  2. Even with the advances in engines these days I think you'll find that if you ever travel fully loaded with passengers and luggage the car will struggle. A car may appear nippy when it's just yourself driving (the default situation for many cars) but if you have the opportunity, try a test drive "fully loaded" to see how suitable a workhorse it may be.
  3. Upgrade Carplay and retain the 6CD system(RCD510)
  4. BlueDun joined the community
  5. Today
  6. 43 for sale in FM Hutchings auction on 12/9/26
  7. Yesterday
  8. mistac replied to mistac's topic in Škoda Elroq
    Would also be interested to hear from any new/recent owners of any Elroq 85 if they have the 84kwh battery (think that is now standard on MY27 versions?) and if they ended up with crappy I mean not so good Giti branded tyres?
  9. I have just ventured into this and through a voyage of discovery, have found you can take the top glove box out without too much trouble. Unfortunately it achieves nothing, no access to the offending item. I have a 2010 mk2 Skoda Fabia and the only way to access the actuator, is by removing the whole dash. The glove box in my car is integral to the dash. The flap motor in my case, is under the passenger air bag, in the top left corner. There is little information about the task, I now know why.
  10. Unhappy Swan............... Not a bad sunset earlier...............
  11. Skoda fabia IV 2024 31k miles. When driven over any slight bump in the road there is a clunky noise/rattle coming from the nearside rear. This includes potholes, speed bumps and uneven roads. Sometimes the noise sounds squeaky but sometimes it’s like a metal clunk. Has anyone else had this issue and if so what was it as i’m trying to repair things myself and wondering if this could be done without taking it to a dealership
  12. Well blow me down! I've been driving the Fabia quite a bit more just lately and continuing to enjoy it, though the ride can be a bit firm when only two up on poor roads, even though we stuck with the smallest wheels available, probably not helped by the energy efficient tyres which I assume have stiffer sidewalls? Also smaller cars tend to be more firmly sprung to be able to cope with the varying load of one to four/five people which is a greater percentage of the weight of a small car than it of a big car. The suspension in my son's Mazda 2 is also quite firm. Anyway, I digress. Couple of days ago my wife looked in the glovebox when I was driving and low and behold a Skoda umbrella! The car is coming upto 3 years old now and in mitigation we rarely use the gloveboxes in any of our cars. Maybe I had looked in the glovebox and saw the umbrella when we first got it and thought it better left in there and I'd forgotten?
  13. Sorry.. No cigar for that guess...
  14. Yes, we accept that it is possible on a good day with the right conditions and the right support just as this diesel powered Skoda Superb managed to drive for 1,759 on one tank of fuel and it set a Guinness World Records record. Record-Breaking Skoda Does 1,759 Miles on a Single Tank Greatest distance driven on a single tank of fuel | Guinness World Records
  15. Guessing a Chrysler Voyager 🤷 A bloke I know here who has one, not sure what spec, but he uses it on the Autobahns a lot transporting antique furniture.
  16. Bingo... A C3 Picasso that seems to have had quite a hard life... Is version number one. Version number two arrives tomorrow
  17. 5Q0 and 2Q0 radars have different mounting positions and, consequently, different brackets. With the 2Q0, you would normally have to buy and install different brackets. The 3D-printed part saves you from having to do that, allowing you to use the OEM 5Q0 bracket instead. It’s a great solution from @Cairus.
  18. ****röen Picasso. Can guarantee that if you're in a hot country the AC will be on the fritz 🤣
  19. Lee01 replied to Lee01's topic in Motoring News
    25 years of the Superb https://www.irishexaminer.com/motoring/arid-41906230.html
  20. Ok there'll be two versions of this hire car as we've discovered the one we have which is named after a famous painter is falling apart and has non-working A/C which isn't nice in these temps and when we have a heat warning for 36 tomorrow. So we're getting an upgrade to an American Group F
  21. My DRL kit arrived from AliExpress so using a spare headlight for cheap I first removed the lens by taking the clips off and then warming the sealant using a hairdryer, Then removed the 100 screws and the plastic strip, which is clipped in place, I also removed the LED module, you can see of the old strip the melting that had caused the yellowing, Using the reverse of taking it apart put it back together and tested it, Good result, just need to clean the inside of the light and refit the lens with some new butyl seal which will involve baking the light in the oven once the seal is in place then squeezing the lens back on and refitting the clips. A small but satisfying win.
  22. Set of four alloys from a 2013 Skoda Superb Elegance. Part number 3T0601025E Style name Themisto Size 7.5J x 18 Offset ET46 PCD 5x112 Also the spare wheel with retaining nut and polystyrene insert. We bought the car as an ex-demo so it has always been always owned by us. In around 2015 we replaced the wheels and tyres with 16 inch steels as we wanted a softer ride. These wheels have been stored in an ISO container ever since. The car has now been written off so these are of no use to us. The tyres have reasonable tread and appear okay but because of their age (2015) it might be safest to assume they are beyond their serviceable life. There appear to be some minor scuff marks, but please judge the condition for yourself from the photos. We are in North Wales and I don’t want to courier these etc so be prepared to come and get them. £200
  23. Me too, but don’t tell anyone 🤫
  24. Yum… stickers for my tool box
  25. I had a similar issue with my previous mk3 facelift Octavia, the info screen would intermittently turn it's self on & off whilst I was driving. I never got to the bottom of it, but I found pulling the dash fuse (behind the glovebox), usually stopped it from turning on & off for around a month. I can't offhand remember which fuse it was, but it's within the owners handbook. Maybe worth a free, try. Mine turned off & on, less often than yours, mind. Still enough to drive me crazy when it did.
  26. I drive both my cars without consideration for MPG ( fabia returns circa 35 mpg, Golf returns circa 25 mpg) but I enjoy every mile (don't commute or do over 5k per year) rely on on fuel calcs in the cars
  27. Crucian started following Mpg????
  28. If you can charge with the ignition on then the microswitch on the gear selector has failed. This will not let you charge because the car thinks it is not in the Park position and you should get a fault on the app saying the parking brake is not applied. The total unit replacement is 12E.713.025.G and is in the order of £700. However it is possible to get a similar microswitch for about £5.00 from RS components or similar. This will need modifying and soldering to the printed circuit board once you have dismantled everything. There is a video on the VW-UP web site https://www.upownersclub.co.uk/threads/car-wont-charge-yellow-flashing-light-selector-not-in-p.14359/?nested_view=1#replies and a link to a video on how to do it. I did mine about a month ago and it is still working! Best of luck and get in touch if you think you need more details.
  29. Hello, long time lurker first time poster... I am looking for the software update for this. Could you help?
  30. chp81 joined the community
  31. OrvilleTheDuck joined the community
  32. Goodies arrived…🤪
