  2. depesz joined the community
  3. Asinrin joined the community
  4. Thank you for your replies! I have already taken the car to a mechanic for an initial inspection. We checked the brake/clutch fluid reservoir while pressing the clutch pedal. There was no noticeable movement of the fluid, and we couldn't find any visible external leaks. The clutch pedal also maintained normal resistance when pressed repeatedly and held down for approximately 60 seconds. However, the problem still occurs intermittently while driving. Could the clutch master cylinder be failing internally, even without any visible fluid leaks? Has anyone experienced this and managed to identify the exact cause? Thanks again for your help!
  5. Do you have an hatch or estate?
  6. Fryderyk joined the community
  7. Today
  8. Yes, I experience that too, but very rarely and intermittently. Try pumping the clutch pedal? Keep us posted. Mine is same model as yours.
  9. Likely to be a failing master or slave cylinder.
  10. 2014 Octavia 3 - 1.6l diesel greenline Pls help with an odd thing earlier today - I'm on the motorway and when I was in traffic it gets hard to select gears (harder for 1-4, easier for 5-6). By the time I've left the motorway and pulled over I can no longer select 1st and it's really hard to select the others. Once I turn off the engine all gears are somewhat ok again. To me this suggests the clutch was not fully disengaging? The brake fluid reservoir was full to max. I left the car for half an hour or so and when I came back, everything was back to normal. All gears are working smoothly and just fine and was fine like this for the rest of the day. The brake fluid reservoir looks to be at the same full level. This is the second time this has happened in about six months. It's almost like the hydraulic system depressurised after sat on the motorway for a while with no gear changes. But how come now it seems to be ok? What's likely to be failing soon?
  11. shirl joined the community
  12. @Alvin600 I can attempt to look up which parts are involved, using your VIN to make sure that only parts fitted to your specific car will be listed. I'll message you privately, so that you can supply the VIN to me. You're too new to start such a conversation, but you will be able to reply to my message.
  13. Hi, I’ve had a bit of a result with this today. I got in the engine bay and as Papez diagram shows it was there behind the intake, two tiny screws and it was out. What I found was the one contact was touching so with a blast of electrical cleaner and a light flick up and separate the blower now works as it should. RESULT 🎉🥳🥂🥂
  14. lbl1995 joined the community
  15. The current battery is 70ah. Standard fit is 60ah. I’ve seen a Yuasa 65ah at a good price and a recommended fit so I have that one at the top of my list. The current battery is over 7 years old having been fitted under warranty. I do really the dealer saying the battery is bigger but I can’t remember the details.
  16. Ssnak001 joined the community
  17. Its brand new car, just bought it. The goal is to keep it as long as possible, same to the 2018 Fabia. I use it mostly for driving to work only 30km motorway driving and 1-2 long trips per year (more than 500km motorway), I use the other Fabia for rest. I was thinking to do the first one in 5000km and then every 8000km (or 12 months if a year the car does not reach the 8000km), exactly same pattern to my 2018 Fabia. That's a good strategy, so the first oil/oil filter change in sub 1100 miles (1800km) on both of your cars, and then 7000miles (11 000km) or 12 months, whichever comes first!
  18. Thanks, DerekU, for your prompt reply and confirmation that the Fabia has active shutters.
  19. Provided it physically fits, fitting a larger capacity battery is not an issue as long as the vehicles BMS is adapted (coded) with the replacement batteries data.
  20. I can understand there being different sized centre displays as happens with many different cars but it's puzzling having different sized driver's displays. Can't see the point?
