Starting Problem 1.2 TSI
P0237 can be caused by a failed or failing MAP sensor/turbo pressure sensor but it may also be a wiring fault/short/bad earth. check that its plugged in and making good contact/no dirt or corosion plus check for broken wires. Its normally on the intake manifold. May look like this There is very probably a part number on it for ordering a new one. Sorry no idea how to check if its good or bad. It can cause poor starting when cold and can also put EML on if car starts Alasdair
Not sure on that engine but normally inline with air intake from airfilter to throttle body. Had an old volvo with failed MAF and had excatly same symptoms. On mine it started roughly but stalled if I went over 1000rpm. I would get it scanned before replacing anything but you could check wiring to MAF and coolant temp sensor etc.
Think you will have to get it scanned for codes. It could be a bad coolant temp sensor Maf or many other things. Can your mechanic come out and perhaps scan it? Alasdair
- Rapid - Used Value?
Front brake pads and discs for Octavia mk3 1.6 TDI Diesel 105hp? Ordered wrong ones last time.
That explains why all my skodas have brake pr codes missing. Alasdair
Code P0341 (Camshaft Position Sensor), BBM engine
Might be worth checking wiring continuity/connectors from camshaft sensor backwards in case wiring is failing or broken/not making good contact. You could do the same for the crank sensor. Think from memory its hidden behind oil filter area. Alasdair
Meant to add make sure slider pins are moving freely and use silicone grease on them. I had to clean mine as the previous owner had used copper grease which had dried out and they were seizing plus copper grease is bad for the rubber gators. Alasdair
I use https://brakesint.co.uk/ They have excellent info and pictures for you to compare. I then order them from https://www.partsinmotion.co.uk/ as they are usually a lot cheaper. By the looks of the old pad its from a caliper without the external spring so should have 280mm discs. Still measure the old ones as well. There may be a PR code in boot sticker that will keep you right as well Alasdair
Fan resistor replaced...now has hot Bakelite smell
Could be just the protective coating heating up hence the bakelite smell or its a poor copy. Any burning bakelite smell is not good but hopefully will disapear. The OEM one is a fair price compared to aftermarket. Not sure what make you got but think Febi do one Febi 34370 OEM 6Q0 959 263 Check the old one for oem part number Alasdair
Reverse light wiring route?
Reckon its been a replacement lens from as LHD vehicle unless its an optional extra. If you have one on the left and a fog light on right you should be ok. Chances are if its wired in you would probably get a bulb warning light unless car has been told there are two. Alasdair
Does this look good?
I dont have vcds but when I did mine 1.9tdibxe I had to loosen top pulley/camshaft bolts and adjust slightly to align locking pins after turning engine over by hand once belt was fitted. When I fitted the belt they all ligned up but after a complete rotation were just slightly out. Didnt have to move it much but I believe its fairly critical. Alasdair
I thought they only had one on the left with fog on the right. Maybe someone has fitted a new rear light from a rhd car from autodoc etc. Are there actual wires going to the reverse bulb? Alasdair
Starting and stalling problems
It may be the throttle body as previous. I would get it properly calibrated with vcds to rule it out. There may well be someone on here local to you with it that could give the car a proper scan and calibrate it for you. If not then you may have to source a VAG specialist garage or at lease one that knows how to and get them to scan it. It may pinpoint a prroblem that your scanner is missing. Alasdair
TCM
Read a post regarding TCM wiring. The plug to gearbox was dirty with oil/water ingress causing no comms. Check its clean and making good contact etc. Alasdair
Replace handbrake cable
On my old Seat it was the same. I used a little heat on the end of the tube as I think they may have been originally glued in. It came out eventually. Careful not to pull tube out while your at it. One side was ok but the other solid. Alasdair
Rear Brake Caliper Part numbers
Think they are based in exeter but have multiple warehouses around UK hence the random surcharge to Highlands. Last order arrived within 36 hours so a lot quicker than autodoc etc plus at least 25% cheaper than my local motorfactors. Alasdair
Only problem I had was one part of order (wheel bearings) that incurred a surcharge for some reason. They said it was being sent from another location. I missed email so they didnt send it. I ordered another euivalent brand (apec) and it arrived no problem. I to are no stranger to their website unfortunately. Alasdair
P0172 - system too rich
Sorry havent a clue either. Maybe purge valve is sticking closed then stuck open or the PCV valve is faulty? Sons had poor idle. low then high etc plus poor mpg. I replaced purge valve and also his brake servo vaccum pipes were split so taped up and idle returned to normal. Have read that some folks needed to replace charcoal canister as well as purge valve. He had problems last MOT with emissions due to small leak in centre of exhaust. Sealed it and emissions were ok. It was a tiny leak that I and the MOT guy thought wouldnt make that much difference. Its odd it jumps from rich to lean. Alasdair
I had similar problem. If I used handbrake the caliper would bind. I took lever off kept caliper upright and soaked overnight in penetrating oil then manually operated it as said. Took a while but eventually it freed off. Have a look at https://www.partsinmotion.co.uk/ Been using them for a couple of years and prices are good and so is their service. Alasdair
To clarify I mean the lever on the caliper that the handbrake cable attaches to not the actual handbrake in the centre consol. I operated it manually and then wound piston back in and repeated until it was free. Could also be a sticking cable. Alasdair
If its like mine 1.9tdi it could very well be the handbrake lever part thats not releasing properly and causing it to bind. I took mine apart and oiled/greased and manually operated it until it freed off. eventually I replaced caliper which was around £35 online. There are I think 3 different rear calipers. A smooth one,ribbed one and Bosch. Have a look on https://brakesint.co.uk/ They have pictures of the different types including piston sizes etc. I had a look at reconditioning mine but at £35 I just bought a new one online. Had a look and 1SS doesnt seem to be a valid code Alasdair
Not sure the Bosch one matches the one that came out as far as I can see unless it was replaced by previous owner with wrong one?. What year is yours. Alasdair
According to Bosch its the equivalent to old one used on Fabia Mk1 AZQ year 02.2003 - 11.2004. Alasdair
On my sons fabia m1 1.2htp there are two lamda sensors available from memory depending on the Vin/age. His is AZQ. Maybe you have got the wrong lamda? Think there maybe a number missing off the bosch part number as they are usually 10 Alasdair
Rapid front coil spring
Same here done a fair few over the years and only now have the open sockets in my tool box. Hope I wont need them if you know what I mean. Last one had to cut the main strut nut off as it was so tight the allen key centre rounded. Alasdair
