Alasdair1
  1. It could also be a fuel problem? Perhaps its draining back to tank and takes a couple of times to prime system again or its letting air in somewhere? Alasdair
  2. Not sure re superb but had a test drive a while back in a mk2 Laurin klement with really nice leather seats. Slightly firmer than the cloth ones in mine but very comfartable. Not sure how readily available they may be but worth a look. I assume the fittings will be the same. Alasdair
  3. If they damaged it while working on it its down to them to repair/make good. Main problem may be proving it was them? When you pick up a car from a garage dealer or not you trust them that its been done right. I don't know anyone who inspects a car before leaving the garage . Check with CAB as said. If the dealer has refused to repair it you could always point out that any publicity of that kind won't help their reputation. By the sound of it you wont be using them again anyway. Alasdair
  4. Might be worth getting it scanned with vcds as it may ping up something your reader can't read. Check any connectors/wiring that you have disconnected or are in the vicinity of any work you have done in case you dislodged them. Alasdair
  5. Have same problem again. Thats now 4 cars with the same symptoms. 2 octavia, 1 fabia and a seat. Random working and then wiper stops somwhere on rear window then randomly starts again and eventualliy fails to move. Previously I just replaced motors but will check for dry solder joints. It always decides to fail in winter when you needit most. Thanks Alasdair
  6. Its a shame there making engines smaller and more complicated. The 1.9tdi was brilliant and gave me no bother apart from a failed glow plug(which I never bothered replacing) I used to get 40-50mpg around town and 60-70mpg on long runs. The 1.6tdi does need to be driven a bit harder but as said so far no problems. I think all models will have their specific problems but generally I find them pretty reliable as long as they have a good service record and the maintanance is kept up. I have heard the early 1.4 tsi had problems with oil consumption etc but I think they were fitted to the MK2 octavia and MK2 fabia. Someone on here will advise you on what to look for etc. Good luck its as you say a bit of a minefield choosing a new car. Alasdair
  7. I have a 2012 MK2 1.6tdi. Think its one of the last MK2. Bought it as my 08 plate was like yours getting past it. So far so good with no real problems. It does have a DPF so we try and take it out for a longish run every week as it usually gets short runs every day. If your only doing short runs then petrol is probably better. I have read that DSG can be problematic if not maintained. I think its every 40k they need serviced so if the car your looking at is near that it will need done. Not sure of the cost etc.
  8. I did my sons and it took a while to bed in properly. First I thought it was slipping and what had I done wrong and had a bit of judder but after a day or two was smooth. Was a fair bit of smoke from front of car at first but reckon it was the old clutch fluid burning off as I replaced the slave cylinder as his was leaking slightly. Run the car for a few days and if it doesnt improve speak to mechanic again. £900 for a new clutch and full service isnt a bad price at all these days. Was quoted £700 plus vat just to do the clutch on his fabia so I did it myself. Alasdair
  9. I know what you mean. I went from a 1.9tdi bxe to a 1.6tdi. Same horse power but took me a while to get used to 1.6tdi. I find you need to keep revs higher to get power unlike the torque from the 1.9tdi. Same here got nearly 100mph just to see and it still had a bit more to give. Alasdair
  10. Wonder if its been remapped before you got it. Have seen a few octavia diesels remapped (obviously badly) and they all have black soot on the tailgate. Not sure how you would be able to tell but someone on here may know. Alasdair
  11. If you have a scrap yard near you see if they have any that might fit. Take your car and try a few from skoda/audis etc Alasdair
  12. I agree. I put a tank of premium diesel through mine every month or two. Reckon it keeps engine cleaner. Might be worth swapping air filter for another brand if it doesnt work. Have read that some brands arent so good. I use mann or febi on mine and no probs. Alasdair
  13. Reckon its probably 6Q0711051. Have mistaken the 0 for a Q before on parts. I think its Fabia Mk1 but also vw polo and perhaps seat ibiza if your looking at scrapyards
  14. May be that the mechanism is worn out and flaps are trying to close/open. Mine sounded like a motor stopping every time I turned off ignition plus a tick tik tick sound after for about 5 secs. Cold and hot still worked but not sure if it was working properly originally as sound was there when I bought car second hand. Never used AC as it was needing recharged and never did get round to investigating it properly as it still worked. Alasdair
  15. Had weird dash lights on my old octavia. Some dim others bright. Fog light symbol on when lights were on all the time (full and dip) plus dim battery light and dim DPF and a few others. I worked out it was an electrical fault as it didnt have a DPF. Removed cluster and cleaned contacts and then reconnected and it was fine. The connector at rear of cluster was either loose or had some corosion. Remember to disconnect battery if you are removing cluster to stop imobilser coming on.