  21. I think the part's code is 6U0959263A (blower motor resistor) and 6Q0959263A (fan-heat resistance).
  22. As far as I'm aware, all Skoda Fabia Mk4 cars (irrespective of age) SHOULD have adaptive cooling shutters. They were referred to in this February 2021 Skoda Storyboard relating to the then-new Fabia https://www.skoda-storyboard.com/en/press-kits/skoda-fabia-covered-drive-press-kit/aerodynamics-innovations-increase-efficiency/ and the information provided reads as follows: Cooling shutters save up to 0.2 l of fuel per 100 km at 120 km/hThe addition of a new type of cooling shutter has been an important measure. These shutters are actively adjustable slats in the front bumper’s lower air intake. When there is little need for cooling, they close automatically, thereby improving the car’s aerodynamics. This results in fuel savings of up to 0.2 l per 100 km when travelling at a constant speed of 120 km/h. To allow for a high level of cooling or to accommodate short stops, the system opens the shutters so that the maximum amount of air can flow in. Also mentioned in this October 2021 Skoda Fabia link https://www.skoda.co.uk/news/details/skoda-fabia-setting-benchmark-in-its-segment Cooling shutters improve fuel consumption ŠKODA has installed cooling shutters in the front bumper’s lower air inlet – the first time this technology has been used in this vehicle segment. To improve aerodynamics, actively adjustable slats automatically close when there is little need for cooling. To allow for a high level of cooling or to accommodate short stops, the system opens the shutters so the maximum amount of air can flow in. To further reduce drag, a larger roof spoiler and side finlets optimise the airflow at the rear. At the front, the air is guided through vents in the bumper, known as Air Curtains, in a particularly aerodynamic manner close to the side of the body and the wheels. Twelve panels now cover a larger part of the underbody instead of three, especially in the areas that are crucial for aerodynamics, such as the engine bay and the axles. (I don't know exactly where they are or how they operate - there's nothing obvious I can see when I look through the bottom and top radiator grilles.)
  23. MrPete joined the community
  24. Time to reach out for insiration and insight as we are looking to change our much loved 2012 CFGB 4x4 for a 2019 car hopefully as an upgrade. The only thing I can well do without is a pan roof but only due to the potential for water ingress, so advice from this Mk 3 forum would be appreciated. I have my eye on a diesel L&K 4x4 wagon with a decent spec inc heated/cooled seats, heated rear seats, heated steering wheel, surround camera, virtual dash, Canton sound, Apple car play, electric tailgate, blind spot assist, side assist etc etc. I would prefer another diesel but do like the idea of the powerful TSi, especially after Rick from RE performance did some tweeks on the green one, but I'm too old to play like that these days and the mpg looks to be a shocker in comparison however. All maintenance is done by myself, mine has been fairly trouble free and is way better than my previous 2005 petrol A6 Allroad 2.7 Bi Turbo which was a proper money pit in comparison, but fun to drive. One car caught my eye today online, but not sure on the colour, mind you the car I have now was bought for all the goodies it had fitted and certainly not the colour! I can live with it as I dont see it from the inside. DSG is on the radar for the first time too, my works VW Transporter has a DSG box, touch wood, seems to be reliable so far, but at only 40,000 miles and a two years old, not much to go on re lonevity. Thoughts and horror stories alike most welcome from you real world owners to illustrate what I am getting into. The Biturbo Passat was considered and dismissed fairly quickly due to lack of toys in comparison to the Superb and how much of a swine it is to work on should the low pressure hair dryer fail......
  25. If you have a Nextbase dashcam you can get an OBD to Dashcam cable for between £19-25, this is for: Nextbase Series 2 models including the 122, 222, 222G, 222X, 222XR, 322GW, 422GW, 522GW, and 622GW (as well as legacy Series 1 and other listed variants like the 320XR, 380GW, and DuoHD) either direct from Nextbase or Amazon. If you have other cameras you can get similar cables from AliExpress & Temu for less than £10, you may want to add a OBD splitter adaptor if you do a lot of OBD port work. https://www.amazon.co.uk/s?k=nextbase+obd+power+cable&crid=V1ZR1DDGD57K&sprefix=nextbase+o%2Caps%2C134&ref=nb_sb_ss_mvt-t11-ranker_1_10
  26. In the mean time and in between time can anyone or does anyone know how I might be able to find the manual ECU kit for my car, namely computer, instrument cluster and key barrel please Thanks in advance
  27. Sorry did I forget to mention that at this very moment i bought a manual computer from someone here at home who purchased it from somewhere in Europe for his fabia even though his ECU was not the problem and when the technician attempted to code it ( for my car) by changing the values/code, think it was 00071 or 73 it changed back, by the way it's a magneti marelli, heard from more than one person that this particular brand is not the friendliest They preference is Siemens or Bosch which some fabias came with mind you, mine unfortunately did not
  28. greenbogey joined the community
  29. Although you can only change between D and S (and manual, of course), as the coasting and such is part of the Eco setting for the whole car. I drive long journeys in eco sometimes, although my car has the coasting mapped out.
