  2. Could be. Estimated £4-£5k excl to sort it
  3. CJJE replied to ian-inhome's topic in Skoda Karoq
    I had one of those messages, along with the normal software update message (which I think is now solved, but that's another story!) I wasn't able to scan the QR code with my phone as I was driving, and then it went away. As you say, the only change in the app is the profile / smart home section which seems to be offering to link my car to my non-existent smart home app. No idea what this is about unless it is offering to warm the car up before you use it?
  4. Today
  5. peterfr joined the community
  6. I understand Thank you Maybe someone else once read few of comments have some experience
  7. According to Rosstech 00532 is either voltage too low or too high. Check battery first and also when running in case the alternator is puting out too much. If thats ok then it may be a bad earth/broken wire. Depending on what you used to reset airbag I heard that it should be VCDS etc as some other non VAG scanners cant reset them properly.
  8. Garmin GPS sat-nav devices can be connected to a USB port https://support.garmin.com/en-GB/?faq=zPmeeDJGFP8qMbgHObM1j7 but, for reliable operation and simultaneous charging, it's simpler to use a car's 12V 'cigarette lighter' socket-outlet.
  9. All depends if the job went straight forward or they came accross a problem like seized bolts etc. I would ask the garage if the job went as planned. How many hours did they charge you for the job. It may have included taking it to and from MOT centre/road test/alignment etc. Alasdair
  10. I have been told by a garage that a flap is broken, and that I will need a replacement intake manifold for my 2006 Octavia 4x4 FSI 1984 cc. I cannot find an after-market replacement, and even a used one costs near £500(!), which doesn't make economic sense... Is it possible to replace the flap, or should I live with less than perfect performance?
  11. Meant to add check that the runners that the glass sits in door are clear and top isnt obstructed. Alasdair
  12. Normally you press up till window fully up and hold for a few secs then repeat down. Should reset itself. Is the glass fully in the regulator at bottom and are the cables running ok Alasdair
  13. Alasdair1 started following Window regulator
  14. I think it’s more doable but I have no experience of this.
  15. Given the reference to Ebay module, presumably this charging mode isn't OEM standard ?
  16. This sounds like you have a DADA code engine - and "crank walk".
  17. Sorry, should have said - DSG
  18. I have booked an appointment today service center on Monday morning. Let's see what they are going to say.
  19. automatic or manual transmission? unbelivable what a bad quality control. there are cars with half a milion km without any play..
  20. push this whole holder in a hole, than push this little pin inside too. it will spread those 4 litle legs.
  21. Just had this error pop up after a cold start a week ago, went away and didn't come back. Late 2022 dq381. I hope it won't become a regular occurrence 😬
  22. Absolutely Superb 👌answer. Thank you very much. Last one. So what chances have I got if I try do it via VCP?
  23. Took apart the mirror as much as I can in situ and the motor looks very much like a sealed unit. No obviously broken wires from what I can see. You can hear the motor start and then nothing moves so I suspect a damaged gear or motor itself rather than wiring issue. Managed to source a whole replacement second hand mirror unit from eBay for £49 delivered. Bonus being it appears to have the ££££ dimming glass installed on it too! Hopefully a straight swap and change the mirror cap for black and away we go. Watch this space…
  24. InstinctHelper joined the community
  25. I've used them maybe 6 times over the years, as said you really do need to do your homework to check that parts are correct for your use, I use an online VW Group parts listing to get the correct and latest version of the part numbers for my cars first, then make sure, for items like road springs, that my part number is the only one that is listed against their offering. My mate wakened up the other morning to an offer from them for rear brake callipers for his old SAAB 99 - both his rear callipers have seized bleed valves and they are the small type - he claims them to be 6mm AF but I'd think that they started life as 7mm AF and have "rusted down a size", so if his latest Autodoc purchase works then he can either refurb the originals or just snap the bleed valves off (worst case), once they are off the car. He's had wrongly supplied clutch parts in the past, but as, unusually for him, he paid the "safe order" premium, the parts got swopped over FOC to him.
  26. Hi everyone, recently bought my first EV after many years of gas guzzlers, and thoroughly enjoying it.
  27. kenyaq started following Hello from newbie
  28. Did you manage to sort this out? At least on my wife's 2015 VW Polo 1.2TSI, the area under this clip is hidden as it is on a plastic body part that bolts down onto the next metal body part - probably the lock carrier in VW Group speak.
  29. kenyaq joined the community
  30. which is mileage of a car? no new engine, just crankshaft machining and larger bearing. maybe only new bearing.
  31. Now dispatched and should be arriving today!
