  2. GeoMag replied to GeoMag's topic in Škoda Citigo
    Thank you! Much appreciated.👍
  3. Lee01 replied to G@J's topic in Skoda Karoq
    As far as I'm aware they're powder coated first then a diamond cutting tool shaves off thin layers to reveal a shiny part.
  4. G@J started following Hello from Lincoln.
  5. G@J posted a topic in Skoda Karoq
    Hello,I’ve just purchased a 24 Škoda Karoq sportline,my question please is,are they supposed to be painted or diamond cut .thank you.
  6. I have a 2025 diesel Kodiaq Mk ll. I have never had a dashcam in any of my cars but thinking of getting a front facing one. Any recommendations of make and model would be welcome. Thanks.
  7. Onyir started following Dashcam
  8. Is there a new firmware availabl for the skoda kodiaq? Device Part number: 565035864 Hardware: H41 Software: 0480 Thanks Andreas
  9. Yep, 2 round rubber covers, one about 3 inches across and 2 inches.
  10. Today
  11. I would have said 500-1000rpm was pretty fast for just cranking. Wonder if the crank or cam position sensor has failed. Reckon a scan with vcds or similar might be in order. The brake manoeuvring unavailable may be down to the long cranking and voltage drop. As said see if there are any fault codes stored. Alasdair
  12. Hi, @pab567 can you also PM the link to MST2_EU_SK_ZR_P0480T please? Looking to upgrade from MST2_EU_SK_ZR_P0468T Cheers,
  13. Hi, I bought my first Skoda and signed up here on Briskoda back in 2009. I was so impressed with the car I moved to the Czech Republic (ok not real reason 🙂 ) Now back in ownership with a Mk3 Octavia RS tdi.
  14. They're different beasts; Superb is larger MQB-B chassis; longer and heavier. The car isn't a hot hatch and is a Passat equivalent so better at motorway munching with much better interior space. Whiteline rear arb is good - hopefully on the stiffest setting. I found although the droplinks weren't necessary, you can notice the firmer bushes based in uprated ones.
  15. I don’t NEED a sports car, but i’m so glad I have my 1979 MG Midget, the antidote to modern all-singing all-dancing cars… 😎
  16. So I tried to start my 2.0TDI crmb engine this morning and I had crank with some spluttering but no start. I've had this a few weeks ago but after a few cranks got it going, but today no luck. It's cranking between 500-1000rpm, glow plug light is off and after failing to crank i getting brake manoeuvring unavailable. I have a new battery replaced on Thursday and coded correctly, tested it and it was showing at 12.4v. Any ideas on what it might be? Anything to test?
  17. GeoMag replied to GeoMag's topic in Škoda Citigo
    I have had a look. Sorry, but what do you mean by the rear of the unit? Are the rubber covers where you change the bulbs?
  18. G@J joined the community
  19. You won't get any action from the dealer, they'll deny knowledge of a problem. Report it as a safety issue to the DVSA as I suggested above
  20. Good morning all - I promise I have tried but I am loosing the will to live with the search as it is such a common string - The problem is I am trying to research going for a wider tyre on our car with a wider wheel but same size (18) We have the standard alloys at present on our estate - these are 18x7.5 I think - the standard 18's that come on a 2014 VRS estate - they come with a 225/40/18. The car is presently in having some serious maintenance done so not seen it for good few weeks... new subframe rear, B12 Kit, new Turbo, DMF, Clutch and we have owned this car from almost new and the wife loves it... Can't really fault it or the 120+ K she has done in it but.... Wheels.... We are considering a set of the old Ronal A8 18's - What I am after is anyone that has run a 235 width on the mk3.. I hoping going for a 235 would give her a little protection from curbs as the same alloys I have seen with 225 seem a little stretched to me and I think she'd be gutted first time she curbed them with any stretch... Will 235's catch the inner arch/strut is my concern? I suspect rears be fine but looking for any experience with 235's on the mk3.. I am presuming everything else will clear as the Ronal's an very similar to present setup but offset I think will push the wheels out a tad and with the small drop from the Eibach setup but I did not think this would be an issue.... things that concern we are arch scrub loaded up or inner arch liner/interferance... 235 V stretch 225 - We already have the 225's on standard rims but can't help thinking the stretch will catch her out is all.... prob over thinking it but never seen an Mk3 running the old school Ronal's which makes me thing there are issues but these are 18.8x5 112x5 Et 45 - the original fat fives as I know them. Anyone any advise, experience or know anyone that runs these on anything in the VAG MQB range and can feedback around interference or work needed.. Have a good, Bobby
  21. No such issues with mine. All seems to work fine
  22. GeoMag replied to GeoMag's topic in Škoda Citigo
    That's great advice, thanks. I will take a look.
  23. To me this sound more of a phone issue then the car, is google maps and the phone OS up to date, am guessing that you are using wireless are the moment, have you tested it using a usb cable, as that would rule out any wireless interference issue. My guess would be if its suddleing stopped working, is the phone had done an app update that has a bug in it and causing something on the phone to crash, what modal phone are you using.
  24. skomaz replied to GeoMag's topic in Škoda Citigo
    I second the above - my daughters suffered similar misting of the nearside unit on a 2017. I found run off from the bonnet was falling straight on to the indicator bulb holder so used some silicon grease on that to prevent ingress there, ran PTFE tape over the top of the headlight at the joint between the 'glass' and rear section and also used some duck tape to direct water run off from the bonnet away from the indicator bulb holder. No more problems since.
  25. Flo96 joined the community
  26. Hi pab567 Could you send me the link for the 0369 please? Cheers Dale
  27. The seal along the join between front and rear of unit has probably failed. It did on one of mine so I ran a bead of clear sealant along the join and ran my finger along to smooth it out. Job done. However it may not be needed. On the rear of the unit there are 2 rubber covers. Pop them off, leave it for a few hours and it will clear itself. That may sort it or you can use a hair drier blowing through the openings which will speed things up. Have a look at the rubber covers as they may be damaged or not sitting around the opening properly.
  28. I do too, they have a weird side effect that the electrics don't shut down properly when you switch the ignition off if any of the other interior lights are turned on!
  29. fffffff32 joined the community
  30. I just asked for a diagnostic for this intermittent cut out at traffic lights and slow revs but was told they want £150 pounds to check it the car is still under warranty and has had this fault from new they originally tested it and said no fault found.
  31. Are this covers aftermarket good? Febi?
