OBDeleven
What's that do?
  • Replies 437
  • Views 152.9k
  • All to do with the UDS protocol.   I don't believe you can take a back up of a scan and adaptation map with OBD11, so you don't have a reference point to go back to IF anything doesn't go to plan.
  • Again apologies if this is in the wrong section.   Tried and tested on a 2016 vRS with Lane Assist.   High Beam Assist (for cars with Lane Assist Camera):  Ensure light switch
  • In terms of long coding, yes, the OBD dongle makes it very easy and CHEAP to do long coding. It also has some of the most common modifications people want to perform pre-programmed in as "one-tou
Does anybody got this Apps section in obd?
(when it connects, it goes to car icon above and then in Apps section)
This Apps section is red in my obd (I have pro version)
i have the same as you - it's red and i don't have access to it.
i see from the links at the end of the youtube video above you can use obdeleven to access the green engineering menu
Just got it (PRO) and had not yet the opportunity to plug in the OBD, but installed the app requiring username and pwd... but I just have an activation code!
Are they provided by the USB dongle?
TIA
TIA
Same issue!
Silly question maybe but have you switched on Pro?
Press on the 3 parallel lines top left of the home screen, Press Settings and then there's a "switch" to turn on Pro. If I remember correctly, this is when you'll be asked to enter your activation code.
Thanks for your answer,
I've been there, but I see a "Need to Sign In" and when pressing on SIGN IN I get again the screen requiring username and password... and no instructions available, as far as I can see.
P.S.: I just dropped an email to [email protected] and will report
Edited by Genoa1893
They requested to register on the forum (!). No surprise nor success in trying to sign in with forum credentials...
i had a query about losing my activation code, submitted an email and had a reply within 15mins!!!
the initial activation code is a one time affair. after that your pro licence is tied to your email and password you setup for the account login
also disabled the chime warning thing when stop/start has activated then you open the drivers door
Does anybody know how to disable warning tone when drivers door are opened with engine on?
17 Instruments
Adaptations
Ignition active message; Trigger
Change to "No display" (default value: driver's door)
I must be particularly thick: I've got an acrivation code for the PRO, of course, but when I try to connect I'm required to Sign In.
To Sign In I need an username (heck I had got only an activation code) and a password (again, I had only an activation code).
Yesterday obdeleven told me I need to register on the forum (???). Anyway I did it and I got usable credentials (on the forum).
Yet, these credentials are useless to Sign In the android App!
P.S.: Ok, I received a prompt anser this morning, issue solved.
Edited by Genoa1893
I found a 'register' option within the app, I think it was under settings. I'll check tonight.
if you know how to do it is simple, just select the image with e-mail (in my case) and define a new username and pwd.
Then everything was pretty straightforward.
Stefano
Bynow I just activated the refuel info on the MFD, but I can't enable the auomatic lowering of mirror on reverse.
Did you just coded what written below
http://obdeleven.proboards.com/thread/176/coding-adaptations
or is there any other trick I must be aware of?
TIA,
Have you enabled the function in the Car settings in the infotainment?
Access Control 2-Menuesteuerung Spiegelabsenkung. Value=Active
...is the coding for placing a menu item with tick box in the Mirrors and Wipers section.
Thanks for your answer!
No, I just followed these steps:
Folding Right Mirror in Rear
Select Control unit 52 (Türelektr. Beifahr.)
Control unit Long Coding
Byte 04
Bit 2-Activate
Bit 3-Activate
Select Control unit 09 (Central Electrics)
Access Code 31347
Adaptation
(15) Access Control 2-Spiegelabsenkung bei Rueckwaertsfahrt
Value=Active
(20) Access Control 2-Menuesteuerung Spiegelabsenkung
Value=Active
It's in Car>Setup>Mirrors & Wipers if I remember correctly.
There should now be a new tick box menu item allowing you to choose whether to have it enabled or not.
And the Mirror adjust knob has to be in the Passenger mirror position.
I'm not convinced it made a lot of difference as it doesn't lower much, plus it doesn't return to it's original position - you have to use the door switch for that, so..... ho hum.
TIA,
Did you set the mirror selector dial to the passenger mirror position?
Also, you should tick and untick the toggle to make it work - of course ending with a ticked toggle in the car menu.
Ticking and unticking the toggle ending up with a ticked toggle?
I knew this would get faar too technical for me.   :rofl:
It kinda does - when you turn the engine off or start driving forward beyond a certain speed.
I turned mine off, it was more trouble than it's worth as I had to keep adjusting it back up.
ok, but on one side I miss the auto lowering,
on the other...  I'm trying to justify the money spent on the toy :notme:
Success, thank you!
Is it possible to take a snapshot photo inside of some modes?
Can anyone tell me the channels for the rear indicators, please? "Leuchte" I understand, it's the numbers after which are not very self explanatory.
Also beats me why the first half of the adaptations list is in english and then changes to german. What's all that about?  :notme:
