the truth about electric cars
Amazon already have a fleet of electric HGVs and they are ideal for their usage as they go from warehouse to warehouse. Known mileages and chargers at their warehouses mean that can be charged while loading and unloading is being done ready for their return trip.
The 220ps experiences, questions & answers thread
Definitely not the case - these DQ250 gearboxes can take up 600Nm with the stock clutch, but needs a TCU tune to cope with additional power. Any higher n u'll need to start changing clutch hardware.
From Amundsen to Columbus: mission almost accomplished!
😂 Sorry. Nobody read What i say: Did you perform the function activation? It probably won't work with ODIS Online, though, because different data is stored on the server. If IT works, only the Fec's from Factory out are activ. In my opinion, the online services are completely useless. The MIB3 runs much more stably and reliably without them. So, disable them via coding, patch the unit, and you're done. But in this case, since the CP has been officially removed, the online service might actually work despite the FEC patch.
- From Amundsen to Columbus: mission almost accomplished!
Hey mate, yes we have after it having to go back 3 times and then them destroying my 12v step down for the USB, I have a service as part of the plan this month and can’t find anything to replace it with that would be worth while so have decided to keep it for now.
Thanks @JR RS so these can take a tune quite well then, maybe I will go for the 300hp as these seems run around 230-40 stock by the look of it. Just that I have read the gearbox is limited to 350nm but not sure if that is true
Android radio 52pin adapter
- Android radio 52pin adapter
Hey everyone! Hoping someone can help me, im currently trying to put an Android unit in my skoda, and cannot seem to find the correct 52pin plug adapter. I have the Fibreoptic decoder for the canton sound system and the can bus box pictured below. But the connector seems to be incorrect every time... Any advice or tips would be greatly appreciated!Kurara started following Android radio 52pin adapter- Dealer Or No Dealer?
Go to a VAG specialist independent in future. Discs do not fall for being lipped, that's a racket a lot of garages do, new pads maybe. It's too late now but with your car only doing about 7,000mi a year you could have had it serviced every other year if they used long life oil. Good luck with your future, I hope it is stress free.KWP started following Dealer Or No Dealer?- 1.5 Tsi Power Cutting Out
Our 1.5 TSI never cut out, bought new in 2018 and sold earlier this year after 8 years of trouble free motoring. Now replaced with another one, DSG this time.- 2011 Superb VR6 Starts then dies, Fuel Issue??
Hi All My 2011 superb 3.6 is causing me major headsches. Car starts great & then immediately dies. can start it again imeediately no issue but then dies again unless I push the throttle down & get it up to around 25 - 3000 rpm but even then it runs rough & will die again if revs drop Have replaced fuel filter at rear, ensured line from filter to low pressure sensor is clear, have fuel to the in side of the fuel rail(?) . no codes come up when interrogated relating to engine control etc. Is there an easy way to test the HP fuel pump is working correctly? any other thoughts & suggestions are welcomed. Do have misfires on nearly all cylinders when I can get ot to run on high revs.bdk started following 2011 Superb VR6 Starts then dies, Fuel Issue??- The 220ps experiences, questions & answers thread
You decided to keep it then?Binx1310 started following The 220ps experiences, questions & answers threadClem_82 joined the community- the truth about electric cars
More news of Electric truck roll out by Amazon are other logistic companies......- Knocking noise/rattle from DCC - Sportline 2.0 Petrol
I have a 2025 Kodiaq noise in suspension from day 1 dealer changed shocks and 2 steering racks still the same car is non DCC.Skoda sent an engineer he said it’s a characteristic of the car. I got an independent engineer he agrees with me noise should not be there now the 2 engineers are meeting up to discuss. I have spoken to a few owners all have the same issue and getting no where fast.PC7101 started following Knocking noise/rattle from DCC - Sportline 2.0 PetrolPC7101 joined the community- The 220ps experiences, questions & answers thread
Gandalf (MY17 Superb 220 FWD) is currently on Stg 3, producing 400 hp 550 Nm at the wheels. Previously I ran Stg 1 for approx 5 yrs before going to Stg 2 briefly then Stg 3 last year. I've had no issues with any of the stock hardware over the many years. The Stg 1 was an APR Hi-torque tune producing 300 hp 540 Nm at the wheels. Supporting mods then were R600 intake, turbo inlet pipe and elbow. I also had a TCU tune, which made a big difference. Now I've got an IE intercooler & downpipe, Garrett Powermaxx Turbo with stronger injectors. The Galano TCU tune has a Boost-by-Gear function that is specific for the FWD, that does an impressive job putting the power down through the front wheels without wheel spin.- Problems after ABS module replacement
- Sequence update file SK20220307SEQSW96
Hi everyone, I am looking for help updating the MIB3 (MOI3 LG unit) infotainment system on my Skoda Octavia IV (2020). * Current SW version: 1668 * Target SW version: 1941 (already downloaded) Since direct update from 1668 to 1941 is not supported and can be risky due to partition layout changes, I need an intermediate bridge/sequence update first. Based on Skoda documentation and TPI, I likely need the sequence package: - SK20220307SEQSW96 (or MOI3_EU_SK_R7880L / R8960L) Could anyone please share a working link (MEGA / Google Drive) or send me a PM with this intermediate sequence file? Thank you very much for your help!slamik started following Sequence update file SK20220307SEQSW96- Problems after ABS module replacement
slamik joined the community- Problems after ABS module replacement
- Yesterday
- What have you done to your Kodiaq today?
Hi, full refueled this evening and 17th fill-up in a row under 7.0l/100km. Not that bad for a big 1840kg bear with 200HP. 🙂- The 220ps experiences, questions & answers thread
@JR RS I think that's a question for you! 😉- The 220ps experiences, questions & answers thread
Dragging this up, did anyone ever have a confirmed higher stock output from the 220 engine? Looking at doing a remap but not wanting the full 300bhp that most quote, would be happy with 240 - 280 - Android radio 52pin adapter
