Everything posted by rum4mo
Changing rear brake discs and pads, notes and tips
I'm old enough to have started working on cars at home before these "fancy" brake callipers appeared requiring the user to have a 7mm allen key to remove them, typical "home use" allen key kits had 6mm and 8mm - 7mm did not regularly exist in basic allen key sets. So, it was a case of "it's not a 6mm" grabbed the 8mm "its not an 8mm"! Followed the next day to a lunchtime trip to a very local to my workplace, welding supplies shop, that solved that tool problem. A 7mm allen key or hex bit would fit these bolts perfectly once the car is quite a few years old, but once you had applied a bit of effort the accumulated rust curd would break and the 7mm allen key or hex bit would rotate freely! Edit:- I'll be happy enough if I can get the discs out>in without removing these bolts, I've never found that to be the case in the past on other cars, but many people do find it possible to do - even my mate had to take them out on his son's old 2011 Audi A3 1.6 - and he is not a person to freely remove bolts just to make life easier - so I live in hope for this 2015 Polo!
- 6 replies
- 2015
- 2016
- discs fitting
- discs&pads
Tagged with:
Fabia III Workshop Manuals
easymanuals.co.uk works for me, they just probably grab manuals from the VW Group source, ie erWin and sell them on, or you could reg with erWin and buy an hour to download the latest version for your car, a bit more work, but you'd end up with the latest version for your car. From memory, easymanuals sells you a copy in 2 or 3 forms, so that means, a download or a USB stick with the same on it, or maybe even on a DVD - though I'm not sure if the 3rd option exists.
Steering wheel Clamps, added security?
I've had and used a Disklok for over 10 years, I'd rather not need to mess around with that sort of thing, but as long as there are nasty people willing to take your car away, I'll continue to feel the need to use it when away from "home territory", my own car is a 2011 Audi S4 and it seems even now some people like to grab them even ones of that age, which is a bit annoying and surprising. One really good thing about using my wife's 2015 Polo 1.2TSI is that it tends to get overlooked, well so far, so parking it in town is easier and causes less worry than using my car, and if taken it would be easier to replace. If you are concerned about having a keyless system in your car, buying and using a Disklok is a good plan, none of our cars have keyless system, I've also fitted a physical OBD2 barrier/blocker to avoid someone reaching in and plugging in a bit of kit to generate a new key, although you can also just remove a fuse that provides a 12V supply to that OBD2 port, which nasty people to power up their kit when generating a new key - it seems. Doing that works best on cars that have fuseboxes at the ends of the dash area as these get protected by the dead locked side doors. Really, I suppose all I'm trying to do, at least with my own car, is to hope the Disklok is spotted and they move onto some other poor sucker's less protected car, I have sort of missed a trick when buying that Disklok as I opted for the standard sliver painted version - at one time there was the option to buy a bright yellow version, logic to me suggests that that version would have been the smarter buy, but I think now that lack of interest in the bright yellow one means that only the silver painted version gets made and sold.
These rear calliper bracket bolts should get replaced as they are first torqued to a set figure then an additional angle of extra tightening applied. I'm guessing that @nta16 accidentally said "H7" for the rear calliper bracket as it is "H7" for the front guide pins, I agree with you that these rear calliper carrier bolts are in deed "H8" ie 8mm hex bit required, I have this job to do very soon on my wife's August 2015 Polo 1.2TSI 110 as sadly I ignored my own advice about cleaning up the brakes every year after a car's 6th birthday (every 2 years is good enough up to and including the 6 year point where I live and use a car), so at the 18 month since the last brake clean up, the offside rear has started to stick/seize a bit and has reduced the friction material down to 4mm where the other side is still 6>8mm. So it is time to fit new pads and also the heavily ridged discs after 8.5 years 48,000 miles. Strangely, maybe, there was absolutely no evidence of the ceramic brake grease that I use, left after 18 months, so maybe that brand of ceramic brake grease has poor adhesion or "water/wash resistance" - I didn't expect that! The offside rear brake that was slightly gripping took quite a bit of levering to remove, the still free running nearside was as easy as usual to remove. One other thing that I had forgotten, again after advising my mate about this is, if you tend to buy your car service bits from ECP, before doing that, check up on the Halfords website as I could have saved roughly £10 when buying the exact same Pagid parts - the only issue for someone that has taken the brakes apart before sourcing parts can be with Halfords, needing to wait a couple of day until the discs and/or callipers arrived at your local branch - I've added the callipers into this, just in case I need to replace that one if I find that it is seized, ie corroded piston - the saving for "same brand" rear callipers from Halfords is even better when compared with ECP - but if the car is already in bits and is needed back on the road ASAP, then ECP at least for me would work out as being where to drive to that day and return with the new calliper. This is just intended as maybe useful info for anyone that is about to do this job.
