2016 Fabia Monte Carlo TSI 90
i must be too use to diesel boost pressures as im nearly 30psi
  • Replies 110
  • Views 17.5k
Our engines put out 8 psi and 11 stock stock form, at least on the EA111 platform, what about yours AMD?
Never logged it stock but I was 20psi stage 1 and now around the 30psi mark
Well get ready for this one!
As per JBS, even though stage 2 often sees over 150 bhp on the 1.2 TSI, they don't run any more boost than stage 1. So it's not even like there's more boost to be had 🤣
  • 5 months later...
Please join freedom if you wish to advertise
Edited by Gizmo
non freedom sales.
@Fab1493
It would be worth advertising them on a Skoda enthusiasts forum like Briskoda.
The Fabia is now running on 15 inch steelies with offset 29 so they're closer to flush with the bodywork. The higher sidewall makes for a much faster "real World" drive because I don't have to slow down as much when driving over broken surfaces even with the lowering springs, very happy with this tyre size 😁
I know this is a dangerous subject but I need to mention - I have been running a pedalbox since late 2019 and on wow what a difference!!! The difference is the same as my 2013 Leon TDI 184 between ECO and Sport. The Fabias accelerator with the pedalbox is actually even more direct than the Leon in Sport which I thought was super direct throttle.
It doesn't improve performance in any way shape or form however it does do what I intended which is add another layer of connection with the car when driving.
Picked up this the other week!!
18k miles from new, one owner, full VW history, manual gearbox.
Don't plan on modifying the Fabia any further as I now have this as my toy 😁
Final update - sold the Fabia last night
  • 6 months later...
how much was the rear stabiliser bar??? and from where did you get it??? got any pictures off fitting it??
regards
Sören
  • 3 months later...
regards
Sören
Apologies for the late reply, kinda been off this forum since selling the Fabia. Only saw your reply as I bought another Fabia (this time 1.2 TSI 110) and came back to the forums.
The rear anti roll bar I got from Whiteline UK, I think it was circa £160 or around that and I did not fit it myself however the guys who did it for me are NOT VAG specialists so they only fit bolt on/easy stuff and they had no issues with it - took them less than an hour.
Hope that helps
