Blind spot assist retrofit
  • Sponsor
We can’t work with clones sorry. It needs to be a genuine VAS6154 or a VNCI6154a
  • Replies 244
  • Views 32.9k
  • I  am almost done with the materials.  Here the most important.      Left radar 2Q0907685H  Right radar 2Q0907686H (master) Bracket on the left 5E6907456A
  • I've had VCDS for well over 10 years and it's paid for itself many tmes over with £100 in garage fees saved everytime I (or friends) have needed a fault diagnosis.
  • Could you please open your topics in the karoq area and create a thread for each topic?
OK, understood. I appreciate your help.
I have installed the entire system in the car and in the next few days I am going to buy the original VAS6154 so that I can remove the cp. Is there a guide or someone who could help me? Thanks in advance.
@alexandros_kolyvas ,
You will need access to ODIS On-line to remove CP for new added 3C module and a dongle/tool capable for SFD Unlock dedicated modules (CU17, CU19) to make the necessary codding.
I'm curious about the progress of your project. I hope you succeed. I couldn't and gave up.
Edited by Giannis20
  • 2 months later...
Cannot see any of the pics; can You please link them again? I'm doing the same on my Karoq and would be helpful
I don't know why you can't see my photos. Can the rest of the forum see them?
It's not easy for me to re-upload them in another way. If you can't see them yourself, I can email you some of them.
The pics from Giannis20 are visible to me on a Win11 computer.
Ok from mobile they're visible; however it's sad to read the retrofit era is almost finished! Which year is it Your car? from 2024 it looks like the BCM are blocked
My Octavia was manufactured in 2023
Project is Finish?
  • Sponsor
It isn’t just the BCM that’s protected by SFD2 (ie VWAGs implementation of the UNECE R155 R156 security measures)
Many modules are protected however where there’s a will, there’s a way - just not for DIYers
On octavia 2021 with sfd1 is the same problem?or this retrofit can be done
  • Sponsor
OBDeleven is sufficient to unlock SFD1, then you're free to do what you want with other tools
Kalispera gianni
ithela na se rwthso sxetika me to update pou Moore is na kaneis Kai monos soy ..
Tha moorouses na me voithiseis ama me epairnss ena thlefono h few esena giati to pas no to link alla den to vriako pas Moore Kai eve na to kanw
Efharosto ek tan proteins!!
4 hours ago, Marios13 said:
Kalispera gianni
Please post only in English.
I’m sorry I was wanted it to send it to Giannis because he is Greek and I though that it will was much better to speak like this to explain me about my problem with the screen that it cannot take any update..Skoda Octavia mk4 2020.
Hello Giannis
I wanted to ask you if you can personally somewhere in Greece about this problem to help me because I cannot find a solution..
Maybe i understand something wrong
On 17/09/2025 at 00:36, Marios13 said:
Hello Giannis
Giasou Marie.
I am sorry, i don't know anyone for that. This is the reason i gave up this project.
Why? What is your Problem?
Can i Help you?
  • Sponsor
48 minutes ago, Giannis20 said:
Giasou Marie.
Why did you give up? 🤔 It’s a simple task, your local workshop just isn’t capable of it
I couldn't register the radars to the BCM (couldn't remove the CP). So after a few tries, I gave up. My car is from a lease, so I didn't want to push it any further.
Reference to parts for sale. No selling on here unless you have Freedom or Freedom Lite membership.
Thanks,
Admin.
Why BCM? CP Master is Gateway, or Not anymore by MQB EVO?
  • Sponsor
Thanks,
Admin.
As mentioned above, the gateway is CP master, not BCM
CP removal is a simple task, I've no idea why your local specialist cannot do it. Seems silly to go through all the effort and give up at what should be the easiest part
So sad to learn you can't diy your car anymore, my car has SFD 1 and even with obdeleven I don't know if I can unlock itt and the swap to vcds to do the adaptations
The vcds I have is a clone one bought it with 40 Euros , but another 150 Euros for obdeleven just to unlock sfd once ?? It's a lot
