Past hour
Problem with humidity in the cabin and fogging windows
Check for a puddle in the spare wheel well, boot leaks are very common and the water gathers in the wheel well. I spent ages trying to eliminate the leak, never got rid of it completely. In the end I drilled small holes in the bungs in the wheel well to let it drain out.
chrisund123 started following Problem with humidity in the cabin and fogging windows
Is the oil service really needed ?
Hello everyone, I have Skoda Kodiaq 2019 and purchased all-in service 2 years ago but used both services and MOTs that were included. The dashboard shows now oil service needed. I booked a visit at Skoda authorised centres and they want me to charge £250 for it. Booked work is: oil change service complimentary visual vehicle check & video environmental disposal charge But when I purchased the all-in service - do I really have to go to vendor's service as the list above is actually the oil change service ? Any risk if I go to a garage next to me ? Kind regards Happy Skoda user
New11 started following Is the oil service really needed ?
Today
Octavia VRS 2.0TDI DPF Issues HELP
already checked it goes sit at zero, with the engine off, ash has been reset by previous owner and soot does clear up after a regen but it instantly fills up again after a short distance. currently at 17g measured soot and 2.4g calculated soot
Before condemning the DPF, check the differential pressure with ignition on and engine off. It should sit near zero. If it still reads 50 hPa there, the sensor or its hoses are offset and that alone can trigger constant regens. If it zeroes, get the soot and ash loads read separately before paying for a clean.
SteadyDiesel started following Octavia VRS 2.0TDI DPF Issues HELP
tim66 joined the community
A DVM (digital volt meter), left permanently plugged into the power point will show the charging pattern under all conditions.
Odd behaviour this weekend. I did road trip to Manchester from Ireland. The battery should have enjoyed as much charge as it’s going to get. Arrived at Holyhead today( Sunday). A few start stops while in the queue nothing too strenuous. When i got to the terminal waiting area the engine was turned off and i listened to the infortaintment system for about 20 mins. When i arrived back to Dublin a few more start stops as we were queuing for customs but everytime the car re-started it threw errors on the screen indicative of low voltage. The start stop system then disengaged. Usually the start stop usually disengages when the charge level is 60% but the indicated charge level was close to 80% according to OBD11 Sure enough according to OBD11 low voltage codes were logged. Also the voltage was 12.3v while the engine was running, the lowest i have ever seen. The impression i got was the battery management system thought the battery was more charged than it actually was for whatever reason i don’t know.
lt_corteztravels joined the community
Rieger Rear Diffuser?
All sorted! I'll try and get some photos up tomorrow. Mine was the gloss black version and fitted first time, after I'd given everything a polish. It did contact the boot floor, so to prevent any vibration-induced rubbing issues, I got to work with the dremel to get a few mm clearance. Probably overkill, but hey, it's done. The only other thing I had to do was cut down the four center screws - they were too long to be installed with only one (or even two) spacers, and would have cracked the plug insert. If I'm honest, the manual didn't really help much - I still think it's for a TDI due to the extra holes and steps it claims are needed! It looks good with the black spolier and black/blue badges. Seems solid too, even without the locking bits on the tangs.
Just remember AC or Climatic do not operate at 4 degrees C or lower.
Yesterday
SkodaElroq joined the community
In the meantime, if you have Climatronic, make sure the air conditioner compressor is set to ON even while the heater is set to your preferred heating temperature. Climatronic system then uses the cold air to condense out the water in the humid cabin air before heating it to your set temperature. This will at least clear your windows while waiting to find the leak.
ACC control
To Stonekeeper. That was a very comprehensive answer and in line with my own understanding of the Superb mk 4 ACC system. Very well done sir. Also to CNC. Thanks for the link to Dave sells Skodas. I have always found his videos quite informative. Thank you for your input. Keep it up guys. 😀
Stuartie started following ACC control
Yes. Red/white wire is constant positive feed to window motor. The brown/yellow is a switched earth that is activated by the door catch and tells the control unit when the door is open/closed.
