Photography Thread
New lens arrived today, wide angle zoom, 14-35mm couldn’t resist giving it a go. Took a few more snaps for a small photography project.
Fog light comes on with headlamps + missing bumper cover
On the facelift cars, the foglight is actually two different lamps - a foglight and the daylight driving lights in the same enclosure. It seems that drivers of many older makes of cars, not just VAG, have the foglights rewired to come on with the ignition to make them look modern. This is maybe what has happened to your car. The law says that the driving lights must be OFF when the headlights are on and so it may be a MOT failure if your fog/sudeo driving lights are on.
- Skoda UK Customer Support are useless!
Stonekeeper started following Skoda UK Customer Support are useless!
Got the call from the dealer today to say my new car has arrived at the dealership. 7 days from order to delivery! I had to wait 7 months for the Superb. A benefit of zero factory fitted options. It will no doubt have been sitting in a uk port for a while, Civics are built in Japan. I’ve booked it in at a professional detailers for a “new car” treatment. I’m going on holiday at the weekend so I’ll be collecting the car when I get back in a couple of weeks time. Thanks for all the help and advice over the last 18 mths guys 👍🏼
Automatic headlight adjustment for driving in mainland Europe
Thanks so much, I’ll give it a go.
Rear 12V socket removal
It wasn’t damaged when they first had the car when they had to take everything off etc but for some reason was this time when replacing things properly which they should of done previously. I don’t have an issue with Service Dept as it’s not them doing the work but the workshop are more like monkeys with a hammer
How odd. So it wasn’t damaged when the armrest was repaired?! There would have been no reason for them to be anywhere near it in that case! We bought out kodiaq and Fabia from underwoods in Colchester and they were brilliant. That branch closed so we then went to bristos in Ipswich for the final services on the deal and they were awful. Cars were left dirty, and I always felt there was an upsell. Real dodgy car garage feel about them. It’s a shame that has jaded your impression of the brand.
This I understand and get even with the following the same routes of the OEM routes. This was mentioned over the phone when being told that everything had been done and they couldn’t get these sockets working again, so I said yes I had them installed and you need to push the button to turn on the usb charge unit. But what I don’t get is the damage not the missing fuse, with the former being done previously to start this whole mess and it working after collecting the car but not after 48 hours of the car being there this week. I have phoned the service department and explained, you could tell he was oh for Christ sale not again and has said did I want them to do the repairs or for them to order the parts, I have said I will do the repairs Had a lovely loaner and being new you are like yes I like Skoda and then their workshop does this and you think nope no more Skodas!
fandy joined the community
Skoda Octavia Kombi 2021 - Travel Assist + Front Assist + (...) - Failures - Suspected Steering Wheel Issue
Trunk Lid electrical opening over the key or the button inside the car - it beeps looks like faulty sensor in the one of the eletric struns suggesting to change in 6D ,module to use only one sensor USB C Output in the back suggesting to retrofit from facelift version more power from 15w to 45w
Manatee32 joined the community
The usb socket is separate from the front cigarette lighter. I can understand them pulling wires by accident due to it being non OEM fitting, they wouldn’t know how they’re routed etc. and you would have to disconnect some of these parts to get to change the arm rest as they have done. But to pull the fuse because it’s blown and not mention it is unacceptable. At pick up they should have said “very sorry sir but when dismantling we pulled some wires we didn’t realise were there. This blew the fuse in slot 40. Here is a 20A fuse to replace it but you will need to repair your wires first. Please let us know if you incur any cost and we will reimburse you” I suspect potentially a junior tech cocked up and tried to hide it. Might be worth mentioning it to them as they may well not know!
Binx1310 started following Rear 12V socket removal
Kodiaq Seven seater and space saver spare wheel ?
