1.8TSI and 2.0TSI engine failures
DGW
Recommended Posts
A car I'm hoping to purchase has had this problem already, about 12k miles ago (currently on 12k).  Apparently the part failed when the engine wasn't running, but when trying to turn the engine over it had damaged inlet valves etc, which have all been replaced at the current owners expense. The newest tensioner and chain were also fitted.  Is there anything else I should check with regards to this?
I would check the paperwork to confirm who did the repair and what was replaced. I would also ask about the car's oil consumption and check to see if there are any obvious signs of blue smoke when driving it.
  • Like 1
Link to comment
Share on other sites
It wasn't Skoda as was out of warranty.  It was a garage called Autobahns in or around Hexham.  They were originally BMW specialists but have experience with VAG stuff, mainly Audi, VW and Mercedes.
http://www.autobahnhexham.co.uk/index.htm
Edited by planehazza
Link to comment
That's a google translation obviously. The "simple rule" is not to leave the car parked in gear.
what has the gearbox got to do with a mechanical tensioner that fails due to missing teeth.
Link to comment
I believe its more to do with putting strain on the engine when its not running, i.e. if the car rolls slightly, force is put back through the transmission and onto the engine which breaks the ratchet that stops the tensioner retracting when it has no oil pressure, or something along those lines anyway.
  • Like 1
Link to comment
One thing to note: that particular piece of advice was about the 1.4TSI engine. They state that its tensioner (of initial revision I suppose) does not even have a ratchet. They advised not to leave car in gear as a precaution to exclude the possibility of retraction of the tensioner due to counterclockwise engine rotation.
  • Like 1
Link to comment
Think it been written by a Member from Helsinki who's English may not be as good as yours.  No Apes involved
I would give you some serious odds on the contrary Auric;)
The two grammatical omissions and additional error in your opening salvo do not bode well! I will let you off the capitalisation though and presume you are an ardent "Planet Of" fan.
Back OT, thank f I do not leave my 1.4 TSI in gear.
Link to comment
Which is fine - but what are you supposed to do on a steep hill - just rely on the super reliable hand-brake ? You should be able to leave a car in-gear with the engine off as a backup to the handbrake, especially as they have been known to slip when the disc and pads cool.
Link to comment
Apologies, I was just having a joke, and did not realise it was written by a member who's first language was not English.
Link to comment
2009 1.8TSI, 30k miles, owned since new and will be 6yr old in July, trying to decide whether to take the plunge and have the tensioner replaced as want to keep the car for at least another 2 years.  Had a quote from local Skoda main dealer who supplied the car and has serviced it since new, £415 incl VAT and includes 2 year parts/labour warranty which seems a good price. Has anyone reported a failure after having the tensioner replaced?
Link to comment
That's a good price. Cheaper than cambelt replacement at main dealer!
  • Like 1
Link to comment
Are VW, Audi and Seat seeing these same failures on their 2 litre tsi's, does anyone know?
Of course they are. That is why they issue service bulletins, silent recalls etc - but they only give them to dealers. Of course if you are only a customer well ......
Link to comment
It isn't routinely inspected as there is no way to do this.
That is not true. As far as I have read myself into this subject, there are two possibilities:
1. Check with VCDS if measuring block 93 of the engine is between 0 and -4 degrees. Everything below -4 is considered a problem.
2. Look via the inspection hole at the chain spanner and count the number of visible teeth.
Link to comment
Still doesn't tell you anything.
Link to comment
Thats a hell of a price from a Skoda dealer, DM Keith in Hull quoted me over £1k :sweat:
Link to comment
£415 that's just a tensioner nothing else no guides and no chain. I believe
Over a grand sounds like a rip off even if it includes guides and chains
Correct, just tensioner, should I be getting chain and guides also? Do these parts also fail?
Link to comment
The chain stretches and the guides wear. The latest timing chain is less prone to stretching. If you have the funds then have the tensioner, timing chain and guides changed.
  • Like 2
Link to comment
Ouch!  To include the replacement of chain and guides, that would more than double the cost of labour, so all in £1,000. :thumbdown:
Link to comment
Turn the wheels into the kerb.
Simples as they say :-)
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