I assume fitting rear puddle lights. You’ve tapped into the correct wires so they come on when the doors opened ? 😃
Jamiek started following Superb Mk3 Estate 190PS TDI DSG MY2015 SE L Executive - Moon White
Photography Thread
Took a trip to Donna Nook earlier 🦭 VID-20261129-WA0045.mp4 VID-20261129-WA0043.mp4 VID-20261129-WA0040.mp4 VID-20261129-WA0041.mp4 VID-20261129-WA0042.mp4
Hey guys, recently became the owner of a 2014 octavia vrs 2.0tdi. shes currently @ 292xxx Kms and I have constant regenerations and my differential pressure at cold idle is at 50hpa, normal should be around sub 10, and during acceleration @ 3000rpms tops out at 900hpa. im looking for advice to see if this car is worth investing into or if i should just get rid of it, it has a decent service history with the turbo being replaced at 202xxx kms but i havent been able to establise whether or not shes burning oil, theres no weird smoke or pressure coming out the oil cap and dipstick, turbo and dpf look bone dry - no obvious signs of leakage, exhaust is bone try and oil doesnt smell of diesel - just a normal dark colour. anyone able to recommend some checks for diagnosis ? ive talked to a few mechanics and all say the same thing, a dpf clean is only temporary if shes burning oil or has a bad crankcase breather its pretty much a full emissions system rebuild.
vaxny started following Octavia VRS 2.0TDI DPF Issues HELP
Fifth gear popping out (gearstick)
Hi all, 1.9 TDI 2005 estate. I assume all original parts for gear system. Started a couple of weeks ago on the motorway; the gearstick popped out of fifth and so the revs shot up etc. Put it back in and all was well (this is Newport to Tenby). On the way back started fine then again once we'd been going an hour or so, did it again. This time, several times. You can hold the gearstick and almost feel it resisting, like something wants to pop it out. Didn't need to use it subsequently around town once back home; gears one to four are absolutely fine. Had it booked at a garage with a two week wait time; they took it for a test drive but it behaved normally. I took it out in fifth for the first time today and it seemed fine too, though again after half an hour or so I'd say the gearstick 'twitched' in fifth (a small movement) but didn't disengage. Then was fine. Any ideas or anyone had this?
JamieH86 started following Fifth gear popping out (gearstick)
vaxny joined the community
Park Distance Control: please clean rear sensors - 2022 Octavia 1.4TSI iV
Evening, thanks for the info. Unfortunately my scanner is a basic one and does not read measured values in the parking aid module. Walking past the sensors does not make a difference as none of them are giving any indication on the car display. The display shows an exclamation mark for the rear parking sensors. See attached.
Add ons
Thanks I’ll have a read there’s a few things I’d like to do. The rear puddle lights make me think is it worth it as the loom isnt fitted
Boru joined the community
Add ons
Tacks, oil slick, smoke, spinning number plate, machine guns, ejector seat. Drop in a V12. Stick another one in the boot. Any of that work?
Add ons
Very much horses for courses. And skill dependent. I have done lots of bits and pieces to correct some of the age related issues with mine. In terms of retrofits I’ve added front parking sensors, reversing camera and upgraded to 9.2” infotainment screen. And a lot of other little upgrades too. I’ve also fully dechromed the exterior and added some other bits to match sportline exterior look. Full details of what I’ve done here: https://www.briskoda.net/forums/topic/537947-superb-mk3-estate-190ps-tdi-dsg-my2015-se-l-executive-moon-white/ Plans for future include: front bumper splitter and maybe pedalbox to improve throttle response. Longer term I’d like to lower it, add wheel spacers and/or maybe different wheels but that depends on the next few years MOT outcomes!
keywacat started following Reverse doesn't always engage on the first try
Nazdar lads; I've got a 1997 Felda with a 1.3 where reverse sometimes needs another try to engage. I had the tranny fluid replaced 2 weeks ago and of course that didn't solve my problem. I'm thinking the linkage might be the problem, is that what you more experienced lads would look into? Cheers; keywacat
- Skoda Octavia 2018 – MEN2_EU_SKGPX_P7381L Firmware Update & CarPlay Activation
ABS fault codes in VCDS but no warning light.
Yep, bit strange. I did the clutch reset thingy in between scans, and as part of that on the test drive did a couple of heavy braking / hard acceleration - it's looking like maybe I dislodged some rust or junk. I'll post findings if/when it returns. Thanks.
Wheel spin on moderate throttle
Get your wheel alignment checked, have a look for uneven tyre wear and make sure your pressures are what they're supposed to be, preferably with a proper tyre pressure gauge because TPMS isn't universally perfect.
Austin Allegro V6 Street sleeper project by Jonny Smith Car Pervert.
Part 13 is now online. http://youtube.com/watch?v=DadcHQc4hz4 With some amazing cars.
