gav_is_con
Everything posted by gav_is_con
  1. 1.6 may have issues. Superb is a very large car especially estate. Will fuel and other filters be changed has it had the emissions fix applied might reduce EGR life although they can go without fix. Check for vibration and labouring at low speeds couid be DMF for clutch I love my superb elegance estate but it’s had its fair share of common issues. You have had Japanese might have been very reliable and low maintenance
  2. I gambled my high mileage Octy2005 TDi had 3 or more belts by meand when it was costing more than I could sell it for I decided not to change. I did no inspections on mine at all. Sold at 265k. The replacement recommended was 4 years or 85k whichever sooner. For mine.
  3. Last year all 3 of our policies increased no logical explanation, I hope they come down for all driver, if yours is a guide. Pay it quick πŸ‘
  4. Mine used to do that but always heard it click back as door was closed from drivers seat. I didnt exactly slam it shut. Never caused any issues so never addressed it.
  5. Isn’t it 2 years parts and labour warranty on everything at Skoda?
  6. https://www.rac.co.uk/drive/advice/emissions/diesel-particulate-filters/
  7. Most likely you are not letting it complete a DPF regen or taking it on a long run.
  8. Another happy customer here 2011 Superb Elegance DSG combi. Motor packed up weeks ago and it’s been cold. Only saving grace is heated seats all around heated front as well as rear screen and a microfibre to wipe the mist off the doors. Managed to break the arrow alignment tab on mine it came out with a twist. But it was a pain trying to ease it past whatever was stopping it coming down into the footwell. Copious amounts of GT85 spray later I felt it moves better but not totally free. Back in the car and I have a heater again. That you so much to all who posted and @Sanmart for assisting with the free fix. I would say it was water ingress in my case as there was some signs of it around the motor casing once removed. Any ideas where it’s coming from and how to deal with it? Where are people ordering replacement blowers from?
  9. @pab567 do you know about these units ?
  10. It’s the cam chain that worried me on these, we had a 2008 1.4 122hp Golf and it rattled on startup, always wondered if there was a problem brewing. It got wrote off at low miles so I never knew.
  11. The 1.6 engine did have some injector issues. Perhaps stick with the 1.9 latest you can get is around 2009 I believe. Or a 2lt CR. However with 1.9 you have no DPF or EGR complexity with cooler etc to worry about, simpler on PD
  12. Glad you got it sorted. I broke one of the small screws once turned the head snapped off. It’s still held in okay despite all the damage the mirror casing etc took.
  13. No dash warnings at all. I believe they are not monitored. I already had the drivers door loom replaced a few years ago.
  14. Some instructions from this site maybe search thread yourself. A slight correction to the procedure I described above: I've just had to do this job on my 2013 Superb Elegance estate, it is a very fiddly procedure: ο»Ώο»Ώο»ΏRemove the mirror glass, disconnect the heating element wires. ο»Ώο»Ώο»ΏRemove the downlighter bulb. ο»Ώο»Ώο»ΏRemove the 2 Torx head machine screws. ο»Ώο»Ώο»ΏRemove the 2 Torx head self tapping screw securing the top half of the mirror housing and the two catches, then gently lever up the top half and remove it. ο»Ώο»Ώο»ΏUnclip and remove the bottom half, with the repeater light unit still attached. ο»Ώο»Ώο»ΏRemove the 2 Torx head self tappers holding the downlighter bulb holder and remove it to expose the screws securing the repeater unit. ο»Ώο»Ώο»ΏRemove the 2 Torx head self tappers attaching the repeater unit to the bottom half of the mirror housing and disconnect the wiring block from the light unit. All the Torx screws are T10. Replacement is the exact reverse, be careful not to trap the wires leading to the repeater and the heated mirror.
  15. My drivers side just died I bought some led dynamic ones the power connection does not fit so intermittently work. For one I know the original genuine was faulty if new one works. There are some write ups here and also these are the same I believe as the FL Octavia door mirrors. The standard ones are very expensive to buy hence me going dynamic as they cost a lot less for 2. Be careful it’s very brittle for me on a 2011 superb and I broke a few plastic clips.
  16. If it’s a DSG, change DSG stat on the gearbox
  17. First stat to replace when temp fluctuates is DSG stat. Read people’s write ups on here
  18. Maybe strip otherwise a runner about Β£500-700 with an MOT
  19. It depends on miles history and mainly condition. 12 months mot makes it more desirable. Why not post an advert in here and offer it to a more targeted audience?
  20. Yep I have a 16” steel spare with the same note on it and running 18” alloys from factory. Does make you think why you can’t go quicker with a full sizes spare but as @Ootoheresays there are many factors to consider.
  21. It’s likely there is a metal crash bar behind that area and the bumper may have moved with it since the impact. Not an expert. When I did this hot water trick on a Toyota it was all plastic in the area
  22. Hello all Sorry to admins, as I wanted a good reach. I tried to fit some eBay dynamic mirror indicators since my drivers standard one had stopped working. I saved some instructions from here some time ago, they were very useful. During the process I snapped a screw holding the mirror casing to the metal behind and one tab from the mirror housing plus one from the indicator. Unfortunately the connector to the new indicators will not allow the factory connector to sit deep enough so the indicator operates intermittently. Suppose this is what you get for Chinese products. I would therefore like to put the drivers one back to factory if anyone has one about. Given the age and brittle nature of my car I would rather not mess with the passenger side now. I believe the FL Octavia has the same part 3TO.949.10 made in China and they have LEDs in them listed as 13.5v 1.7w where power connector goes. Thanks in advance.
  23. Ditto happened on my superb 2 was intermittent also until speed/abs sensor and hub/bearing replaced.
  24. Check the starting car main battery can cause electrical gremlins.
