  2. I used compare the market and you have options to list all the things so then you only get quotes from insurance companies that will cover. Mine is with Hastings and just had to take about 10 photos from all angles. I suspect it now means that any tiny cosmetic change will void insurance and require a £20 admin fee to update as they have photographic evidence! I think it probably helps that I’m not a 17 year old liability with a modified car!
  3. 2 things to bear in mind: They weigh a ton Whilst they do look natural, they sit beautifully proud of tyres inviting the most exquisite of lovetaps with any and every kerb. My advice, get something that is a little lighter and also that sits flat or dishes in slightly. Also not a fan of diamond-cut given its propensity to give up the ghost so easily.
  4. I declared my stage 1 Revo ECU remap (+80bhp) to my insurance company a few years ago & have changed insurer since then a couple of times. No increase. Having said that some insurance company's won't touch anything that's modified these days so best to check before diving in only to find out bad news later on.
  5. Have a browse on instagram. Lots of inspiration… for example https://www.instagram.com/superb_vrs3?srtk=dWZic3NjbmVpYTJr https://www.instagram.com/mk3_superb_grey?dlrf=MWxhbHViejR4MWsxMQ== And @Kosin https://www.instagram.com/danny_superb_3v?cplk=YW1ycnRhbjl2dzli
  6. Hi guys so quick update, The oil level is at the correct level it's just below the first slope/line. I will check the wiring on the sensor for and breaks or if there is a connection issue using a multimeter if that seems okay I will get the exact oil level sensor as I have found one with the same part number as the original one which I have confirmed with the vin number . P.s I have pumped up my tyres so that has sort out the tpms light
  7. Problem is. I do car shows with it So also want the most impact to stand out It’s strange driving a standard car 😂
  8. Easiest/cheapest first. Then you don’t feel so bad about spending more money on singular larger mods as you’ve achieved so much already… Make sure you let your insurance know. Just done a renewal and declared everything and had to send photos but no change in premium as nothing is permanence changing.
  9. My 19” vegas are rough Kerbs, clear coat is flaking, worming Debating a few things Upgrading to 20” vegas Refurbing these, but I don’t know what colour to go for, not a fan of the diamond cut lips etc so would prefer a solid colour over it all Or leaving them and buying aftermarket Advice Anyone fitted 20” vegas?
  10. I have a huge list of mods And I truly don’t know where to start first 🥲
  11. Sorry, forgot to close this off. The Skoda dealer in Dundee charged me £80 to diagnose the pump and then £265 to change the pump. It was a warranty job hence the dealership, but the warranty only paid me £9 for the pump as they said they check GSF parts for price!!!!!!!! Anyway a £9 pump was the issue all along. Lesson learned for any future parts.
  12. I’d love to put eibach springs on mine but can’t justify the work to do it. So might buy them to sit in the shed awaiting it needing some suspension work….
  13. It has standard shocks. The Bilstein B6 24-229890 seems to be the one to go for. I fitted B6's to the rear of my 2010 BMW 330D 4 years ago. They've worked fine on that car.
  14. I have the same problem, stuck in emergency dowload loop. Can you help?
  15. Hi guys / girls , I got my new Octavia vrs plus Saturday and this morning the crystal lighting really looked good , my question is really do I just leave my main beam on all the time or if I do a certain speed will it kick in itself ?? Sorry to sound thick but I’ve never had lights like this before
  16. Nigel7625 started following Octavia vrs
  17. Today
  18. Hi, i have a problem says emergency download, can anyone help?
  19. Thanks for the info, really helpful
  20. Thanks for clearing that up
  21. Nigel7625 joined the community
  22. wooliew joined the community
  23. Hi. If you need any help with insurance at all then please feel free to drop me a line. Regards, Dan.
  24. I have a similar problem, but mine is the fuse overheating. I have cleaned the contacts a few times to little and now to no avail. Any suggestions on how to bypass the allocated fuse or a fix?
