Everything posted by wiilydog
One for the suspension experts
Can't go wrong with Bilstein B6 dampers, if you are after heavy duty items
Fabia LE Comfort - grabbing brakes
sounds like similar issue to golf mk7 owners with 288mm brake discs as the brake system was designed for 312mm discs but to cut costs VW just replaced it with smallers discs and carrier leaving everything else the same, this caused the brakes to be very grabby.
Is this the gearbox oil filler plug? Mk2 estate.
Yes, the bottom one is the drain
2007-2014 Fabia 3 1.4 diesel Brake wear light on
yes that is the brake pad warning light, the warning can be turned off permanently by someone with vcds cable + software
Another high oil consumption Octavia!
agree with bigjohn and reject the car as the 1.8tsi are known to have piston ring issues causing high oil consuption you are lucky you have bought it from a dealer and not priviately as you will be protected by consumer rights
Buying used estate - expectation management
the 1.4tsi also a good option if you don't do the mileage and don't want a diesel as no dmf or dpf to worry about also does decent mpg around 40mpg around town and 50 mpg on a motorway run
Loud creaking when going over bumps/speed bumps
Worth checking out front and rear anti roll bar drop links as these are cheap to replace.
Need a new one
Glad your not hurt is the important thing as cars can be replaced. Good luck with finding your replacement.
Tips, tricks, things to check or try
I've heard that comment too on some YouTube engine rebuilt videos and 0w20 is like water may be good for mpg / emissions but may be not so good for engine longevity as 5w30 vw spec will offer better protection.
Jobs to do at 100,000 miles octavia vrs tdi cr
Gearbox oil worth doing
Bilsteinsuspensionstore / Potn.co.uk
try https://www.autodoc.co.uk/ and download the App on to your phone as they do special promotions on certain days
Better suspension on my 2019 MK3 FL L&K
Worth looking into some bilstein b6 shocks too
Headlight glare.
The technology is already out there to retrofit LED bulbs that don't dazzle on coming traffic as Philips also produce a Street legal LED bulb for the the EU market https://www.philips.com/c-e/au/road-legal-led-headlights/ultinon-pro6000-led.html
Octavia 1.5 TSI 170k miles
Nothing wrong with the mileage especially if has been well maintained and mainly motorway miles. My 1.4tsi has done 160k and had no major work apart from regular oil service. Just check that the Cambelt has been done by a specialist as the 1.5tsi has ACT and needs proper timing equipment. Also just be aware that Cambelt changes on the 1.5tsi can cost around £750 to £1k whereas the 1.4tsi with no ACT is around £350, so something you wish to consider before going for a 1.5tsi
Headlight range issue Octavia MK2 2.0TDi Laurin & Klement
Has the rear level sensor been checked too as there is one on the nearside rear but best to get a scan with someone with vcds as that will pin point the exact fault if it is electrical. Can't really see much to go wrong other than the front and rear sensors as they are exposed to the elements.
How I made my Octavia Superb part 2: Eibach Pro Kit
It would be even better on b6/ b8 shocks
2015 Scout 150 power query
No light or fault codes, just felt gutless below 2k, new MAF sorted the issue, hence try unplugging it to see if it drives better.
Does your car have a maf sensor? As worth try unplugging it if it has one, to see if it makes a difference as out of spec MAF may make it a bit gutless at low revs as the fuel and air mix will be wrong as had a similar issue with Oct MK2 tdi
1.0 TSi and 1.5 TSi Cambelt change interval
Yes it is a non ACT 1.4tsi, I got mine done at 150k as didn't want to risk of pushing it any further despite no specific intervals from VW
I got my 1.4tsi belt changed at indy for £320 back in May so guess the 1.0tsi will be similar. Anything with ACT will be expensive due to the complex nature of the variable valve timing.
Looking for Low Maintenance Motoring
Give it another few more weeks there should plenty of good non ULEZ cars up for grabs from London. Go for something with good service history preferable with annual oil changes rather than variable servicing. I ran my 2.0pd 140 to 215k before I sold it and it was still going strong. Can't beat the old PD engines as long as you avoid PD Vrs as that came with DPF.
Better / Best Turbo for MKII Estate 2.0 TDI PD Engine
Would try some turbo cleaner first such as archoil as you may find it is just cloggged up turbo vanes. You just add it to a full tank of fuel and give it some beans once the engine is fully warmer up.
Sump. Paint, leave, replace ?
Here is proper guide for Golf Mk7 but should same for Oct MK3 as they share a similar platform https://www.golfmk7.com/forums/index.php?threads/how-to-retro-fit-skid-trays-aerodynamic-under-trays-stone-guards-to-a-mk7-golf.320687/
Also consider sourcing a used full length plastic under tray as I'm sure some models come with full length trays
Tyres very unevenly worn... can anyone help identifying this?
Get your rear alignment checked as probably worn rear toe bushes
