Reversing Camera Retrofit
The Sinosmart camera injects it’s own code. Put the car back to standard, untick all camera options (lowline and VPS) and soft reset radio. If all faults clear, plug the Sinosmart camera back in, soft reset radio and that should sort it.
  • Replies 168
  • Views 76.6k
  • Up and running!
  • apple_pie
    apple_pie
    My first post here, and english is not my native. I have finally managed to install the Sinosmart reversing camera on my Octavia mk3 MY2015 (nickname: brownie). The hardest part was the cabl
  • If your tailgate handle is 92x35mm and you ensure the camera is an NTSC camera then yes it will fit and work once you’ve done the relevant coding tweaks.
Hello Sasha.
I believe you have me confused with another recipient of your help.
Terry.
Thanks @SashaGrace I did as you suggested. Unfortunately, it didn't work :crying:
I reverted back all the changes and did an auto-scan and here is the auto-scan results:
Log-26-07-2021-1.txt
Then I connected the camera and when it didn't work I did another auto-scan and got this:
Log-26-07-2021-2.txt
Then enabled the rear camera in the park assist control and got this:
Log-26-07-2021-3.txt
In the last auto-scan it complains about miss communication and I get an error as below:
Edited by Vahids
It scares me the way the Chinese cameras seem to code themselves in and seemingly even mess with the diag comm's from 5F. Sure, the OEM cameras are more expensive but they avoid these issues :D
I don't think I have much to add I'm afraid @Vahids - assuming you've got a scan and adpmaps from before you tested it, my only suggestion would be restoring everything then connecting it. Might be worth contacting the seller too.
Not sure if you know anyone with a HEX-V2 or HEX-NET to find out more detail for some of those errors?
This camera should be plug and play. Chances are the previous owner has coded something which has interfered with it
OK, some update on this. I figured out what the issue was! As sashaGrace and weyland said, the camera is plug and play really! The issue was the camera does not show the video signal if the boot door is open. So, because the boot door was always open during the installation, it never showed the video signal. So, after I reseted all the previous camera settings it started working (of course when the boot door is close)!
On 04/12/2018 at 13:16, SashaGrace said:
That’s correct, however I would ask how much the lines mean to you? The camera linked above can be coded into the Amundsen HU as can all the cheap RCA plug ones, you just chop the end off and crimp VAG terminal ends on and plug them into the quadlock. I believe the highline camera also has the washer jet to keep it clean which is a good idea, but my camera was £20 and when the correct NTSC one gets here (I’m hoping by the weekend) I’ll detail the install. For now, this is a £8 universal RCA input camera rigged to my car for testing. Much cheapness :D
I really would like you to send me some info as to how to do the wiring. I bought a cheap AliExpress camera and I don't seem to be able to get image on my amudsen. It is driving me CRAZY.
  • 9 months later...
Thank you all,
I managed to install camera for my 2017 octavia. Working as smooth as told here :)
Local skoda dealer wasnt able to sell me camera when I bought the car so aliexpress saved my day :)
I have one 'silly' question,
Is there a way to remove that "warning" message at the bottom of view? Its blocking my view to towbar? Also would remove that 'sensor view' by default.
Any ideas?
Gurus are being called..
@pab567
@sashagrace
Thanks, Daff
  • 1 year later...
  • 4 weeks later...
Hi, I've just bought a camera to fit to our Octavia Estate (Mk3 facelift) and after reading this thread, beginning to wonder if I need a computer expert to help me getting it to work!  I've got plenty experience of fitting stereo's, cd changers, speakers and amplifiers in previous cars, so trim-prising holds no fears, but seeing things here like "reverse camera in 5F Byte 19 Bit 4" and I crawl under a desk with my hands over my head!  Words like CANBUS don't help either...
The camera is an ATD2514 SKOD4 from ebay (https://www.ebay.co.uk/vod/FetchOrderDetails?itemId=175161616367&transactionId=2555399690007&mkevt=1&mkpid=0&emsid=e11400.m144671.l152967&mkcid=7&ch=osgood&euid=b80cbeaabf87457e919b3d4b35162be5&bu=43211089509&xt=254362&osub=-1~1&crd=20230914080127&segname=11400), it has two cables - long with yellow rca plugs plus short red leads for reversing bulb connections, the other is for 12v switched / earth supply.
