Cleaning Veritate wheels
That sounds like an excellent plan. Anything to reduce the build up of brake dust and tar is worth exploring. When I swap over to winter wheels at the end of this month, I am going to get the Veritate wheels ceramic coated. That won't solve every problem with the design, but it should reduce the elbow grease at each cleaning.
Random misfire on Octavia 1.4 TSI CHPA 140ps mostly on cylinder 3 and 4, not Injectors, sparks, coils. What to do?
Hello, i have a skoda octavia 1.4 tsi chpa 140 ps 2015 on 205 000km. First owner. The car had no critical issues for all mileage. Since February 2026 i have an issue with misfires on random cyliders. I check them with VCDS and OBD Eleven 3 on live data. Also total counter on cyliders is very different on cylinder 4 as: 1-26000; 2-27000; 3-30000 and 4-41000. For certain trips the car generates up to 50 misfires mostly on cylinder 3 and 4, very less on others but still exists. There were a fault codes as P0300 and P0304. I changed: 1) All 4 pcs. of injectors with new by Bosch. 2) Changed the coils from 1 to 4 and from 2 to 3 but no difference. 3) Sparks were also changed, no solution. There are no errors as P0300 and P0304 after injectors change. In the mornings, when air is cold 15 degrees misfires are less, than in hot wether as 30 degrees ambient temperature. In the mornings during catalyc heating there is no issue. When i turn on the AC the misfires gone and no misfires. Without AC misfires exist. Idle rpm are 719 rpm/min. No issue with fuel preasure, injectors sealings, fuel rail, sensors, air filter. I checked the vacuum PCSV with oil cap opening, no issue seen. On intake valves has less carbon on the valve tail. I didn`t do a hasenut cleaning. Has somebody same or simmilar issue? How was solved? Why AC reflects to the misfires? The reason to solve this issue that i feel every misfire of engine. The shakings are very anoying.
VW Caddy mk2 (Felicia) Pick-Up 1.8T
Another job that Martlet Autos got done whilst the Caddy was with them was to replace the windscreen rubber. I really wanted to get it done by an automotive glass specialist, because I figured that they would definitely use a quality rubber or risk me making a fuss if the windscreen (still) leaked. Unfortunately the only place local to me which showed an interest in doing the job on a 30 year old car then lost that interest and ghosted me. Plan B was to buy the best quality windscreen rubber that I could find, but that was stymied by the total lack of choice of rubbers which were available from stock. Literally all I could find was a rubber made by Vika on eBay. Sika I am aware of, Vika I was not. It was worryingly cheap too. Still, beggars can’t be choosers, so I ordered one. I was pleasantly surprised when it arrived and did not feel like it had been made from recycled tyres. Johnny at Martlet concurred, and he is better qualified to know than I am. So far so good insofar as the Caddy’s carpet has been staying dry in the recent rain. With all of the bodywork jobs done, for now, it was finally time for a new MOT. On the way over to JKM for the test there was very clearly something wrong with how the Caddy was boosting. As soon as the boost approached 1bar it was all being dumped very abruptly. This was diagnosed to be due to my re-fitting the N75 valve wrongly, which was a simple fix. In what has become my usual style, I had asked JKM to do a couple of jobs which I did not fancy doing myself. One of these jobs was to fit the braided brake hoses. I bought HEL kits for front and rear, which involved making a couple of guesses due to my Caddy having very few of the original spec brake components still fitted. For the front I bought Mondeo hoses to match the ATE callipers, and these proved to be fine. For the rear I bought a Felicia kit, even though I have disc brakes, but this was not so successful. The issue was that the kit was for a Felicia hatchback or estate, and so contained only one hose for each side rather than the two per side required for the pick-up. JKM did try to source the hoses to finish the job, but could not get any delivered in time to fit on the day that the Caddy was with them. That part of it will have to be deferred to another day. The second job was to fit (another) new sump. The one that was on there had not suffered impact damage like the previous one, at least not that I can remember, but it was leaking badly, more so following my forlorn attempt to re-seal it. Whenever I collect a vehicle from JKM, which happens fairly frequently, I always find myself in the evening rush hour on the drive home along the A27. This time it was worse because I was doing it at the height of a heatwave, there were roadworks on the A27 plus a diversion due to a full closure of another road, so the traffic was carnage! I sat in queues virtually the whole way home, and all while the temperature gauge was creeping towards the red. I had remembered the Caddy as cooling very efficiently when it was in more regular use, but it was definitely looking marginal now. The cooling fan tell-tale on the dash was illuminated most of the way home, but the temperature gauge was only coming down when I was generating airflow through motion. It was a massive relief when I made it back home without the Caddy boiling. The next day I tested the cooling fans, and found that whilst the tell-tale was on, the fans were not. It did not take long to pinpoint the fan relay as being the cause. I swapped it for another, and normal operation was restored. When I tested the failed relay on the bench, it actually ‘unstuck’ after a couple of attempts, but I threw it in the bin anyway, I am not trusting that again after it has come so close to causing a disaster.
Just picked up a car with these wheels (would have preferred the standard wheels but we weren’t going to say no to the discount. The Karoq that it replaced had a similar trough but also had plastic aero trims which made cleaning the wheels a real pain. Looks like I am shopping for toothbrushes but one job for later in the week is to take the wheels off and apply some Autoglym alloy wheel protector that I bought three cars ago and never got around to applying.
