Stopping chain noise
It's has gone into an independent garage today for oil an filter change. He uses 5W 30W for this engine so looking good
Radio cutting out new starter motor
What about just turning the radio off before starting engine?
Retrofit OEM LED Headlights for LHD
Hi, Did you have a look by Kufatec? They may sell plug and play adapters...
Felicia bonnet swap
I've never done this, so I'm not 100% sure, but cars made after 1996 should have the newer radiator support panel, compatible with both types of the lock. Try to remove the old lock, there may be extra holes hidden under the cover (sorry, I couldn't find better photos of a bare panel) For reference, the older panel, that's not compatible with the facelift lock, looks like this So yours should be compatible.
Sorry its Gearbox. On my sons mk1 its a braided strap. Alasdair
I would be requesting back to 5w 30 FS III then which was @nd still is the spec of oil for that engine. Personally if noise I would go 5w 40 FS which was and is still the spec if you want and as long as doing fixed regime oil and filter changes.
£30 charge for Courtesy car!!!!
Heritage Skoda charge £40 for a courtesy car.
robsie started following £30 charge for Courtesy car!!!!
Tyre recommendations
For what it’s worth… I notice that, when I said that Skoda only advised that a single 2.5bar inflation-pressure should be used for the tyres fitted to Skoda Fabia Mk4 cars, that was not correct. The ’correct’ tyre pressure for Fabia Mk4s was discussed here https://www.briskoda.net/forums/topic/522596-correct-tyre-pressure/ when I provided the following photo of my own Mk4 SE L car’s pressure-sticker. It will be seen that the 2.5bar front- and rear-axles pressure recommendation applies only to ‘normal’ loading (3 people + 3 suitcases) whereas 2.7bar (front axle) and 3.4bar (rear axle) are advised for ‘heavy’ loading (5 people + 5 suitcases
scottm73 joined the community
Octavia 2l tdi cupa egr cooler bypass what is needed and how to do it ?
Hi ive got a build up of black soot in the coolant tank and getting pressure in the system when taking off the coolant tank cap in the morning when engine is cold it still releases a heavy hiss of air escaping, also when turning ignition on or off get a gurgling sound from behind dashboard. Im hoping this is a broken egr cooler and not the head gasket so to check i want to bypass the egr cooler , the dpf and egr are already mapped out . As anybody on here bypassed the coolant pipes on the egr cooler on here before ? If so what size pipe do I need ? Is it possible to do from top of the engine or do you need to get underneath it ?
Hallen joined the community
Hi Cairus, I'm currently converting my 2017 Škoda Kodiaq to the 2021–2022 facelift version. I have purchased both facelift LED headlights, but the original wiring connectors are not compatible. My headlight part numbers are: Left: 566 941 035 Right: 566 941 036 New control module: 992 941 572 CA Original control module: 7P5 941 591 AD I'm looking for a complete plug-and-play adapter harness for both headlights, without cutting the original vehicle wiring. Would you be able to manufacture these adapters, or help me identify the correct connectors and wiring? Could you also advise whether additional modules or coding would be required? I'm based in the UK. Please let me know if this is something you can help with and what the cost would be, including delivery. Many thanks.
gold started following Retrofit OEM LED Headlights for LHD
gold joined the community
Škoda Approved Used – should outstanding scheduled maintenance have been completed before sale?
I'll keep it brief. Whatever you want, make sure they give you it. I was sold a crash-damaged Leon by a main dealer, which is why I'm now in my Octavia. The VAQ service, plugs and air filter should have been done - especially as £19,250 is pretty expensive for a 40k Mk3 Octavia. Check if you can see a date on the battery - my guess is it's the original, which is knackered. If the VAQ hasn't been done, it's 11,000 miles overdue. Make sure you get in writing that they acknowledge this, in case of any future issues. The DSG isn't "due", but I would suggest you do it. The 381 interval is 80k, but most follow every single other DSG interval and do it at 40k.
- Aftermarket jack pad inserts Octavia MK4
- R600 Plus Pikey mod Skoda-specific?
