the forum. Has it been confirmed that the battery is discharging overnight? Multiple, seemingly unrelated fault indications are a common issue if battery voltage goes too low. If battery is discharging overnight while vehicle is shut down (and nothing has been left switched on) it is possible that you have a parasitic load, where one, or several of the control modules are not going into sleep mode correctly.
  4. Are you having to 'slip' the clutch while you are reversing?
  5. If vehicle is now pulling to left after loss of wheel, it is very likely that, at the very least, the front alignment has been affected - the wheel hub/brake disc or lower suspension arm will almost certainly have contacted the road surface too. Strongly suggest you have an independent inspection for any damage caused by the mechanics gross negligence.
  6. I suggest getting the start button scanned for correct function of starter function.
  7. On SWMBOs Fabia (keyless start) the 'press clutch' message only displays if you press start button without disengaging clutch - what happens it you do that? I'm suspecting a faulty start button.
  8. At the very least, it looks like the mounting brackets are broken.
  9. Has the 12 volt battery become discharged?
  10. Highly unlikely for shaft diameter, taper or spline pitch to match, even between models - let alone different manufacturers.
  11. Hello welcome to the forum. 3000 RPM seems rather high for manoeuvring, even on a slope - how steep was the slope?
  12. Hello Abbey, welcome to the forum. Very strongly advise to fit only correct rated fuse to any circuit. Unless the actual capacity of the circuit wiring is known, there is a very real risk of overheating and fire if the current capacity of wiring is exceeded.
  13. Disconnecting a battery connection while the engine (and alternator) is running can result in failure of alternator diode pack.
  14. Skoda UK pervious recommendation for cambelt replacement at 5 years, regardless of mileage, was always out of step with remainder of VW Group manufacturer's (who use exactly the same engines) Skoda UK revised the cambelt replacement interval to match the others around the middle of last year.
  15. Have you had a proper battery condition test done? A battery left completely discharged for an extended period is very likely to be fubar.
  16. Pretty strong indication that something's wrong with 1st cluster synchro or baulk ring.
  17. What you describe sounds like faulty baulk synchro ring on 1st cluster, I consider it's very unlikely for this difficulty in selecting 1st gear to be normal. Do you know how to double declutch to test synchro fault possibility?
  18. Because of the way 1 to 2 and 5 to 6 gates are biased, you do need to maintain very slight left or right pressure on the stick to align those gates correctly, as the stick is weighted towards middle gate.
  19. Is the 26 psi you quote the maximum difference across all cylinders?
  20. It does sound to me that you have a fault with your gearbox.
  21. Hello, never experienced any 'baulking' between 1st and 2nd in either of our M6 boxes. I do notice some slight added resistance from the synchro's if changing down to 1st in the Octavia on the move, but not something I would call excessive baulking - and not something often required, even on lowly 1.4. Will operate marginally faster with double de-clutch on down-shift though.
  22. Hello, assuming this is a diesel, your engine could have suffered significant damage and excess wear if it has been running significantly under temperature for over two years. How many annual miles do you run? How frequently has the engine oil been changed? How often is it currently running a DPF regen?
  23. Looking at the key you pictured, I'd say the press-button is to simply shine a light for locating the keyhole in the dark.
  24. Hello, welcome to the forum. Are the affected bolts snapping while driving - or do they seize-up in use and break when you attempt to remove them? Are the longer bolts used from a reputable supplier - are they being tightened to the correct torque? Do you use anything to lubricate them when fitting? Apart from ease of mounting a wheel, there would be absolutely no difference between bolts and studs with respect to risk of breakage.
  25. Especially when you consider that "New Road Layout Ahead" signage usually stays in position for years after a relatively minor change to layout.