Another Superb
After almost theee years with a Karoq we set off to look at an Octavia and (for the second time) came back having ordered a Superb. We have been looking around for a while and I saw a new Octavia estate advertised for less than 30k so went to look. Saw it Saturday evening, dealer closed Sunday and Monday advised it had gone. They then found a Superb estate with similar discount (anyone else benefit from the September offer?), the wife agreed and we collected it last Monday. 2.0 TDI SEL auto with 19” wheels. After two 2.0 TDI SEL hatches as personal leases we have a third Superb.
Cambelt / Timing Belt Quotes
"plus £110 extra for auxiliary belt" Wow, that's a lot of parts cost for an auxiliary drive belt. A belt you have to take off and refit as part of a cambelt change anyway. So they can't claim any extra labour is involved. Edit "unless that means the aux belt tensioner too, but I fear it doesn't"
aubrey started following Cambelt / Timing Belt Quotes
Key replacement
And just had a quote from the local dealership for £516 (inc VAT). And payment up front just so that they can source the key!!!
Rare parts ? That you got/ what can you get ?
Hi have recently had brake problems with my beloved Fabia VRS 1.9TDI and my garage cannot find a brake vacuum pipe and I have tried searching the web with no success. Any fellow VRS lovers got any possible leads on where spares can be found for my 2007 model. Any help much appreciated as I hate the thought of not being able to brake!!
Essexman1 started following Rare parts ? That you got/ what can you get ?
- Hi All
Thanks for the recommendation, may be a little far for me as I'm outside the city but will have a look.
Hi Warrior, just at 100k miles. No issues with the pump as far as I can tell. By way of context re. belt change, I feel now is a reasonable time to look at exchange for me. Early per updated recommendation but while I anticipate having the car another few years I'm unlikely to do another 100k miles on it so don't see a huge amount to gain by pushing the change much further out.
- Hi everyone
Crucian started following Hi everyone
Essexman1 joined the community
Key replacement
We lost a key. Went to a reputable independent local locksmith that specialises in car keys. Tried twice to get a new key working: First time with a third party fob Second time with a genuine Skoda fob Failed both times to generate a fully working key fob. Sounds like I will have to try the dealers. Anyone else had similar problems David
dacn started following Key replacement
Dani1980 joined the community
HandyHowie joined the community
Fabia Automatic
Thank you.
As your in Glasgow try https://www.thecrossgarageltd.co.uk/ for a price.There in Kirkintilloch and are vw/skoda specialists. Bought a 1.9tdi from them a few years ago that had been looked after/serviced by them and had no problems for years. They were really good to deal with. Old school garage Father and Son. Alasdair
Alasdair1 started following Cambelt / Timing Belt Quotes
Fabia 2011 1.2 TSI - DSG 7 speed gearbox help
^^^ That is different from doing a DQ200 on a 1.2 or 1.4 TSI Fabia. Do not remove the starter motor. @Catwoman If your car is a 2011 than there was a Service Campaign after 2014 to change the oil from Synthetic to mineral & a software update. '34F7' Dide the car get that. Sticker in the spare tyre well. There are 2 oils to change, in the gearbox and in the MCU. If changing the oil best do both. Best know what you are actually doing.
Fabia Automatic
It is a DQ200 DSG which is a Twin Dry Clutch Gearbox. Skoda / VW call them a Semi Automatic. They are as far as matters a 2 pedal automatic gearbox. Best thing is go try one. You driving it like an Automatic, so 1 foot only. You can change gear manually. No Servicing Schedule with them.
Fabia Automatic
I am very happy with my MkIII Fabia estate so looking for a Fabia for my daughter. Sadly she only drives an automatic and I have no knowledge of automatics. I would be grateful for any advice from owners.
Mugwamp started following Fabia Automatic
I seem to recall there's some reasonable step by step guides on YT, e.g.: We've the same DSG in our Polo. I've considered changing the oils, but not yet made it past the considering stage. Gaz
Catwoman started following Fabia 2011 1.2 TSI - DSG 7 speed gearbox help
Hi all I am fairly new to this website and definately new to being a Skoda owner! I purchased the above car a few months ago and as we (my family and I) usually do all our own car maintenance although we are pretty clued up I purchased a Haynes manual for the car it covers the 'usual' stuff but unfortunately it doesn't cover certain areas like the DSG, I want to replace the oil in the gear box and need to find a definitive answer as to what oil type, the quantity and also how to change it. So if anyone out there is able to help with any advice or trusted web links it would very much be appreciated. Thanks 🙂
Good morning Jamie, what is your mileage? Are you beginning to have issues with the pump?
Strange flickering from inteface consul
Hi, I have a Bolero enteratinment system with the CPU head unit in the glove box and a 5E0 919 605 B interface unit on the dash. Over the last year I have been getting periodic flickering on the screen until the summer when the screen packed up altogether but the buttons continued to work. I replaced the interface unit and whilst this worked for a couple of weeks, the dreaded flickering has returned and I'm worried the replacemed screen is going to go the same way as the last one. Does anyone know what might be going on here? Or quite happy to be pointed to another post that covers it. Thanks
- Hi everyone
Skoda Karoq 1.5 DSG gearbox
A final(hopefully) posting on my mate's 2019 VW T-Roc 1.5TSI 150PS DSG, WBAC happily took it off his hands, I don't know what sort of money he got for it, but maybe I managed to soften the blow by saying that I was worried that he was going to just get it repaired and then get hit by the much quoted DADA engine problems "quite soon after". So it's back to using some of his fleet of classic SAABs for now!
Johnny_bravo_5 joined the community
Windows
Thanks for your tip, I don't have a lot of faith in our local Skoda dealer. Which by the sounds of things is not unusual!!