- 6 replies
- 2015
- 2016
- discs fitting
- discs&pads
Tagged with:
Remote Key Not Detected
@nta16, you need to edit your previous posting - your first part of covering coin cell dimensions, before the "hounds" come at/for you!
Help with Fuse Size (not rating!)
Just a bit of additional (unnecessary) info on fuse types, the fuse type that can get called "standard" and also named ATO by Littelfuse, who first brought them to the market, the "O" means "open" as in the fuse element is exposed, there is another version of "standard" fuses called ATC and the "C" means "closed" as in the fuse element is covered- I only found that out when I Googled "ATO" to make sure that I had quoted the correct term - so that explains why some of these "standard" fuses, in VW Group cars anyway, are either "open" or "closed" with probably no logic as to why both can exist in a new car from the factory - a supplier related issue maybe.
2017 Fabia Estate 1.0tsi 110 SE L - will these wheels fit?
Yes, I tend to either roll the car forward "half a wheel rotation" then get the areas missed during the initial washing - or hope to park it after being out in it, with the front wheels in a different position - the first option works best! Edit:- removed an "out" !
Battery on the blink already?
If the battery is an EFB, why don’t you run the “reconditioning” charging program. I’ve done that once a year on the original EFB in my wife’s 2015 Polo 1.2TSI and and it does improve the battery’s health - ie its CCA as measured using a CTek battery tester. To be honest, I’m almost annoyed how well this original, ie factory fitted Exide EFB is behaving 49k miles and 8.5 years from new, but in reality, a car’s battery life tends to be linked to how a car gets used - not intended as a criticism, just the way it is.
Maybe a better plan would be to check the fuse boxes and see which sizes of each fuse are being used on that car, both of the sizes you mentioned will be in there as well as another version, ie ATO, MINI and JCASE I've found Halfords and many other car parts outlets stock supplies of car fuses. In my wife's August 2015 VW Polo 1.2TSI 110PS 6MT, the "12V Power Outlet" fuse is a 20amp ATO.
My wife's 2015 VW Polo 1.2TSI 110PS uses 15" 6R, ie slightly earlier than her 6C Polo, VW alloys in winter and they clear the 288mm front brakes, I think that your 2017 1.0TSI 110PS Fabia will have 288mm front brake discs, or even the newer slightly smaller front discs, so that means that if you buy a genuine VW Group alloy, it will clear the brakes on your car.
Front caliper nut rubber covers
A comment that I would make is, there is more than one thread size(pitch) available even where you have metric fasteners, or, including metric fasteners, typically a "fine" and a "coarse" thread, and for some metric sizes, more than just 2 sizes. I'd always measure the thread pitch before fitting a new bolt or nut, though typically I only buy new bolts/nuts from a local VW Group dealership, doing that means that you end up with the correct fixing first time. You can buy metric thread gauges as well as taps and die sets that cover all or most fixing sizes/pitches used on these car.
rear springs
Ah, okay, but good to know that my local parts shop could source them quickly from them - as that time must be getting close for my wife's 2015 VW Polo 1.2TSI !
rear springs
Out of interest, for the future, does your local Dingbro deal with the general public - I've always looked on them as being a "trade only" operation, so never tried buying from them locally? I've bought Lesjofors springs in the past and consider them to be a "better" quality and exact replacement than some others.
Škoda 2017 SE 1.2 TSI Stage 1 map issues.
He wrote "back box", by the way.🙂
Fuel Filter
I'll hazard a guess, stupid maybe, that what is being referred to as an into tank filter, will only be a single gauze screen to protect the in tank lift pump, if that ends up getting choked, and it shouldn't, the high pressure fuel system would under perform and you would get to know about that. Nowadays, with lots of newer cars, replaceable petrol fuel filters are a thing of the past, so this can now be ignored as a preventative maintenance service task. Edit: one "can" removed, no "can can" intended!
Kamiq corroded rear brake discs
Yes I agree, our younger daughter and husband has a 2019 SEAT Arona and I can see that if it appears up my way from Bromley before it gets its next MOT in April-May, then I'll be replacing the rear discs with Pagid and either Textar or Pagid pads. That will only sort things out for a few years as they are smart enough to not use the car unless they really need to and drive "too carefully"! In the past I've found Pagid rear discs to stay cleaner and longer than VW or SEAT factory fitted rear discs, either coincidence, luck or something else.