  30. OccyVRS started following DSG arrow
  31. Hello there sir, thanks for reaching out and offering help, I'll pursue the link see what happens and send subsequent info to my technician in addition, my concerns are that the car dies not want to climb small inclines, much less hills, also since my car is the 74 kw version I'm uncertain regarding whether or not this Auto ECU came from a 74kw fabia the fact that it's searching for the TCM (transmission control module) on scan tool says a lot about my current issues despite immobilizer data having been copied, but for a certainty I'll check the link you shared, see where it leads and share results Thanks a million Alasdair1👍
  32. I’m guessing you plan to keep the car for many years, so make sure the service interval is set to Fixed so oil and filter changes are every 12 months or 10,000 miles. Nothing to stop you doing oil and filter changes more often though. I bought my 2023 Karoq (in April 2024) with 1,080 miles recorded, selling dealer included an oil and filter service as part of the presales prep. When I bought our 2015 Fabia in 2016 900 recorded miles and 1 year old, from a car supermarket so no pre sales prep, I had my local independent do and oil and filter change immediately. Karoq does around 7000 miles a year and the Fabia around 2000 miles a year both have annual services though.
  33. Hi I have also been looking for software to fix the carplay crackling issues in my 2019 Skoda Fabia. I think this is the right place to ask can anyone help?
  34. Cfleetwood joined the community
  35. GrandadStuart joined the community
  36. I've been all round the houses on this even comparing an older Golf V system that has ABS indirect speed based TPMS enabled and working. I've reached a few conclusions.: for TPMS there has to be comms to the Instrument controller. The yellow icon is present and can be lit. The Golf V has no active controllers in the gateway list for TPMS, neither does it have the adaption options which Yeti ABS module 03 has. Yeti has two options for adding controllers to the gateway list, activating either brings on the dash icon but scan then errors because it finds no supporting module. I've concluded our Yeti only responds to coding for Skoda INTERNAL TPMS sensors with a Skoda TPMS controller? Older cars like the Golf V were hard programmed for basic indirect ABS based TPMS with integrated hardware before internal sensors were available, which would explain why there are no TPMS gateway modules or ABS adaptation settings? I've now decided to add a cheap aftermarket TPMS, which is a shame because their sensor battery life will need monitoring. If I was marketing the 2012 Yeti with optional TPMS addons, why would I enable a basic ABS system and add the panel switch which buyers might be happy with? Good thing regulators have now made TPMS a mandatory car safety feature. I'll keep an open mind just in case somebody here has another answer?
  37. I've posted about this in two threads (look up breakdowns) but it is still being raised. Do not ignore the situation or accept a dealerships insistence that there's no fault showing so nothing to be fixed. Our 2023 Fabia mc had this issue and we got nowhere with getting it sorted despite it being likely to result in a fatal accident. The local dealer has a service department which they said is state of the art and has a full team of Skoda certified staff, but I never saw it. Customers are corralled in a comfortable seating area. I suspect their tech staff are fine carrying out a service where they follow a checklist but if you complain about an issue and no fault shows they are not really interested or trained to handle the situation in a customer friendly way. The first time the car was taken to the dealer the AA had cleared the fault which means the car retains no trace of the problem. Despite the AA saying that it was throttle body related which was backed up by a photo of what showed on their equipment the service manager said the car should have been taken to the dealership on a low loader with the fault showing because the dealerships electronic equipment was not compatible with that of the AA. I’ll give Johnson's Skoda's service manager credit for having the car in later on and trying but failing to get to the bottom of the matter. He was very upset because the dealership lost money over this. Skoda won’t pay the dealership for work in such a situation. They might even have insisted we pay for this farce but fortunately that didn’t happen. The only way we got through this was through the AA breakdown service when the issue occurred. By then, we’d learned about the AA “silver service” vans. These are manned by experienced staff fully trained for VAG group vehicles like Skodas who have all the necessary software on laptops. I’d go for this option even if you have to sign up for the AA to get a silver service vehicles to attend. The van – yes it was silver coloured - came to the house after the wife limped home in the Fabia at about 12mph. It turned out that a software update came out in summer 2024 specifically to fix this issue on our model. He knew from the off what the problem was and took half an hour to update the car. He said the problem would not recur. The Skoda dealer’s service department knew nothing about the update. Battery levels are not the cause because we replaced ours before the last limp breakdown and the technician said it was unconnected. I’m horrified that Skoda and dealerships are still getting away with the no fault so no fix strategy. It ruined the enjoyment of the car for us and because we are quite old, we began to think it must be us doing something wrong. It has been a very unsettling situation. I am not optimistic about you getting this sorted by Skoda without raising a huge fuss and being prepared to take legal action. A comprehensive list of available engine management software updates for Skoda cars would be a valuable resource for Skoda owners. Dealerships like the one we bought our new car from could use it for such situations too, because they are not up to speed or confidence inspiring. Good luck.
