Everything posted by UndertheRadar
KESS model, Superb, how to effectivelly prevent keys being scanned?
New service contract
Look it up in the search function. There’s a pic somewhere on here giving the part number of the expansion bottle you need without the silica bag. I replaced mine not long after getting the car with a genuine VAG non silica bottle.
Wheel bearing noise like noise, but with a twist
Does it do it when going slow and during any sort of steering adjustment when manoeuvring?
Rear seat back creaking noise
Adjust the striker down slightly with a hammer on the side making the noise.
Front or rear?
Stuttering Superb
- Stuttering Superb
Where about are you in N.I?- The 280PS Thread
The H&R front roll bar with “Teflon” coated bushes are so far very quiet and squeak free. They claim to not need any grease at all and are supposed to be a permanent fix for the issue. We will see how they fare over time as literally only in a few hundred miles ago.- Koni Special Active being fitted today
Ended up fitting front and rear B6 damptronics as they all arrived in at once. I have them running on standard factory springs. I replaced the top mounts with Bilstein mounts and fitted an OEM mount bearings. the difference is night and day. It is slightly firmer, but in a much more controlled and still very comfortable way. It has removed the dive and clunking from the front end, and has honestly made the car seem quieter on the road all round. I can now actually use comfort without it feeling like a cross channel ferry in a storm. the car drives now like it should have from the factory. I still have/had a very slight noise from the roll bar bushes, which have been greased for now, and I’ve ordered an H&R front roll bar as they claim their Teflon coated bushes eliminate the issue without the need to grease at all. We’ll see how that goes when it arrives in, and I get a chance to get the car back on a ramp.- Superb -16 2.0 280hp idle problem
Have you checked to make sure the vacuum pipe is still connected to your new filter?- Front ECS strut mounts
I have the usual knock/rattle/grind noise during slow speed manoeuvring or over unsettled ground. My Bilstein B6 damptronics have all recently just arrived in and I should hopefully get them fitted very shortly. my question is: Has anyone used the ECS tuning upgraded front top mounts from awesome GTI, that they list for the MQB platform, and if so, would you recommend them given they’re £192 for the pair?- Engine oil
I removed the 0w20 from mine and replaced it with 5w30 at the first service.- Inspection Service
If you have someone near you with even an OBDEleven it will reset the services for you. My oil and inspection run at different intervals as well. I just reset both every year when I service the car. I run my own schedule, so the reminder is just a PITA anyway. the old minor/major/minor/major interval was a better system than this digital rubbish IMO, so that’s what mine gets, with haldex/dsg oil changes etc thrown in at whichever interval they occur during.- AWD Oil Change and maintaining warranty
As above, it seems they’re asking for it to be serviced early. I did mine early as I’m just overly fussy, but we were able to add it to the online service system at my mates garage. the dealer won’t remove the pump and clean the gauze in most cases, they will just drop and replace the oil and hand it back to you. so you could have it carried out by a specialist as long as they can add it to the online service, or leave it until it’s 3yrs old instead.- Engine Cover Dealer Delete
Or maybe just “yes”- Koni Special Active being fitted today
I’ve a failing front hub bearing in mine at the minute at 27k. I’ll be fitting a new one along with front B6’s at the same time. If interested I’ll let you know how the car rides after I get it sorted as it has DCC. think the B6 damptronics are about £300 each for the fronts. Rears haven’t arrived yet and still showing an April/May delivery.- Black window trim issue.
They possibly used a trim restorer dye or similar just to hide it long enough to hand it over.- Black window trim issue.
Has it had any paintwork on that door? it looks very like burn through from a polisher.- What have you done to your Superb III today?
- Steering system issue
Had my rack replaced under warranty for a clicking noise when turning/shaking the wheel while stationary. Picked it up with the window down one day while parking and then realised shaking the wheel produced the issue as well.- 272. Remap or not?
I’m waiting until I’m fit enough to replace my suspension as I find the OEM DCC monroe setup to be horrendous at best, and then mines off to revo for the performance kit. Hopefully get it sorted this summer all being well.- Sonos connect AirPlay
Thanks. Since posting, I’ve looked at the soundform and a few others of similar type. I have removed and sold most of my Sonos speakers except for the play5 in the kitchen. Bought a H&K citation one and a citation 500 to make connection easier, and I think I will remove the connect altogether and replace with something like the soundform directly connected to my processor, to then allow it to power and run its own separate zones again with both my own music saved locally and the likes of Spotify as well.- What have you done to your Superb III today?
Thanks. It was just luck that we bought a house years ago with a Corner site. I was able to use that to add the garage with a couple of rooms above so it’s all joined to the original part of the house. It’s handy now I’m slower and not just 100%. Means I can take my time or stop altogether without worrying about it sitting there.- Are creaking anti roll bar bushes replaceable? Big job?
Petrol here as well and I’ve had a new front ARB under warranty and the replacement greased during this summer while they were replacing the steering rack.- What have you done to your Superb III today?
I used a rupes yellow wool pad on mine recently. Needed mostly 2-3 passes to remove wash marks using their own (yellow) fine cut polish. Finished with a soft (white) pad and Uno. Wiped down and then coated with raceglaze ceramic pro. The wool pad removed everything that the lights picked up from all angles. I spent a week and a half in the garage, so I checked each panel quite intensely. I normally use their foam pad, but for some applications their wool pad is absolutely fantastic. Might be worth a try if you want to lift your cut from the 70-80% you achieved. - Stuttering Superb
