- 38 mph in 5th gear ?
Warrior193 started following 38 mph in 5th gear ?
1.9 TDi Timing belt kits
very disappointed to see the INA kits uses a Gates tensioner
Constant app updates
@thamestrader My Amundsen hardware is H22, and software 0276! But my dealer told me at the last service that there were no updates required. You could well be right that Skoda have forgotten about all the cars with early software levels as I also have problems with the map updates. Despite paying for the automatic map updates, the the map date is back in 2024 (although to be honest they seem accurate as I drive around.)
Engine mount bolts?
Cheers Pete. What do you mean "fasteners that are taken into the plastic region"?
Polle joined the community
the truth about electric cars
All along bad decisions by the Westminster Government and no Sovereign Wealth Fund and using moneys to break the unions (Coal mining etc.) Supposedly no Oil & Gas left and no way could Scotland be Independent. Licences change hands but the UK is not buying them back or buying them out. It is like Hospital Car parks that were leased to companies on very long leases and had to be bought back at great cost to the general public or tax payers. Sometimes for many millions.
- Elroq tailgate won't stay closed
Suspension upgrade installed
KYB KSC4260 and KSC4261 fitted. Need to get setup but they were a decent fit. Having done some research as they are the same spec as JRRS' Delphi suggestion, they are for Audi TT Mk3 (FV3/FVP). So you lose 6mm of track each side rather than 14mm with the Golf parts. The seems to equate to a little under 0.5 degree positive camber according to Google. While Google/Gemini is telling me this using pretty catastrophic language, I can still physically see negative camber on both fronts. I'll keep this and tyre-wear under observation though and see what the 4wa results come up with. Ironically, Gemini also suggests the Delphi ones that JRRS referred to, saying that, because they are for the Passat B8, they are wider as meant for the larger MQB-B platform cars. However, when I search for them specifically, they are suggested as a part for...the Audi TT Mk3. And no-one gives the bush centre-line to bush centre-line width measurement to confirm whether they're better or worse (even Delphi website). And if I search by model for Passat B8 (even the 280 equivalent Saloon AWD) you just get the black steel ones back at square one. And if I challenge Gemini, it admits that both parts are for the Audi TT Mk3 and that there is confusion sourcing this thread as a reference lol. For now, the TT Mk3 ones are on, feel pretty solid and just waiting for the final work to be done to get the ARB on and the alignment done. @MarioVrs how does yours feel now?
Agreed but it still makes zero sense at the current time given all the other stuff going on and with many countries and Europe putting plans in place for possible acts of aggression on the horizon. Each of the decisions taken if looked at in isolation, look defencible. Now piece together those and see the negative effect if a bad player wanted to destabilise a country especially an island solely reliant on importing vital requirements?
Geodiegeorge started following Elroq tailgate won't stay closed
Evolution13 started following 38 mph in 5th gear ?
redoor43 started following 38 mph in 5th gear ?
hi Everyone i have just recently bought the Skoda rapid estate which seems to have come with a few problems, one being when i start the car it idles a 800 rpm then when it gets warm it it get to 1000, and in 1,2,3,4 gear it quite normal then in filth it goes along on its own at what seems to be 38 mph as thought cruise control is on has anyone experienced this thank you in anticipation
redoor43 joined the community
P048a / p048f
Got the electric actuator off (luckily the valve in the exhaust isn't seized as it's in the middle of a long exhaust section so would be near impossible to get to) Arm on actuator doesn't move at all Watched some videos of them and it seems I should be able to move it by hand ,could someone confirm this ? Thanks
Rear parking break fault
Thanks for the info, Battery was changed about 1 month ago. I have cleaned around the connection and used the car yesterday with no problems, as you say could be just a electrical gremlin. If I get it again I will attempt to unplug it to check contacts.. Thanks for your help
The Crown estate Scotland & Crown Estate England, Wales & Northern Ireland. So not your's or mine. So the leases / licences need to expire. But the Rigs, pipes and other infrastructure is owned by others on that Crown Estate Seabed. The UK Tax Payers are paying companies to decommission rigs etc. ................ I know this stuff without the need of internet searches and have since 1972 when my dad started working for Bristow & family went offshore, then school mates, and i worked for a business doing offshore fabrication. It is pretty much a topic that comes up in the North East of Scotland all the time since it is a major employer in the North East.
- P048a / p048f
- P048a / p048f
Chinese rear differential
It depends on if they are made to oe standard or not and what factory they came from. Have had a few chinese parts over the years and some were excellent copies while others very poor. Problem is telling which is good or not as they generally look ok. Cylinder head for old toyota lucida which was excellent and a fraction of cost of toyota. Replaced a honda GX200 engine with a Loncin and they are identical. Even honda parts fit and have had no trouble. Got chinese carb for chainsaw and wouldnt run due to one of the fuel ways not been drilled out. Reckon with a dif I would be looking at second hand or at least a reputable supplier that you have some come back if it fails.
Alasdair1 started following Chinese rear differential
1.9 diesel fuel pump not working advice needed.
StevesTruck replied to Rsedmonds's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanOn the pump, look for a wire going into what looks like the middle of a 17mm? Bolthead. Did you find out if it was a D or SDI, or have you got the reg and I'll look it up?
I was aware that it is not operated by the UK. However, the fact still exists that the UK issues the licences to drill and extract the oil. So how is that possible that we issue licenses and collect tax on it unless we have a legal claim on it?
How can i tell what fuel filter i need?
imart143 started following How can i tell what fuel filter i need?
The oil and gas in the British sectors of the North Sea is not Britain's or the UK,s to have. The licences to explore and to extract have been issued to others. The treasury does tax it though. Norwegian and Israeli companies, and Canadian and Americans own the product. It was Russians and they sold them on because they had to. Natural gas from the North sea sold to the UK and arriving into the UK does not come via pipes owned by the UK. Eg, Centrica / British Gas. And as far as the Forties pipeline for oil pushed along by gas. INEOS sir Jim boy Ratcliffe and Petroineos (PetroChina) own it. And it's damn old. Below FYI & a quick read , best check things out & know what is what as things stand now.
ala3sam joined the community
Timing Kit Fitted by Garage, car now stumbles under power at lower revs.
If they were changing the chain at the service, they had to remove the spark plug wires. These wires eventually get burnt, and mechanics often pull them by the wire itself instead of the metal connector, which irreversibly damages the inner core of the wire. Also, the third wire (on the 3rd cylinder) runs close to the turbine and suffers from overheating at the factory and often breaks.
Falcon452 joined the community
- Chinese rear differential
