New
Since you have a 2015 Octavia that would be the Octavia 3 forum here
Cold air intake
I've only had one car where a cold air intake made any noticeable difference - that was a Citroen C1/Peugeot 107/Toyota Aygo Mk1 where the air intake was directly above the exhaust manifold and took in heated air, adding a pipe to directly take in cold air from the front grille did make a small (but noticeable) difference in hotter summer weather.
octavia rs
That's an Octavia 4, you may be better posting in the Octavia 4 owners forum not the Octavia 3 owners forum.
Software versions on recently delivered cars.
My point is that stating the infotainment version is no help whatsoever in determining the software version of ANY of the very many other modules in the car, so is no help in determining the behaviour of other car systems such as ACC, etc.
Remember that the version being talked about as 1896 or 1900 cannot be taken as being definitive for all the processor modules throughout the vehicle - do a VCDS or OBDeleven scan and you'll see how many different modules running different software there are in an Octavia 4!
Is Octavia MkIII (2017-2020) CANbus encrypted?
My point is that they were VW, SEAT and Audi but not Skoda - Skoda are not seen as desirable by vehicle thieves. And as J.R. points out the immobiliser encryption is much stronger than the DES algorithm and has yet to be broken so any vehicle with the full immobiliser system in place cannot be stolen in the easy way the article suggests. I think the article has an element of journalistic simplification so should be treated with some scepticism. BTW I spent many years working on vehicle electronics for a major automotive consultancy so I'm not ignorant on these issues.
Skodas don't appear in the top 10 of cars that are stolen, so I'm not going to lose any sleep over it.
Skoda Rapid 2017 integrated Satnav not receiving TMC traffic messages.
And there is still no proper solution for people living in mobile not spots to have the ability to make emergency calls during a power cut if the power cut is longer than 1 hour (the time the available battery backup option lasts).
Kodiaq warning lights after flat battery
Try driving in a circle on full lock left then full lock right to reset the steering angle sensor.
That won't help those of us with older Skoda models that do not support Skoda Connect. For us there is no solution I am aware of since the only way the infotainment systems we have can get traffic data is via RDS/TMC?
Kopacek/Superskoda
I've purchased from Kopacek both in 2016 and 2023, the only issue I've had is that post Brexit they will not ship items that are larger than the Royal Mail limits so I had to cancel my recent order for the power bonnet struts - no refund needed as they contacted me before processing the order.
Part number enquiry.
Probably a good idea to ask in the Fabia 1 forum where fellow Fabia owners will be visiting?
Octavia error codes on start up
Sounds very like an ABS wheel sensor to me - all those systems need to know wheel speed so them all appearing together strongly suggests that. I had the same raft of faults on my previous Octavia and the cause was the right rear wheel speed sensor.
ICE Vehicle Rationing
That will only happen when/if Governments break the link between oil/gas costs and the prices of electricity to consumers (which is currently artificially high) - and there's no sign of them doing that anytime soon despite the costs of green generating having dropped as volumes increases and technology improves.
How to alienate voters in one easy lesson
Space saver on 4WD
The length of the contact patch depends on the circumference of the tyre, so if the circumference is substantially the same (in this case a diference of 1.9% is stated) then the length of the contact patch will be substantially the same and hence the contact patch area will be almost completely determined by the tyre width - hence why I only took tyre width into account in my earlier calculation.
- DSG delayed response
Wireless Charging
Or are they claiming it's an early 23 spec? With the spec changing every few months (bring back annual model updates!) it's become increasing difficult to know what the spec will be on a new or nearly new vehicle.
Space saver on 4WD
Assuming the circumference is the same, that's a contact patch that is 43% smaller - so in wet or slippery conditions (mud, ice, snow, etc.) I would say that would be a noticeable difference in grip across the axle.
I'd be more likely to use the gear stick in M mode if it were more 'logical', IMHO VAG have got the "+" and "-" on the gear stick the wrong way round (unlike Toyota, I always drove my Aygo MMT in manual mode) with "+" being towards the front of the car and "-" towards the rear of the car. Here's my thinking - when you're braking, and most likely to need to downshift, the deceleration force acts to shift your weight forward so it would be best if "-" was towards the front of the car as the deceleration force would help you downshift. Conversely, when accelerating, and most likely to need to upshift, the acceleration force acts to shift your weight backwards so it would be best if the "+" was towards the rear of the car. A small point which many might not agree with or even see the problem, but one which matters to me.
Could be a faulty wheel speed sensor or connection to it? Really best to do a fault code scan with VCDS or OBDeleven to get more useful diagnostic information.
Unstarted over 12V, just started probably over 14V.
Removing the DSG Gear Shift Knob
Is the gear shift knob different depending on which DSG is fitted? On the Octavia 3 they all look to have the same gear shift knob regardless of the actual DSG model?