A small update on this. I visited a dealer today and had a really long look around a new unregistered Sportline seven seater. I lifted the boot floor and it had properly mounted space saver tyre. It therefore appears that the configurator may be accurate as it allows the purchaser to select the space saver on a seven seater and the brochure is probably wrong when it says that we cannot have one. 😕 Anyway, with the seven seater SEL I ordered, I opted for the space saver, so we’ll see what arrives. 👍🫰
Expansion tank contains silica? Skoda Fabia 2018
I think that what happened was, VW Group or their coolant supplier BASF, became a bit more environmentally aware and so "greened" the coolant and so G12++ became G13, some time after this, VW Group or BASF became aware that for some engine version uses or at least the typical working temperature was causing enough silicate to get depleted to cause concerns. This was addressed by "sort of" providing silicate pouches for some model/engine combinations - so some models/engines were sent out with the "Mit Silicate" reservoirs while at the same production/sales periods, some cars were sent out without these pouches in the reservoirs. While my wife's 2015 VW Polo 1.2TSI 110PS - factory filled with G13 aged, it was sent out without a silicate pouch in the reservoir, the ph level in the coolant changed quite quickly - compared with my older daughter's 2019 SEAT Leon Cupra - factory filled with G13, which has a "Mit Silikat" reservoir - so these pouches do seem to do what they need to. I think that VW Group was gaining info about this G13 as time went on, and if they had had enough info on G13 in the 1.2TSI 16V engines, that 2015 VW Polo 1.2TSI 110PS would have been sent out from the factory complete with a "Mit Silikat" reservoir!
How To: OCC DIY Guide Install
Just finished. Car starts and goes/brakes but haven't tried it properly yet. I'm worn out! Will update on the issues later, need a wash first! Thanks to all the heads on this forum who provided the 'how-to's'...esp. Bowders. Main problem was hopeless jubilee clips and the damn 19mm hose being too chunky to bend, etc. And the spring retaining clip on the manifold 90degree section. Talk about ripped up hands....who designed that was one evil guy. The one-use hose clips were another nightmare; I expect I've punctured some other hoses but I'll find out in a bit. I left the N249 plugged in, on the advice of someone who knows this stuff. Resistor on the N122 line. Air pump still in the engine, but redundant- gave up trying to get it out. No error codes...yet
Open the shop application from the main menu. Wait for it to load & then click the settings icon (bottom right). At the last screen click information... It displays the shop application version
Satnav migration between cars ?
I am about to change cars from a 2019 Superb Business edition to a new Kodiaq. I have dozens and dozens of destinations in the Superb satnav that I will need in the Kodiaq. Is there any way that they can be migrated between cars to save me having to add them all manually to the new car which would likely take me about a day to do. The internet suggests its not possible, due to the Kodiaq using a different kind of satnav technology for its operating system and memory, but I was wondering if anyone has come up with a non-too techie way to do this?
Pesmog started following Satnav migration between cars ?
Thanks! How / where can you see this updates references?
Skoda Karoq Ambient Lights
As far as I can see, in the linked post there's everything I need to make them work/replace
As Lee has mentioned it's a cover for the pop-up headlamp washer. If you have problems finding one let me know as I have a complete bumper with washer covers in your grey - no longer any use to me as I have a Scout (different bumper).
Octavia vRS Limited Edition WRC
Richardos started following Octavia vRS Limited Edition WRC
the truth about electric cars
@lol-lol, this bit of news will please you.
Fuse Box Under Bonnet Help
Hi All Need a favor please, today I was mucking about planning an audio upgrade and I took a look in the fuse box that sits to the right of the battery under the bonnet. There appears to be what looks like an 80A fuse to the left of the box. It seems to be missing a nut on the 10mm threaded post. Would some kind soul please take a look in there fuse box and confirm?
Tankdave started following Fuse Box Under Bonnet Help
Geo04 joined the community
Activating SmartLink on Swing 3
Victory! After replacing the USB port and wiring harness and ereasing the error. Huge thanks to @Zlatko580 for this guide and the additional help. Also thanks to @bigwhale42 for the Linux guide. I used WSL and had some pretty good fun... ...although playing with clamp was quite stressful for me :) Thanks again!
Mine are white and I can only change the intensity of them. The reason that you see them colored on your MIB is due to a faulty coding. To make sure that your footwell lights are RGB, check the wires that plug into them. If you have 3 wires, then the lights are RGB, otherwise(2 wires) they are monochrome. Further infos can be found here https://www.drive2.ru/l/591707406241650380/
The front USB/Apple car play was working not these ones Ahh I had read it was a 30amp fuse, have a 20amp so will swap that then
I'd start by checking the wiring. Previous owner may have wired the fogs to come on with the headlights. You're probably aware it's an MoT failure if fitted and not functioning. Missing cap if for the headlight washer jet. They should activate every fifth use of the screen wash if memory serves. I'd try eBay or a local breakers yard. I think they're push/ clip fit.
