OBDeleven
Hello to the community, I've been a lurker on this forum so far, but I felt I needed to share my experience with this OBDEleven dongle + app (PRO license).
My Octavia is a MY16 Estate with MIB2 Bolero and everything works like a charm. So far I've enabled the below:
- cornering fogs
- both rear fog lights
- needle staging
- hill hold assist timing
- change comfort lane change indicator flashes
- Automatic DST
- Deactivate AM band
For 55 Euros the price is unbeatable and unless you need the extended capabilities offered by VCDS you get 95% of the functionalities for a fraction of the price.
For any android phone/tablet owner this should be a no brainer.
What is Automatic DST?
  • Replies 437
  • Views 152.9k
  • All to do with the UDS protocol.   I don't believe you can take a back up of a scan and adaptation map with OBD11, so you don't have a reference point to go back to IF anything doesn't go to plan.
  • Again apologies if this is in the wrong section.   Tried and tested on a 2016 vRS with Lane Assist.   High Beam Assist (for cars with Lane Assist Camera):  Ensure light switch
  • In terms of long coding, yes, the OBD dongle makes it very easy and CHEAP to do long coding. It also has some of the most common modifications people want to perform pre-programmed in as "one-tou
Daylight Saving Time.
The clock will add an hour in the spring and minus an hour in the autumn, automatically.
Apart from this year, when it didnt for mine annoyingly. Anyone else have that this year?
(also, is this not standard? I have it on mine-basic Bolero)
Edited by Mallettsmallett
I'd only had my VRS for a week and was disappointed it didn't change itself as my previous Leon did. Took me 10 seconds to sort by my setting time and date to be GPS controlled.
I have i all set to automatic and I still had to change the time manually.
Me too
Has anyone tried to see if the OBD eleven can unlock the engineering menu ?
Quick one, I have set the passenger mirror to dip on selecting reverse. It only dips very slightly though. Is there a way to set how low it dips? There was on my FR.
MY16 VRS, no memory seats or mirrors.
I had a look in controller 5f - there is a toggle to activate developer mode but didn't work for me (i used 20103 as security code)
i had a query with the developer after losing the OBDeleven packaging with the pro code sticker on it asking if i change my phone will it ask me for the code again - had a reply within 15 minutes!! from the developer saying it is a one time activation code - once you have an email tied to your initial pro code it will recognise you as having the pro licence if you reinstall the app on another phone etc
Without the memory seats/mirrors that is all you get. I have it done on mine and I think that it is better to have it than not have it. What I do is to have the mirror set normally fairly low, as I don't need to see the sky, so that when it dips, it is enough to see the ground. Be aware that it may not always return to the same position so you may have to occasionally manually tweak it.
There's a section in the manual explains how the set the dipped position
Just noticed the previous post though so probably ignore me! Haha [emoji85]
Edited by DravenSteel
That's only if you have memory seats/mirrors
Whoops! you were editing while I was typing. I will follow your instructions and ignore you, maybe!
Set the adaptation channel to Europe as per the VCDS sticky
Because you need a more powerful tool to be able to access the controller in engineering mode in order to change that adaptation channel
Can you transfer this device on your next vehicle or its limited to just one car?
I'm guessing I need vcds to do that?
The app has a "Garage" where different cars can be stored by inputting their VINs (or deleted) so I assume that it's transferrable.
I need some pointers:
1. How do I change Comfort Blink Cycle to 5?
I did that, although it offer values to enter from 0-3, it accepts value 5, but it still blinks 3 times after adaptation.
2. How do I disable open door chime?
3. Extend or remove headlight wash on bixenon?
4. Make DST automatic?
 after coding you need to set your lights back to factory default in the infotainment unit before this change takes effect
hope that sorts it out
Yes, I have already found this and it works.
Anybody done this?
Dynamic Breaks
Select Control unit 03 (Brakes)
Adaptation
Channel 09
Value 2
Which part do you have to reset, I can't find an option to just factory reset the lights.
Found it.
Sent from my SM-G920I using Tapatalk
Anybody done this?
Dynamic Breaks
Adaptation
Channel 09
Value 2
What's that do?