AdBlue
Did this ever get resolved? I have a similar issue on my 2017 2.0 diesel. Last time it was filled - about 6m ago, it took three journeys to register the fill (and the distance remaining to go up). After that it put the engine management light on, with a P203 error - "Reductant Level Sensor Circuit Range/Performance". I cleared this code, but it's recurring. I recently re-filled the adblue, but this time it hasn't recognised the fill at all, so I'm on a countdown. I've tried some Wynn’s Crystal Clean & Protect in it, but no difference. I did read that sometimes the car gets confused about where the level really is (it did have a new battery some months back), but needs VCDS to reset this - but I'm thinking it's probably the sensor (= new tank), which will be an expensive job. Any thoughts or experience? Does anyone near Hereford have a VCDS tool?
- Yesterday
New headlight cannot adjust the dipped up enough
Nope Booked it into a skoda dealer for either a simple adjustment ( as soon as I felt resistance turning the adjuster for some basic levelling (before I took it to a garage for proper setting ) I stopped maybe it just needs to turn more) or for a warranty claim against the new headlight that’s potentially faulty
Yes, I used the Powerflex PF3-1663K. I did not cut anything, but I will do it in the front next year, it is only necassery in front. But will only be an issue if you have to remove the plasticpanelsat some point. Front before: front with pad: rear before: rear with pad: and I used this OE spray in the hole before mounting them, and as lube to get them in.
Thomas_Toget started following Aftermarket jack pad inserts Octavia MK4
Radio database field BLANK on MIB3 FM radio - Australia (2021 Kodiaq, SW 0330)
Paged but unfortunately I am not in Autrslia and I don't deal with MIB3 units
Which all-season tyres are you running on your Octavia?
I've run Goodyear Vector 4 All-Season Gen3 205/55R16 94V XL for several years on an Octavia Combi 1.6 TDi 110 Front wheel drive.. Very pleased with them in all respects -so much better than summer tyres when it's cold and wet. Haven't had to do much driving in snow or mud but when I have they've behaved well considering the conditions. Replaced them due to age not tread wear - fitted same again.
BazzY started following Which all-season tyres are you running on your Octavia?
Paging @pab567
Hi everyone, Hoping someone can point me in the right direction. I've looked all over the posts here but Im just getting confused. I bought a used Skoda Kodiaq 2021 132TSI only to find that it doesn't have DAB, only FM....shattered!! I’m trying to get radio station logos to display on my preset buttons. My Kodiaq is equipped with the MIB3 system (Device part number: 3V0035876D). Currently when I store an FM station to a preset it just shows a generic station box or blank icon. Looking at my System Information screen: Hardware: H22 Software: 0330 Navigation database: 20.3 Radio database: [BLANK] I tried searching for updates on Phonostar using my details but there don't appear to be any regional logo packages or matches for Australian FM stations on MIB3. A few questions for anyone who has dealt with this on MIB3. Is the "Radio database:" field completely blank on all Australian MIB3 units or is my database missing due to the software version (0330)? Is there any signed database update zip file (Phonostar/VAG) that can be flashed via USB-C to populate logos for Australia? Since MIB3 has no SD card slot and Skoda removed the manual individual logo import option that older MIB2 units had is there any known workaround to assign station icons? Or are non-DAB MIB3 owners outside Europe simply stuck with generic blank placeholders for FM presets? Any advice or insights would be much appreciated!
Engine is 86bhp tsi with 75k on clock. It has the revised chain tensioner and 2013 reg. I have owned it since new and dealer serviced. The dealer has changed hands and also oils. Currently it has 0W 30W Castrol Edge. In its lifetime it has had Shell Ultra Helix 0W 30, Castrol Edge 5W 30W all Skoda filled
slawekro joined the community
19” vega alloys advice
Love that - something different is always good.
i like to try different things as well, took the 19" vega's off and fitted a used set of seat 17" alloys, had to fit 10mm spacers and longer wheel bolts to keep the same offset. Got 4 cans of spray paint out of aldi's and sprayed them up gloss black, put 225/55x17 tyres on and it;s been the best thing i've done to my superb. i was even able to fit & balance the tyres myself, with 19" wheels/tyres there's no chance of that as you cant even break the bead. The strange thing is, there's been no difference to the handling or cornering but a big difference to the ride comfort. Why does everyone wont bigger wheels?
Yevhen joined the community
The fronts are 19”, the rears are 20” so a set of 4 fronts fits perfect. I think Gallardo wheels fit too but I’m not convinced they fit stylistically. I tried to buy a set of non-badged centre caps (happy not to have emblems) but after 2 sets (albeit Ali Express) neither of them fit so I gave up.
