OBDeleven
Just now, Item said:
Ah great! Something for me to check over the weekend then...interesting I still managed to get the rears working with my guesses!
Did you get the wiper park working?
Ive not tested the wiper park, only activated. I'll need to wait for some rain. Can't see why it wouldn't work given the teardrop success.
  • Replies 437
  • Views 150.8k
  • All to do with the UDS protocol.   I don't believe you can take a back up of a scan and adaptation map with OBD11, so you don't have a reference point to go back to IF anything doesn't go to plan.
  • Again apologies if this is in the wrong section.   Tried and tested on a 2016 vRS with Lane Assist.   High Beam Assist (for cars with Lane Assist Camera):  Ensure light switch
  • In terms of long coding, yes, the OBD dongle makes it very easy and CHEAP to do long coding. It also has some of the most common modifications people want to perform pre-programmed in as "one-tou
Yesterday I almost posted that I was tempted to take the plunge and go for one of these but I was a bit worried about making a mess of things.
However it appears drunk me has none of these concerns and purchased the pro version at about 2AM last night/this morning. So here goes!
Im wanting HBA for my VRS, some indicator tweaks and other menial things. The mrs has a fabia monte carlo and I'd like to enable hill hold for her. Im worried about introducing faults but Im sure going backwards is fairly easy?
my advice is only make 1 alteration at a time and check that it works so if you need to backtrack it is easier
Sage advice, sage advice!
Good advice indeed. Think I've mentioned in here before, I also do a dry run as well. So if something requires more than one tweek to some adaptation I'll make sure i can find them all first. No use getting half way then no knowing where to go next.
It does keep a log for you so you can retrace your steps if required.
I got my pro Obdeleven a few weeks back and have done a few tweaks to my vRS, I have noticed today though that the corning fogs were not coming on when headlights were in auto and on due to it raining but we're working when switching to the on position but I'm sure they were working the other night with lights set to auto and it was dark. Anyone else noticed  similar behaviour?
On 22/02/2017 at 01:50, spinifex said:
Yeh I considered this, but the VIM is just a "maybe I'll use it one day" thing for me, and not a necessity.
I used my credits enabling it for someone who was using an external OBD program for displaying live analogue data monitoring/gauges, and needed it to display on his screen while driving.
It worked perfectly, and I was considering doing it on mine too, but I don't have the other OBD device for it yet, so it's not critical for me.
I'll probably just wait until I've earned enough bonus credits each day by viewing ads.
Can earn 5 per day, so will only take a few weeks to get enough to use the one-touch app.
I went for 3 weeks in a row everyday on the ODB 11 app and managed to get the 100 credits to buy the VIM app, just requires to remember to launch the app everyday ;) Got VIM to work and it's pretty cool, even though I rarely use it (only in long traffic jams)
Hahaha well sometimes alcohol helps to make a choice (event if it's often the worse :D). But in your case it's a good decision, really nice to be able to activate all those things for your cars and those of your friends :)
You can track all changes you have done, so going back is a piece of cake
Edited by Wiivern
Me and a guy at work had a chat about it and we were both undecided, that was friday and on monday ot turned out we both bought it. Its a long trail from lithuania so im pocketing the free credits for the one touch stuff but I'll be ready for the coding too.
Shpuld be fun, thanks for the vote of confidence ;)
does this allow you to control the temp of heated seats?
thanks
you can adjust the initial heat of the seats when you press the button but only as in the initial heat will be 1 2 or 3 bars (default is 3), you not able to change the level of each setting in actual degrees
I can only agree that OBDeleven is indeed a great and cheap tool to have, I've done a lot of adaptations and some coding to my vRS!
Once you start tweaking you can't stop :D
That`s why I`ve just bought one :tongueout:
How long the delivery takes?
Edited by imikk3
To Sweden, a week tops!
To the UK its taken 12 days so far! Cant be far away!!
On 08/01/2017 at 15:14, ahenners said:
Followed the instructions for High Beam Assist enable, including the helpful bit from Spnifex regarding the byte 2 bit 0-2 value change. Had light assist in the car setup light menu to tick, but when pushing the stalk back it showed the symbol for HBA for about a second, then said Light Assist Fault. Anyone else had a similar issue or any ideas? Reviewed the instructions and followed again exactly but still had the same issue.
I'm getting the same issue, does anyone know a way around this? It would be so useful!
Clear. The errors then it should be ok
to Czech just 5 days
I got my superskoda parts from the Kopaczech company quicker! Lucky you!
Guys, I must say that OBD11 works very fine .. I set up a lot of things like a:
the second rear fogs light
pernamently high beam assist on
speed of fan on auto mode
site light (orange) indicators when the fifth doors are opened
start/ stop off
DLR in opposite phase with orange indicators
laptimer on
fuel liter tank on
and the windows closing if is raining..
that all via coding/ adaptions with tutorial here on forum, ALSO THANKS!!
BUT I have a problem with Trafic Sign Recognize ... I set up all what is in tutorial, but the "
Controller A5 (Front / front view camera)
07 - Coding
Byte 1
Bit 0 Enable - "01 traffic sign recognition (FTE) active"
 a
16 - Security Access - enter 20103
10 - Adaptations
Select channel Display end of speed limit symbol
Change to activated
I cannot to find, the app show me just A5 Controller (front/front park sensors).. but not the "Front/ Front view Camera" also in coding I cannot find the other thinks...
My car has builted the front camera for Lane Assist etc, simply I have in auto all what possible is in original... anyone the same problem? I wont to pay a 100 credits for this tweak... :D
O3 RS 2.0 TSI MY14
I bought the OBD11 on original site, thats Lithuania I think
Me too, bought superskoda the day after but they came last week. My OBD is waiting at the post office!
I followed these instructions after the first time I tried I got the same errors
09- Central Electronics adaptations: [2] Assistance Light Functions- Menuesteuring Fernlichts- Change from Not Present to Present
09- Central Electronics coding: Byte 2/Bit 0 change to 1. (Byte should change from 0A to 0B (MT), or 1A to 1B (Automatic))
A5- Frnt Assist/Driver Assist coding: Change Byte 2 to 01 (High Beam Assist Present)
Interestingly - the latest update to OBD11 now has the Traffic Sign Recognition programmed as a one-touch app.
It "costs" 100 credits, because of the amount of programming/coding involved, similar to the High Beam Assist one-touch app.
But if you don't want to mess with trying to long-code a gazzillion different modules, it'd be worth it if you really want it.
Those members in Australia (and possibly elsewhere too) will probably still have the error message on the maxidot, which can just be cleared and has no effect on the function of the TSR.... it's something that nobody seems to be able to rectify for Australian road signs.
does the changes leave traces in the TD1 bit and therefore could be tracked by the dealer?Can they reject a warranty somehow?
ok, I ll do it via 1touch app.. :/ :D