Sump plug stripped
So that was an EA211 engine with an alloy plug, the workshop instruction, at least for my wife's 2015 VW Polo 1.2TSI, ie another EA211 engine with an alloy plug, is at the first service, to remove the plain steel plug/captive washer, and throw it in the bin, and replace that with a different steel plug and a separate rolled/folded alloy washer. Now, at every service since the warranty ran out, I've serviced the car myself and just reused the steel plug and fitted a new rolled/folded alloy sealing washer - always using a torque wrench set at 30Nm, but at the 2022 service, the steel plug sort of "caught" a bit when about half way out, so I eased it out, examined the steel plug, which looked as good as these steel plugs tend to seeing as they probably get thrown into a huge hopper during the manufacture process, anyway I changed to using another - same version, steel plug and it was also slightly "not right" but seemed okay when it was near the fully screwed in point. So, at service time this year, I ran a tap down that sump drain hole and some bits of alloy came out with the plug, I also ran a die over the steel plug but it seemed to be okay - so for the service next year I'll be buying a new steel plug, and checking/cleaning it before using it. So, why the steel plug/alloy sump hole offered no resistance during the 2019, 2020 and 2021 oil changes, I can't say. I serviced my old 2000 VW Passat 4Motion 12 times and my wife's 2002 VW Polo 1.4 12 times, both had alloy sumps and the older steel plug/captive washer, and never had any issues with the sump threads, a bit annoying!
Spare wheel size for Skoda Fabia Estate 2016 1.2 TSI ?
No, you would only need a 16" steel spare wheel if you had bigger ie upgraded the front brakes, 15", as already said is what VW Group supply when they provide a spare wheel as standard. Lower powered Fabias ie ones with 256 or roughly that size of front discs, would get supplied with a 14" steel spare wheel. The rolling circumference of any these wheels when fitted with the "correct for that car" tyre, will be roughly the same. Edit:- obviously other aspects of the wheels need to be correct when fitting 15" wheels and same if able to fit 14" steel spares - ie rim width and offset.
1.0 TSI Oil Leak
Sorry I was dreaming, your car has a 1.0TSI engine, but what I suggested above still counts! Edit:- the O-ring seal for the end of that pressure pipe that seals it to the throttle body is WHT 007 498, and the O-ring at the other end of that pressure pipe that seals it to adaptor and also the same that seals the adaptor to the turbo O/L is WHT 001 386 - you should only need one of the O-rings at the turbo end of that pressure pipe as you will only need to remove the pressure pipe alone or complete with the adaptor. I'm suggesting that you remove the pressure pipe completely as doing that seemed, to me, to make life easier when refitting, and also allows you to wash the engine oil out of that pressure pipe, apply a spot of clean engine oil to these O-ring seals so that the pressure pipe can be fitted easier and so not damaging the new O-rings.
1.0 TSI Oil Leak
I'm guessing that that is an early 8V 1.2TSI engine, and I'd think that either the O-ring seal is allowing oil in the forced air to leak past it, or that pipe is cracked, or if there is a plastic adaptor on top of the throttle body, maybe that is cracked or its O-ring - if it has one, is leaking. That area really just needs cleaning up to help you work out exactly where the leak is..
Non-engine-related computer in Fabia?
A weak and/or under charged battery could cause this sort of thing to happen - as the battery's voltage will dip down when the starter motor is turning the engine over. VW Group call all the "computers" or "smart controllers", controllers, and there will be quite a few of them in your car, now if you had a good scan tool, like VCDS, you could check everyone of them for stored or logged fault codes - doing that might allow you to work out what was happening.
Skoda Fabia Engine Oil Leak (2017 1.0 TSI 110 Monte Carlo)
One easy way to find your car's engine code is to stuff your reg number into Opie Oils website - and possibly some others.
Skoda UK are being nasty cheating bar stewards, ask this question again, this time via recorded/tracked snail mail, and when they give the same answer in print, seek further advice - as well as shaming them publicly. Edit:- the only alternative to them being nasty cheating bar stewards, might be that Skoda engine plant has a bigger problem than they initially thought concerning this version of this pulley - it would have handy if you had asked for the removed pulley assembly to be returned to you - as evidence.
Lower control arm issue
Just a comment in the passing, maybe for people who have not done this yet, the engine RHS mounting is sold by VW Group as a single assembled item, what exactly does the text supporting that "picture" from the official workshop manual say about this, maybe the red arrow is pointing this out, whereas the "!" group of bolts is instructing that they should be removed - and not that nut in the centre of the actual "silent block". I'm sure that I've read about this being the case - while "back street" workshops creating youtube videos just say "remove that nut and jack up the engine" - I can't say if or why removing that nut is a big issue though.
Fabia Mk3 inner tie rod dangerous corrosion of the threads.
Not good! My wife runs an August 2015 VW Polo 1.2TSI and I tend to scrub the threaded areas clean and apply grease, every year at service time - more in a bid to make it easy to re-adjust the toeing if it becomes necessary, this car is at around 42,000 miles and lots of salt is spread on our local roads in winter. I did replace the TREs on her previous October 2002 VW Polo 1.4 16V at the 4.5 year point, but that was only due to me needing to replace the front springs and the TRE threads/nuts gave me a lot of grief. Later on, maybe at 10 years and 85,000 miles, I did replace the inner track rods due to "slackness" on one of them, doing that with the correct tool was very easy. At both times, I didn't find any unusual rusting on the track rood threads.