  16. Cant view clip but it may be the flaps on the climatronic system. They can be reset but it may be that they are worn. My old octavia used to make a weird noise/low hum that faded away every time I switched off engine. Alasdair.
  17. Might be worth replacing it as they arent that expensive. Have seen some online for around £30 Cant see it breaking and if it does it needs replaced anyway. Alasdair
  18. Mine was an 08 plate. I got it when it was about 10 year old and it had a few bits of rust around the rear panel just before the rear wheels. I tried to keep on top of it but alas it was a bit down hill after that. Still lasted another 7 years but underneath became bad with bad sub frame corosion. Saying that it was only the last couple of years that holes started appearing in sills. Managed to cover them for a year but last year would have taken a lot of time and effort for MOT so bought a cheapish 12 plate. Its developing rust in exactly the same places (front wheel arch, rear numberplate and rear panels in front of rear wheels. but sills seem to be better painted. Did notice when changing timing belt that there is a lot of crap behind front wheel arch plastic that was causing corosion so removed both sides and gave a good clean pus waxoil. It depends what part of the country it comes from. Up in Inverness they use a lot of salt so cars tend to die much earlier no matter what you do. My sons 06 plate fabia mk1 came from I think somerset and has virtually no rust at all. Alasdair
  19. If its at the rear my old octavia was the same but mine had started to rust. I glued a rubber bung in each side to cover it up for an MOT in case they came back with weld a patch on it as the sills on mine are past it. Reckon its a drain hole but I know what you mean about the rough edges. Squirt a good load of waxoil in as far as you can. Alasdair
  20. Sons 06 plate fabia mk1 1.2htp with 70k. Brilliant car had a few ball joints etc and rear brakes plus a new clutch and repair to window motor plus regulator. Its got no rust on body plus underneath pretty spotless as well. Must get underneath treated before dreaded winter salt and do somethig about the faded headlights. Alasdair
  21. MIne was the same. Couldnt get handbrake to hold car no matter how much I adjusted it. One of the levers was seized so handbrake puting all force to one side. The rear one that was seized was also binding quite badly. Before adjusting check that the cables to each caliper are actually moving as well. If one or both cable are seized or stiff you can put handbrake on but it doesnt release properly which causes binding. Alasdair
  22. That does look like a big gap but I don't know what the proper gap should be. I think it depends on the make of plug but I assume it would be 0.9-1mm. Also worth checking your actually getting a spark. I doubt if all three coil packs would fail at one time. Check fuses as well for fuel pump etc. The two thin wires on the alternator should be marked L and DFM on the small connector. The L wire is the exciter wire and the DFM is connected to ECU. Cant remember their colours I have read they are liable to break at the connector but still look ok. The wire marked L should have 12V supply with ignition on. Alasdair
  23. Meant to add if yours has rear discs the handbrake cable operates a lever on top of caliper. My old octavia used to bind as the lever was seizing. The handbrake would go on when you pulled handbrake but wouldnt release properly. I removed caliper (still connected to flexi hose) and then lever from caliper and lubricated mechanism, replaced lever and manually operated it until it freed off. Had to do it a good few times plus kept having to wind in pistons as well. If checking if the brakes are over heated don't burn your finger like I did. Alasdair
  24. It can also be caused by sticking handbrake cable or pads that are seized in guides/seized caliper guide pins. As Warrior193 said check that the centre of wheels isnt very hot after a longish drive. You can also check by raising each wheel and make sure it spins freely. Alasdair
  25. A simple check. Have a look at the thin wire going to alternator(exciter wire). Its known for it to break causing no start. Alasdair
