JR RS
Joined
Last visited
Currently
Viewing Forum: Skoda Superb Mk3 (2015 - 2023)
Everything posted by JR RS
Battery Replacement
I have a CTEK MX5.0 and the user manual explicitly says to connect the charger's negative wire to the chassis. It says the negative connection must b away/remote from the battery.
Replaced the AQS Sensor in my Superb today. Old - 5Q0907643D (HW 30; SW 119) New - 5Q0907643F (HW 32; SW 120) Hopefully no more intermittent errors with the Air Conditioning Module 08 anymore. This was the error I would get randomly, sometimes.... "Air Quality Sensor B10AF04 [008] - Internal System Fault" Fingers crossed.
No, they r the pre-facelift tail lights. I added a light smoke tint to it, otherwise factory lights. I added a chrome strip to it - door edge protectors in fact, that I repurposed. Still going strong after 3 yrs plus. I originally wanted to retrofit the facelift tail lights, along with the chrome strip, but it was too much of a hassle, and very expensive for all the bits n pieces required. So I did my version, thanks to a cheap AliExpress alternative!! I also used the same chrome stripe on the lower door trim.
Hey hey. The cable is actually going around the A5 camera housing, but I managed to tuck it under the trim, and then under the roof liner towards the A-pillar. I didn't remove the A5 Camera trim surround - didn't want that hassle.
Throttle Controllers..... phwoahhhh!!!! Fitted an Ultimate9 EVC Throttle Controller EVC201L. Combined with the Stage 1 tune, it's like an Energizer bunny!!! Nice and easy to install too.
- REAR FOG LIGHT LED SUPERB MK3
Dashcam - Which Fuse
I've got the Blackvue Power Magic Pro. It's wired to a permanent power source in the glovebox fuse board. So far I haven't had any battery drain issues either. It's been 2 yrs plus now.
Easy entry/exit
I turned off the "EasyEntry_Enable_Passenger_Over_DriverMMI" as u recommended and the error in 5F module disappeared. Makes sense given there is no software module or memory for the passenger seat - just electrics. Sadly the Easy Entry still not working. Also the Seat menu has disappeared from the Vehicle Settings. No idea why it's not behaving. Do I need to reset my Personalisation settings? Do I need to change my Key Assignment, under Personalisation, to Automatic? This is my 36 Door Seat module:- System description: Sitzmemory Software number: 5Q0959760C Software version: 0024 Hardware number: 5Q0959760C Hardware version: H09 This is my 5F Multimedia module:- System description: MU-H-N-RW Software number: 3V0035045D Software version: 1433 Hardware number: 3V0035045 Hardware version: H50
Easy entry/exit
I have this error now in the 5F module when I perform a scan...... "U111100 - Function limitation due to missing message static"
The Superb III Picture thread
Thanks. That's actually a few days after being drenched in heavy rain, so it's not so clean, but the colour helps hide it well. This is the fuel flap sticker. Skoda + Turbo = 😁 Gives me an extra 2kW 😛
Easy entry/exit
I tried enabling the Easy Entry on my MY17 Superb too, but with no luck. I get the message "This function is currently not available" Not sure why. I don't know how to fix it. I made the following changes:- 36 - Driver's Seat Module 07 Coding > Easy Entry Front - active > Easy Entry front over MMI - active > EasyEntry_Enable_Passenger_Over_DriverMMI - active 5F Information-Control Unit Module 10 Adaptation Select channel « ENG 122227_ENG 117556 Car Function Adaptation - Gen2 > Menu_display_seat_configuration - active > menu_display_seat_configuration_over_threshold_high - active Reboot infotainment unit. These were already activated:- This was already set correctly:- "Seats" now showing, however I get the message saying it's not available.
No map in virtual dash
The virtual dash will only ever show the factory maps. It won't show CarPlay or Android Auto maps.
Canton speaker issue or firmware?
I don't know wat the process is to re-parameterize the Canton. Perhaps a visit to the service centre to see if they can help u out. Otherwise @varooom might have some ideas?
Superb Mk 3 Seat Memory
My seat controller module was replaced under warranty, about 4-5 yrs ago. They tried a software update, but that didn't fix it. So the module was replaced with this:- Software number: 5Q0959760C Software version: 0024 Hardware number: 5Q0959760C Hardware version: H09 Before replacement, it was this:- Software number: 5Q0959760B Software version: 0021 Hardware number: 5Q0959760B Hardware version: H08
Seems coincidental that this has happened not long after u did a firmware update. Likely u need to get the Canton re-parameterized. Have u done a scan? Any errors?
Where is the "Air Quality Sensor" ? B10AF fault code.
There is a TPI for it, see if ur Skoda service center will replace it for u. TPI - 2049398/3 printTechnicalServiceHandbook-2049398-3.pdf I've been getting the same error too. The part number I've got in Gandalf currently is 5Q0907643C. I've ordered a replacement part 5Q0907643F. Hopefully this fixes the problem.
VCDS options on Superb III.FL
the SWaP/FEC codes cannot b activated using ur standard VCDS or OBDEleven tools. u need specialist tools for that, ur MIB unit needs to b hacked, and patched with the appropriate files too.
Superb 272 Stage 1 experience
i've got the ContiMaxContact6 (MC6). its on the factory 19x8 Skoda Trinity rims. also with 12mm hub-centric spacers at the front, and 10mm at the rear.
I've been running 245/40/19 tyres for 2 yrs plus with no issues or vibrations. Plenty of others have been using the same size tyres too with no problems.
DCC Slider adjustment option mod
@ApertureS- u referring to this? The test was done by DSC Sport in the US. "We had some pretty interesting findings today when shock dynoing the Bilstein Damptronic B16's for a MK7 Golf R (part number 49-255874). We found the Bilsteins only are able to control the rebound, while the factory shocks are able to control both compression and rebound with their valving. This means the Bilstein Damptronics are a less capable setup when looking at compression adjustment, but still happen to have slightly greater rebound range. Basically the only benefits to the Damptronics are adjustable spring perches to change ride height and stiffer springs. But are not beneficial when looking at the "active" functionalities of the shock. This is due to the valve used in this specific shock, however in other Bilstein kits we have tested, like the Porsche Kit, the valve is different and was able to control both rebound and compression."
Hid bulb turning pink
Esshhhh.....weird indeed!!! U mentioned u've changed the ballast, but have u tried/checked the headlight driver module too? There r two modules under each headlight. U can see the two modules at the top of this pic......
Rear Canton speakers replacement
+1 The Canton sound is still great whilst sitting in the rear of my 2017 Superb. I can also clearly hear audio coming out of both the top and bottom speakers of the rear doors. My Canton Balance/Fader is set for centre/middle of the car interior.
@Colin170CR- geez.....wat an adventure!!! Good u didn't give up and persisted. I just hope u don't have curtain airbags as the wiring u've run through the roof liner will foul the airbag in the event of an accident.
Converting the Superb 3 Pre FL to the Superb 3 FL Matrix Light any experience?
@Waylon - wat is the story with ur 4B module? Is it the original that came with ur car, or did u replace that? If it is the original 4B module, has it been parameterized with a file that has the datasets for dynamic light assist? If so, was the file sourced from another facelift Superb with factory fitted Matrix LED headlights?
