Everything posted by JR RS
What size wheels/tyres will fit to Superb III
I'm running 245/40r19 tyres on 19x8.5 ET35 rims. Lowered 25mm on Eibach Pro-kit springs, factory DCC shocks. No issues at all.
Skoda Sportline Exhaust
I hope the res delete is not just a straight pipe... unless u don't mind drone.
MY17 Superb SLA Headlights Upgrade - Help
I'll send u a Private Message shortly so u can give me ur email address.....
Brake components Skoda Superb Estate 2.0 4x4 2019 DSG
For the 3V3/3V5 Superb....... 280/272 AWD Superb PR Codes:- Front - 1LA - 340mm vented Rear - 1LZ - 310mm vented Everything else Superb PR Codes:- Front - 1ZA - 312mm vented Rear - 1KU - 300mm solid
Steel Pedal Covers for DSG
Lol....I am a bad Influence 😁
I just sent u an email, to the Gmail one u had shared before.
A few Superb 280 owners here in Oz have fitted the one made for the Cupra Formentor. Fits well. The Golf R version is no good. I initially made the error of buying the Golf GTi version for my 220 Superb, only for it to b all wrong. The Octavia RS version was the right fit for the 220.
Facelift has Matrix lighting using LED. Pre-facelift has Smart Light Assist (matrix light utilising rollers) using Bi-Xenon.
Cool, thanks for confirming. Send me a private message with ur email address - I'll send u the 4B parameter file.
@Serhii1886 - sure thing. But first, do u have a pre-facelift or facelift MY19?
I'm assuming ur asking the part number for the RPM Performance Anti-drone resonator delete pipe? If so, it's RPM-SKODA-VRSADRD
Juddering on quick acceleration from a standing start
its called axle tramp. i had that before with my 220 being a FWD. i fixed it by fitting a 034 motorsport dogbone mount lower insert. i also did a code change called "Torque Steer Control (TCS)", specific to FWD cars. no issues now putting 350bhp and 500Nm+ (stage 2) power down on the road. good tyres help though. i'm running Continental MaxContact7 now.
- Wiper Position when Running & When Off
my 220 came with 19x8" ET44 235/40R19 from factory. factory spare was 16x6.5" ET45 205/55R16 from factory. it's a full-size steel rim, not the crapy bicycle tyre!! yes, i did get a TPMS warning whenever the spare tyre was on, which would in turn disable ACC and Front Assist. i've had 3x punctures in the first couple of years of ownership. super annoying. hence why i got a full sized 19" tyre as a spare now. original factory spare.... comparison between 16" spare and full size 19"....... with 19" spare in the boot....
Not debating the overall tyre size - just stating wat is factory fitted spare tyre. I myself have a full size 19" tyre.
Factory spare wheel for the mk3 Superb (non-272/280) is 6.5Jx16 205/55R16. U've got a 6" wide wheel.......
Seat adjustment, resets when getting in
The module needs to flashed with a software update/version. Not a VCDS thing. Mine had exceeded it's min/max thresholds - as a result, it was't remembering any of the saved settings. I did the whole seat calibration procedure but to no avail. In the end I took it back to Skoda and they replaced the seat module with later revision, under warranty. Original:- 5Q0 959 760 B Fixed:- 5Q0 959 760 C No issues since then.
It's a safety thing for the seat motor railing. U can't change it. If u exceed the motors max and min positions, u'll upset the seat module controller, which will then need a software fix or replaced altogether. I've had my seat module replaced.
- UK spec S3 2016, prepping to re-reg in Spain, tail / foglight query
Using google maps
Did u not read my post earlier?
- Superb 2017 Sportline – Wheel Fitment Help
Using google maps
Simply won't show with MY16 to MY19. U already have MIB2 in ur MY16 Superb. MIB2 does not show CarPlay or Android on the Maxidot. Likewise, MIB2.5 does not show directions in the Maxidot. Doesn't matter wat software/firmware the MIB2/2.5 unit is running. I'm not sure about later models with the MIB3 units being able to do it on the virtual cluster. No....u can't retrofit MIB3 on ur pre-facelift Superb.