Have I bought the right piece of kit?  It's mainly needed to help reversing up to our caravan hitch.
The link is for your order so only you can access it :)
Still, at a guess you bought this: https://www.ebay.co.uk/itm/175161616367
If so, it'll probably work but....
- you will need to find someone with VCDS or similar to recode your car
- the headunit doesn't have an RCA plug so you'll either need an adaptor or to chop it off to put the correct pins/connector on
- it should be powered off the reverse lights but it'll likely have interference without a relay kit
I'm also not sure what video format a MIB2 headunit expects, maybe someone else can confirm if it's correct.
Yes, that's the one.  So "vehicle specific" doesn't mean no additional parts or tools required...  Annoyingly I missed the bit in the product description that says "This will NOT work directly with any factory fitted monitors or head units" which is what we've got.  Just had a conversation with the seller, they do sell a connection kit for the MIB2 head unit, but it's £249 which blows my budget a bit.
Now I've seen Aliexpress mentioned on these forums (fora?) but have no experience with buying from them - are they a good source of the complete kit?  If so, does anyone have a link to the right package?  Is the link from SplinthMonkey's post from 24th August the right kit?
Eddie
I bought mine from AliExpress, see the other ‘retro fit reverse camera’ thread on here. (Author was member Wayland). No coding needed, mine iirc was type A, but the type you need depends on the tailgate handle size.  Took me about three hours to fit, you will need trim removal tools (eBay is your friend) and a bit of curtain wire to aid threading.  I didn’t fully remove the tailgate trim, i managed to jer-jiggle it enough to get at the latch.
Edited by Baxlin
Indeed 😞
In this instance, it would appear 'vehicle specific' just means it will fit in the boot lid hole...
Personally, I'm not a fan of the Chinese 'magic' kits like the Sinosmart. I don't trust anything that's recoding modules automatically and some folk have had issues with similar kits failing quite quickly.
I would always recommend a genuine highline kit from a reputable seller. Yes it'll need coding but done right, it'll be identical to a factory installed kit. For example: https://www.aliexpress.com/item/1005003578483619.html
Have a look at this thread for some ideas and pros/cons etc:
Eddie
I bought my kit from Ali Express, and it was all straightforward and was plug and play for about £45.
There is a full guide here.
My tip would be to run the wire down to the back not up in the headlining. That way you don't have to worry about it fouling the airbags in the A-pillars and above the doors.
I found a dowel and net curtain wire invaluable when threading the wire.
Also plan ahead for where you're going to put the large boot trim down if/when you remove it so you don't mark your trim.
Good luck!
Hi,
Based in this thread I took a punt on one of these plug and play camera kits from Aliexpress.
all works as described but the camera display is in black and white? All the connections looks secure.
for £35 I can live with it but just wondered if anyone had any bright ideas or if I’ve missed something?
Any ideas?
@pab567
@sashagrace
Thanks, Daff
Hello! That would be a really useful piece of information!
Thanks in advance!
  • 6 months later...
On 24/08/2023 at 22:29, SplinthMonkey said:
I have a mk3 octavia 2014. I want to fit a rear camera to original
1. Is it this one [camera e] ...https://www.aliexpress.com/item/4000230897829.html?spm=a2g0s.9042311.0.0.40694c4dTEPT93
2. I'm confused because it does not say this is for 2014 model.
3. Is the picture quality good
4. Do I need to get system reprogrammed with VCDS ?
Did you figure this out yet?
I recently got a Skoda Octavia mk3 rs from 2013 and I want to retrofit a rear view camera. Coding isn't a problem, a friend of mine can do that.
My problem is that most of the camera kits I find are for 2017 and later (facelift). I really don't know which one I need for my car, does the facelift camera fit or what do I need, can someone please send me a link to the correct camera with the wiring.
I only find stuff like this, but it says 2017 and later:
https://a.aliexpress.com/_EQEvwjz
This is my head unit:
And further down it says that it also works on a 2013 Octavia
I also retrofitted one on a MY2014 and it works just fine.
