What bulbs are fitted to the S3 & upgraded bulb recommendations
@dilino
4x Footwell lamps r the same type I believe.
1x glovebox
2x boot (for liftback)
Edited by JR RS
  • Replies 798
  • Views 227.8k
  • Reversing Lights   1156/BA15S/382   STD:   80W CREE LED’s:  http://www.ebay.co.uk/itm/2x80w-1156-BA15S-382-BRIGHTEST-OSRAM-CREE-LED-WHITE-CANBUS-REVERSE-BRAKE-DRL-/152013310456?hash=item2364b
  • Boot lights   (no std photo)   Fitted with W5W LED’s from eBay (the flat 4x LED ones in the middle)         Now whilst these were a big improvement over std they were not as good as they
  • Rear indicators   PY21W    Philips X-treme Vision http://www.powerbulbs.com/product/xtreme-vision-py21   OE on the left LED on the right:
3 hours ago, dilino said:
i mean 4x in trunk (only 2x such in estate?) and maybe one such in glovebox and one in each door ?
originally trunk bulbs are only two no matter hatch or wagon,
hatch have them in trunk, while wagon in cover.
additional two bulbs in hatch's cover were my idea
different type of bulb body comes in glovebox
-> https://www.briskoda.net/forums/topic/393511-what-bulbs-are-fitted-to-the-s3-upgraded-bulb-recommendations/?do=findComment&comment=5375416
door's warning light also have different type bulb bodies
-> https://www.briskoda.net/forums/topic/393511-what-bulbs-are-fitted-to-the-s3-upgraded-bulb-recommendations/?do=findComment&comment=5168994
On 01/09/2024 at 12:18, numskull said:
If you want a cheaper pair of boot lights, these do not have any issues, so no bonging when you open the glove, nor box flickering on the maxi when the doors or boot is opened. Here
The link does not work, any chance you could relink please?
  • 3 months later...
Hi folks,
I’m sorry if this has already been covered.
Has anyone had any issues with warranty or MOTs after fitting upgraded reverse light bulbs?
I don’t know if it’s the weather, my eyesight or the fact that the car is longer than a supertanker, but I’m really struggling to reverse safely at the moment.
I’m pondering whether to go with upgraded halogen or bite the bullet and fit LEDs.
5 hours ago, djfish said:
Hi folks,
I got these
Nothing mentioned at MOT, as they just have to work and not as specific at headlights
Edited by Danoid
@MartiniB - for the wing mirror cover with BSD retrofit, below is the how it was connected up, if anyone is interested.
Edited by JR RS
Hi, I would like coding puddle lights in rear doors of FL Superb 2020
In Carscanner or VCDS or aren't explain about bytes to be modified to activate it.
Any suggest?
BB. Rear door behind driver (UDS)
Application data identification: 4X0480SK48100003
VAG Part number: 8W0959595M
Software version: 0384
ECU serial number: 0000406388709
Hardware Part number: 8W0959595J
System designation: TSG HFS
Calibration date (ASCII): 000101
Hardware version: EV_DCU2RearDriveMAXHCONT
ASAM/ODX version: 001005
Application software identification (id/version/valid/plausible/used): 7200/0003/1/1/1;
Parameter set part number: CU5-DCM24.02.200710459A
Parameter set version: 0001
System abbreviation: J388
Date of last adaptation: 000101
Date of last coding: 200504
Diagnostic mode: 03
Parametrization date: 200504
Long Coding: 001880208000020000001100
BC. Rear door behind passenger (UDS)
ECU serial number: 0000406394131
System designation: TSG HBFS
Hardware version: EV_DCU2RearPasseMAXHCONT
Parameter set part number: CU5-DCM24.02.2007103620
System abbreviation: J389
Diagnostic mode: 03
Any suggest?
Before u do any coding - do u have the hardware for puddle lights in ur rear doors?
Normally those r dummy reflectors in the rear doors, and the wiring is not there.
Yes, of course W38 in pin 12 and 13 of T16o 16 pins connector of door control unit.
Done, just reinstall VCDS and full information in long coding helper.
Hi , I have a 2019 Superb 1.5 Tsi SEL Executive.
I am looking for help from any members the head lights : The car has Bi Xenon Stripes head light that could be better.Full beam head lights are really bright ( never been flashed ) but fields of vision and range is limited.
Any suggestions re bulb replacement would be greatly appreciated
A long time ago I changed the factory D3S bulbs for Phillips XtremeVision Gen2 D3S bulbs.
They were a nice improvement.
This was footage of it...
I recently replaced them with LED D3S, made by J.W.Speaker.
Massive improvement.
This is with the LED bulbs...
Hi everyone ,
Thank you very much for information to improve the head lights in my Skoda series 3.
Will digest details and keep the forum up-to-date with my selections made ( if any )
  • 6 months later...
Can somebody please recommend a quality wiring harness for the door interior exit lights on a Skoda Superb 3. I've checked some older posts, but the Aliexpress links aren't available anymore.
I had a 2009 superb before this one. It has better headlights than superb 3, especialy high beam with additional halogen. On superb 3 when i turn on high beam, almost no diffrence on the road ahead.
Ur headlights r incorrectly aimed.
The mk3 pre-facelift Superb Bi-Xenon headlights r really good, when aimed properly.
If u have a broken levelling sensor, or an associate fault, ur headlights will simply point downwards.
This footage of my headlights, showing both low & high beams.
Hi. Any up to date recommendations for led reversing and rear indicator bulbs?
Twenty20
I have replaced my hid bulbs, I suppose they were stock ones.
Philips Xenstart old ones.
Osram Night Breaker 220 new ones.
Light was tested at the same road, 1 day difference, same headlight settings and same camera manual settings. So comparison is valid, not amplified with camera auto settings.
Upper old
Lower new
Left is main beam
Right high beam
Upper old
Lower new
Left is main beam
Right high beam
That’s a great improvement. I love the nightbreakers. I used to have them in my golf many moons ago.
Just had new bulbs fitted to replace old factory xenon bulbs. I went for D3S Osram Xenarc Blue Intense and they are fantastic. Car is Superb Sportline 280 year 2018
