- From Amundsen to Columbus: mission almost accomplished!
The 220ps experiences, questions & answers thread
Hey mate, yes we have after it having to go back 3 times and then them destroying my 12v step down for the USB, I have a service as part of the plan this month and can’t find anything to replace it with that would be worth while so have decided to keep it for now.
Thanks @JR RS so these can take a tune quite well then, maybe I will go for the 300hp as these seems run around 230-40 stock by the look of it. Just that I have read the gearbox is limited to 350nm but not sure if that is true
Android radio 52pin adapter
- Android radio 52pin adapter
Hey everyone! Hoping someone can help me, im currently trying to put an Android unit in my skoda, and cannot seem to find the correct 52pin plug adapter. I have the Fibreoptic decoder for the canton sound system and the can bus box pictured below. But the connector seems to be incorrect every time... Any advice or tips would be greatly appreciated!Kurara started following Android radio 52pin adapter- Dealer Or No Dealer?
Go to a VAG specialist independent in future. Discs do not fall for being lipped, that's a racket a lot of garages do, new pads maybe. It's too late now but with your car only doing about 7,000mi a year you could have had it serviced every other year if they used long life oil. Good luck with your future, I hope it is stress free.KWP started following Dealer Or No Dealer?- Today
- 1.5 Tsi Power Cutting Out
Our 1.5 TSI never cut out, bought new in 2018 and sold earlier this year after 8 years of trouble free motoring. Now replaced with another one, DSG this time.- 2011 Superb VR6 Starts then dies, Fuel Issue??
Hi All My 2011 superb 3.6 is causing me major headsches. Car starts great & then immediately dies. can start it again imeediately no issue but then dies again unless I push the throttle down & get it up to around 25 - 3000 rpm but even then it runs rough & will die again if revs drop Have replaced fuel filter at rear, ensured line from filter to low pressure sensor is clear, have fuel to the in side of the fuel rail(?) . no codes come up when interrogated relating to engine control etc. Is there an easy way to test the HP fuel pump is working correctly? any other thoughts & suggestions are welcomed. Do have misfires on nearly all cylinders when I can get ot to run on high revs.bdk started following 2011 Superb VR6 Starts then dies, Fuel Issue??- The 220ps experiences, questions & answers thread
You decided to keep it then?Binx1310 started following The 220ps experiences, questions & answers threadClem_82 joined the community- the truth about electric cars
More news of Electric truck roll out by Amazon are other logistic companies......PC7101 started following Knocking noise/rattle from DCC - Sportline 2.0 PetrolPC7101 joined the community- The 220ps experiences, questions & answers thread
Gandalf (MY17 Superb 220 FWD) is currently on Stg 3, producing 400 hp 550 Nm at the wheels. Previously I ran Stg 1 for approx 5 yrs before going to Stg 2 briefly then Stg 3 last year. I've had no issues with any of the stock hardware over the many years. The Stg 1 was an APR Hi-torque tune producing 300 hp 540 Nm at the wheels. Supporting mods then were R600 intake, turbo inlet pipe and elbow. I also had a TCU tune, which made a big difference. Now I've got an IE intercooler & downpipe, Garrett Powermaxx Turbo with stronger injectors. The Galano TCU tune has a Boost-by-Gear function that is specific for the FWD, that does an impressive job putting the power down through the front wheels without wheel spin.- Problems after ABS module replacement
slamik joined the community- Problems after ABS module replacement
- Yesterday
- What have you done to your Kodiaq today?
Hi, full refueled this evening and 17th fill-up in a row under 7.0l/100km. Not that bad for a big 1840kg bear with 200HP. 🙂- The 220ps experiences, questions & answers thread
@JR RS I think that's a question for you! 😉- The 220ps experiences, questions & answers thread
Dragging this up, did anyone ever have a confirmed higher stock output from the 220 engine? Looking at doing a remap but not wanting the full 300bhp that most quote, would be happy with 240 - 280tombee started following The 220ps experiences, questions & answers thread- 1.5 Tsi Power Cutting Out
Welcome to the clubSlawa123 joined the community- Hello from Belgium / New Member
Hi, glad you joined. I drive an Octavia 2014 petrol- DQ200 DSG Mechatronic Issue – Loss of Odd Gears & Low Hydraulic Pressure (P284F00 / P283C00)
Hello again, to convey my previous experience, but I also need a little help. I have been researching this dq200 hoping to solve the problem myself because the price they are asking in Belgium and surrounding countries is crazy. After watching a lot of videos on how to disassemble and assemble, how to test various parameters, I found that I lose pressure very quickly, that the pump works properly and builds up pressure, and I established that it is not a mechatronics problem, but a pressure accumulator or an aluminum plate. Since I couldn't test where the crack is (I don't have a compressor or suitable adapters), I bought a replacement accumulator Kinergo MSU04 for pressure, oil for the mechatronics and for the gearbox, as well as the digtung cover and tubular oil filter and prayed to God that it wasn't a plate. I did not measure how long the pressure holds before replacing. Now with the new one it lasts about 18-20 seconds Does anyone know how long the pressure accumulator should hold pressure while the car is idling?- the truth about electric cars
Indeed. The withdrawal of the Federal EV credits caused sakes to drop big time. EV sales have recovered a lot with fyel doubling in price. The Buzz will need to be biult cheaper, LFP pack etc and buyers happy to pay for a premium over rivals.- Cambelt change for 1.5TSI engine
Cahill in Dorchester - Android radio 52pin adapter
