  2. The T&c,s of the warranty on paint 3 years or corrosion 12 years dies not saying, annual, bi-annual or periodic inspections required. But Skoda Servicing details 'body inspections' as part of servicing and Skoda / VW UK knows exactly which Dealerships employees are not carrying out body inspections while doing oil and inspection services or extended scope or minor and major services as they were up to 2019/ 20.
  3. @cwt did you lift the bonnet and check that the oil filler cap was on? Had you checked the oil level and coolant level when collecting car and before leaving with it. Maybe just the drain plug not renewed or washer when serviced or plug cross threaded.
  4. Today
  5. Hi, can anyone tell me if, on a pre-wired Octavia RS Combi, I just need to plug the 5E3055202B wiring harness into the trunk? Or do I also need to run a cable through the interior of the car?
  6. Torque Pro is also very good. Can’t do the customization that Carista will allow but it does do live data logging for fault hunting
  7. Please be aware that English is the default language for the forum as it is UK based. Posting in non English language can trigger automatic content moderation. Thanks, Briskoda admin team
  8. I didn't want to start a new thread just to answer a question, but i can't find any answers on the forum. I've done the SAI delete,N249/N112 and evap system mods as outlined in the 'Skoda guides' section. I have a resistor on the N112 lead, and another for the SAI pump. I was advised to just leave the N249 plugged, to avoid misfires, etc. I get the P0411 code every few days, which I can live with, but it got me thinking. Will the car fail the MOT on emissions due to these deletes? All the info suggests having a catch can and re-routing some of the hoses is actually cleaner all round. No-one has brought up MOT's in relation to these deletes; and it seems doing the deletes is really common. Has anyone had emissions fails at MOT since doing the deletes? And how did folks get around the MOT as a result? Thanks
  9. glad I looked at this post- I'm getting my turbo looked at later this week and although the guy is a vw/ 1.8T specialist, I'd be surprised if he's aware of this difference across engine models (mine's an AUQ too and there's an oil leak on my turbo..somewhere...)
  10. Yesterday
  11. I'm not so sure about that; I think Trump has given up and is claiming victory. It would seem that the B1 Lancers currently based at Fairford are all going back home, and lots of cargo planes have been arriving to take home the support systems that is needed to keep the aircraft operational; also, a 747 has arrived or is arriving to take home loads of support. staff.
  12. nicerone joined the community
  13. OBD 11 or Carista. I don't know if VCDS Lite is still available. Or if you're looking for full compatibility then a genuine VCDS cable. And welcome to Briskoda 👋
  14. Bonjour quelqu'un peut me dire si sur Octavia RS combi precablé, je dois juste brancher le faisceau 5E3055202B dans le coffre? Ou y a t'il un câble a passer a l'intérieur de la voiture aussi ?
  15. Hi guys so recently i’ve bought myself a first car and its skoda fabia mk2 estate and i’m just here to ask for any tips like what would be the best diagnostic software to use etc… literally anything would help Thanks! Heres a pic of my car
  16. Bengares started following My first car
  17. Octavi joined the community
  18. Bengares joined the community
  19. Hello Looking for some advice or suggestions on if anyone has upgraded their radio with a touchscreen single din option while retaining the storage cubby. Options for this type of radio are limited so wondering if anyone has any suggestions. I’ll attach photos below of what iv found. Options seem to be touch screen single din’s with a small screen (which I don’t mind) or a larger flip out screen. Trying to get something that’s decent but not completely breaking the bank. Any suggestions or experience with this upgrade would be appreciated Thanks. *removed part circled red retained part circled green.
  20. The result of the Gridserve charge starting was a mystery. Dont know if there was already thd tax power being drawn or what, no explanations. If I was in the Scenic, which has a 22 KW AC capability could have gone for that but at 11 KW would not have bothered. Should gave topped up on the way up as had time abd there was a new bank of Gridserve High Powerec chargers on the Northbound just commissioned. Also should have gone over to the TESLA chargers which have the highest reliability rating. Not sure if they have a TESLA Mega pack on site to avoid power supply issues. Renault have announced new R5 abd Scenic versions today and versions have more range. Also LFP versions which will have lower costs but fast charging. The 5 and Scenic both will need there cheap servicing in the next month or two so will ask the sales team about upgrading which should reduce or negate thd need to public charge in future so I will only home or destination charge. Lad talked about his Electric Forecourt experience which sounded great. Place has 4 8 stars on Google. I found charging cheap on the continent. With the larger European countries adding about 2k chargers per month competition wil intensify though a European wide shortage of electricity, but also gas and oil, all linked, a bit of planning a good thing. Octaverse card works at a high percentage of the 1M chargers across Europe. My problems were largely solvable by my better actions. What charge i did get at Sabdbach was less than £8 and then I charged up on free lecky at home yesterday ie the bank holiday where it hovered at minus 1p per KWh in the middle of the day. Cannot imagine going back to ICE as EVs getting better abd better as us the public charging network where ICE running costs look like they will be staying high with the Iran US rumbling on indefinitely.
  21. almeucuata joined the community
  22. @lol-lol Wow, it's good to see an honest report on the various charging problems one can run into through no fault of their own. I've got so used to hearing from so many on here that range anxiety and chargers being in use, faulty, etc. are nothing short of hogwash, since they claim it never happens and that proper planning prevents it anyway.🙄 Come to think about it, I think the only other person who has been honest about problems with chargers is @Evolution13 . Did you see the report written by Will Stapley of Which magazine where he recently took an EV on a 2-week, 1,500-mile trip to Italy and back again, and he had to have 19 charging stops on that trip at £285.77, and the total time spent charging was a staggering 14 hours and 38 minutes? Phew. Now the cost is almost on a par with my diesel Kodiaq, which on a decent run averages around 540-560 miles on a tank, so that would only require 3 refuelling sessions (being generous, 10 minutes a time), 30 minutes in total. What I learnt driving an electric car 1,500 miles across Europe - Which?
  23. Bugger, was the oil warning light showing on the drive home?
  24. I looked into that too. With the age of these units the battery backup cells would be fairly depleted and breakers are unlikely to check the health of the internal cell. I've done a siren battery replacement in an Audi and in the end felt it was not really worth it, time and costs considered.
  25. No but sometimes simple things cause big problems cheers
  26. You can probably pick up a replacement alarm horn very cheaply on the secondhand market. Much easier to just change that than start from scratch. Car alarms are almost useless anyway, immobiliser does the work these days.
  27. It did have; unfortunately it was unreliable and I suspect a previous owner/garage may have messed with it - siren looks battered. I just want to fit a new system for reliability.
  28. Doesn't it already have a factory fitted alarm?
  29. You don't have ECO mode selected by any chance do you?
  30. Ohhhh - so essentially vibration was disappearing when haldex disengaged - once you’re up and moving the car is basically front wheel drive. Makes a lot of sense. You’re right though it should be every 2 years and clean the gauze on the end of the pump as well as change the oil. It isn’t in the dealer workshop manual but all decent independents know to do it (although always worth asking just to check). Anyway, glad all is sorted!
  31. No warning lights or codes on garage’s diagnostic
  32. Hi All, I was wondering if any knowledgeable folks out there have any wiring information and connection locations to install an aftermarket car alarm? I have a 2012 Fabia 1.2 TSi. Many thanks, M
