Amundsen MIB2 Firmware Update
4 hours ago, octaviavrs5e said:
suite à la mise a jour ce jour j ai des default  de version en passant sur le vcds  pourriez vous m'aider pour solutionner ca
Merci
Since most of us here don't speak French here's a translation of octaviars5e's post made using Google translate
Quote
following the update today I have version defaults passing on the vcds could you help me to solve this
  • Replies 4.6k
  • Views 770.8k
Hi guys. Is there an update for me ? I will leave a photo
 Hello i have problem with my apple car play while i am on the call with someone  and also i am having screen freeze problem. May i receive the 0480 version? I have attached the current version info. 🙏
Hello, also please for a newer firmware version. Thank you very much.
Martin
Hey Pab567
Been searching around for a few days now…hopefully you can supply a link to a newer version of software for our Karoq…the online update feature of the car just responds…Service Unavailable….despite being online and Connect Services all working fine…?
Here are the current version numbers…
Hello Pab567,
If you have chance, please could you let me know if there is a newer firmware version for my 2016 Skoda Rapid Spaceback?  If yes, I'd be very grateful if you could provide a link.
Picture of current version below.
Thanks in advance!
Hello everybody!!
Could you send me newer firmware PATCH?
Attached photo with current version on my octavia 2018.
device: 5Q0035840C
HW: H41
SW: 0472
Thank you very much.!!!
Manuel
And for this model ? Skoda SuperB
thank YOU
 I need your  the help please I can't install the update ( the current version ;   MST2_EU_SK_ZR_P0456T  )    (  the version that i want to install : MST2_EU_SK_ZR_P0478T )    .. I downloaded the file correctly then I put it on the memory card I inserted it .. after when I click on search for update I am told ( cannot read info file source version unavailable )
What does that mean .. is the problem with the sd card or the file?
thanks all
Push the menu button for like 10 sec and you will find the update option. Use that and you will succeed.
good luck 🍀.
good luck 🍀.
I did that ..... you can see the pictures ...what file format to install * .rar where I have to extract it
thanks
thanks
Extract to root. Metainfo has to be in the root. format has to be fat32. use sd card.
Edited by gerstemann
ah ok
possible that the problem is the NTFS sd card format
thank you very much i will try to format the card with fat32
25 minutes ago, salimslimani said:
ah ok
Thank you the problem has resolved
It worked fine, upgrade it from software 472 to 480.
All you need is posted at this 1-45 pages,
future upgrader... JUST READ !!
please .. I want to know if the car must be parked and just the key in contact or I can drive when installing the update ... thank you
Hi . For this ?
Hello guys. I asked for a firmware update about a week ago. Is there any other info that i can help you with ? I will leave the info from my car in a photo. If there is other info that is needed, please let me know. Thanks a lot !!
Thanks guys !
is there any updates avaible? Hoping to get random aux heater problems fixed as winter is coming. Yes, the problem should be in the HU. Kinda resets itself from time to time and forgets all user set heating times.
I see that someone has a blue interface, someone red.. I have a black and white one.. maybe it depends on the color of the vehicle? Is it possible to change it?
Hi. I have Karoq 1.0 TSI MY2018.
Since yesterday I have a problem with Android Auto: error connection 8.
In an italian forum I read there is a problem with head unit firmware. My software info are here:
Is possible to have the software upgrade for this unit?
Thnaks in adavance for you precious help
Hi @pab567, just bought 2016 vRS and attached is the system info. Could I kindly ask for the latest updates? Many thanks.
Hello @pab567
Is there an update for mine? Thanks in advance
PM
