  2. I agree with battery check as well as earths etc. Anything under 12.2V may be too low as during cranking can drop below threshold for electronics. It could be a completely dead ABS sensor or broken wires to one. If the ECU detects no connection it may ping up those errors. If the battery is good and earths are good I would get it scanned with vcds to see if it can pick up something the garage scanners cant. Also check the brake light is working. Alasdair
  3. In the end I went for Audio-Technica M50xBT. they were well reviews and he didn’t need the noise reduction. He's happy with them so that's a win. Got them as returns on Amazon warehouse for a bit of a discount. they were missing a cable but they coughed for a replacement.
  4. Lucky he doesn’t have warning stickers on the back of his van. Sorry for the sh*tshiw @Stunts - hopefully you get something and back on the road quickly
  5. Mine in December of the same year (31st, missed out on being 2021 registered by one day lol)
  6. Just a thought, it could be the GPF regeneration. It happened to me after several days of slowish journeys. I even called the RAC out thinking there was a fuel leak. Never happened again.
  7. Thanks for the explanation
  8. Tell replied to RodDuggan's topic in Skoda Karoq
    Yes. The portal ones are for people who choose not to subscribe to online map updates and are free twice a year. Traditional for Skoda and VW. The online connected services ones are monthly. You got the October one there 26.10. It would be a down grade if you managed to get that June one installed. It wont let you downgrade. People do periodically loose the ability to get the over the air in car updates for whatever reason. Outside Europe connect service are not rolled out so like the old days map updates can only be done via USB if the car is enabled for them. Another story. In the current economic climate some people discontinue their connect services contract but with the app integration of all things between phone and car, penny pinching they loose the ability to do those extra things remotely like turn on the heating in an EV etc. Firmware updates are distributed free whether you have a connected service contract or not but you must be logged into the car as the primary user for that to take place. Then it informs you that there is one to install.
  9. Today
  10. So I have the latest update even before the one on the Skoda portal?
  11. I've tried to second-guess myself on the driving style, trying to fit the available data into a theory, but it's very much guesswork, and it doesn't explain the HUGE variation in MPG, given a very similar route driven at a similar pace, traffic permitting. (I'm just driving too and from work, after all.)
  12. Hi 2006 Fabia vRS Had the master cylinder replaced a couple of weeks ago. Brakes much improved. However, a couple of times since the brakes have stuck on. Apply brakes for example on approach to roundabout. Go to accelerate away from roundabout and car is held back. When you take your foot off the accelerator it feels like the brakes are on. Pulled over when safe and you could smell hot brakes. All 4 wheels were hot so brakes definitely sticking. Turned off, waited a few minutes then all ok again. It's happened 3 times now. Car going back to garage tomorrow but mechanic has said he's not come across this before. We've used same garage for several years now. Any ideas? Mark
  13. Thanks, much appreciated.
  14. Hi everyone hoping to get some help with my mib unit I am having issues connecting to android auto On MST2_EU_SK_ZR_P0245T 5Q0035874A I have tried everything I'm aware of so far and now I'm thinking it's got to be a software/firmware issue. I've tried several different OEM cables and 5 different phones (iPhones and Android) I have replaced the usb port with " 5Q0 035 726 E " aswell as a new HSD cable from the head unit in the glovebox to the back of the USB I have also tried 3 different byte 19 codes and checked that android auto and is enabled in 5F module the usb has been set to "full" but after all of that I still cannot get any to be recognised it seems like the usb just isn't sending data I haven't had the car very long maby a month but I have yet to get smartlink to work Bluetooth seems ok however it does drop out from time to time and is around 15/20 seconds delayed I would really like to get Android auto working as I do a lot of motorway miles and I like being able to easily change music to podcasts ect.. if anyone can help or possibly point me in some other direction I would massively appreciate it 🙏
  15. hi im new im hoping i have said hello in the correct section if im wrong can you let me no were to do it thanks jimmy
  16. hiim jimmy im a newbie if im in the wrong place to say can someone point me in the correct direction thanks
  17. Lily101210 started following hi im jimmy
  18. Lily101210 joined the community
  19. My 2008 fabia was fitted with a single mass flywheel. I was shocked when they looked up my reg and told me it was a solid flywheel. Had the clutch replaced first time and no issues, now for my second clutch and I'm getting bad vibrations when taking off in first gear or when I reverse. Now the clutch was replaced it's looking like I need to replace the flywheel. Will this fix the problem or not big? Do i replace it with a dual mass or stick with the single mass. All comes down to money. Anyone Else have this issue. Thanks.
  20. Walter123 started following Strange discovery
  21. HBH96 joined the community
  22. Yesterday
  23. Not a confirmed fix, but when only one door handle misbehaves on KESSY it's usually worth looking at that door's handle sensor/antenna and its connector (water ingress is a common cause) rather than the key. A garage with VCDS/ODIS can check the KESSY antennas for faults on that side. Fresh key batteries are already a good first step, so I'd focus on the door side.
  24. Thanks - the update installed OK but did not solve the problem - still no villages. What is the very latest firmware - I understand 0253 was the last 'official' update.
  25. Thanks. Autodoc where way out so it looks like I'll have to get the OEM units. It looks like my reference is Gas strut: 3V582755201S Dimensions: 634mm x 145mm
  26. Hi. Not sure if it was my original thread re Autodoc and their misleading Superb struts. My Superb is a 2020 1.5tsi hatchback petrol. I got my struts from SkodaParts.com with part reference 3V5 827 552. Cost about 68 Euros each + 9.50 Euros delivery. Came in about 5 or 6 days. https://www.skoda-parts.com/spare-part/3v5827552-gas-spring-for-the-trunk-lid-sedan-skoda-45985.html Hope that is of some help
  27. bjpb joined the community
  28. Don't be surprised if it squirts quite high.
  29. Hi All. New to this site as ive recently sold My T5 transporter and purchased a 2016 superb L&K estate. So far very happy with it.
  30. Skiprat77 joined the community
  31. Yes, this is still confusing me. I would expect some residual oil if it "drained away". Normally oil is difficult to disperse, but this sensor was totally dry. It led me to think it isn't operated directly by oil at all, but by a plunger inside the head. I've thought some more about this since my last post, and I think it's worth doing as above suggestion, i.e. unscrewing it and running the engine - at the weekend, I'm busy working until then ... Luckily I can use a different car.
  32. Normaly No Key.. https://mega.nz/file/A3kVnRrb#5USQHMiRRmq3dhy1cjEvacw4y6GoXxRMGnsVhhOIhAw
