Start/Stop ERROR on screen, mechanic suggest Injector
Stop-Start error indication is normal if MIL light is activated - as would Cruise Control unavailable.
Warrior193 started following Start/Stop ERROR on screen, mechanic suggest Injector
Hi from the Netherlands
It's a good forum full of knowledgable people..
Sofo started following Hi from the Netherlands
GPS ISSUE: Software 330 vs 332?
I disagree with a previous post that said Android uses the same data as built-in system. I believe your problem may be a faulty GPS antenna - is this vehicle a Kombi?
Warrior193 started following GPS ISSUE: Software 330 vs 332?
"WE BUY ANY CAR"
Is it worth that?
- Hello
Hello
What a polite person. Then I'll say a big HELLO! back to you.
- Airbag light after glovebox removal. VCDS in Ayrshire/Glasgow/Stirling to clear it?
Kodiaq memory seat coding?
yes to all positions - including second drive after first stop. dataset/parameters I dont know. not sure what I need to check and verify that. I have vcds and autel and I think somewhere I have a knockoff odis adapter but I've never done anything with that
Skoda Octavia scout TDI 4x4 DSG 2018 184HP
Yea I get you, also didn’t know it was a mk3.5, is it because of the infotainment system and headlights?
Flickering head lights
Thanks for the update pal, so it would be the 1 at th3 back that needs checking. My drl is working but not the main beam. I will swap over thr ballasts and take it from there.
Bobsko1 started following Chassis cover protecting fuel tank
The plastic underbody trim and rear chassis cover protecting the fuel tank fell off the other day. Part No. 5WA 201 429. I retrieved it from the street. I am not sure whether or not any of the fixings remain attached to the underside of the car. I assume the safest course of action would be to purchase a replacement part, (not outrageously expensive) but would it come with the appropriate nuts/bolt etc.? All comments welcome. Many thanks. Bobs
todor1963g joined the community
Any additional help guys? :) I've noticed that when in the garage, the problem is much more frequent and when outside, it works most of the time.
Folks, Fitted a new Android head unit (Yeti 2016), as part of process had to wire a USB to glovebox so removed glovebox and hence disconnected airbag. Must have turned ignition on to test as now despite glove box back together and airbag switch reconnected have airbag error. From research this is because if power ignition on with glove box switch disconnected it creates the error which must be cleared by VCDS as doesn't auto clear when reconnected. Tried basic ODB2 scanner but that doesn’t do it. Assuming the above it correct, please let me know if sounds incorrect, anyone with VCDS in Ayrshire/Glasgow/Stirling who could clear it for me? Any help much appreciated, Cheers, Alex
AlexW222 joined the community
MikeTheThinker started following Newbie saying hello 👋
HELP.All Warning Lights On At Once & Failure To Start
I would get it scanned as there is probably a code stored pointing to which abs sensor is faulty or could be broken wire to it. As said check voltage accross battery when cranking engine. 12.3v is 60-70% charge but if a cell is failing it may drop a lot when under load. Might also explain why it happens when rear wiper is on etc. Alasdair
- 23 replies
- 1
- mk3
- octavia
- start failure
- tdi
Tagged with:
Clean the pano roof sun visor?
Superb L&K with panoramic (sun) roof, and inner liner/visor. Insects and dirt have got in between, and I recall reading (previous model) a way of retracting the roof, but not the visor, so it could be cleaned. Anyone know if this is possible, please?
Very high bite point on Skoda Fabia 2 2011 estate 1.2 tsi (CBZA) 5 speed manual
Ahh, makes sense, hope this car won't have the same problem 🤞 No rust is really impressive, makes it worth keeping it alive and refreshing some components! Guess the car isn't a powerhouse, so can see where he's coming from, but it's nice that it still will get some use :)
Octavia MK4 MY2023 OTA update went wrong (03A8)
I felt the same, especially as I understand this update is a firmware flash and not a soft update. However in the end I did it, made sure the battery was topped off and sat in the car while it processed - seems to have been ok. But agreed, the quality of the updates and financial consequences when Skoda **** up the updates isn't really acceptable. I'm considering dropping it out to guest mode and no longer having care connect.
- Hello
Hobron joined the community
infotainment online makes voice commands unusable
I've got a MK4 Octavia with - I think - a Columbus infotainment console. I pay for care connect, and recently got a 12 week trial of infotainment online, mainly with the objective of getting a quick easy map update. Howver since infotainment online was activated voice commands continually try to connect to the internet; the result is they often fail, or at best are slow. Previously they worked quite well; I could ask it to play a particular album or plot a course with relative ease, but now it is a pile of ****e. Anyone else experienced similar or knows how to resolve it? At the moment I can't wait for the subscription to end, and I will not ever pay for it, guess you could say the free trial did it's job!
Inexplicable tyre deflation - no puncture, valve OK
I had a similar episode, took the tyre to a nearby tyre depot they took the tyre off the rim gave it a wipe around and fitted a new valve and inflated it no charge (slack day) no further trouble. There is of course the possibility that some twisted soul let the tyre down out of malevolence.
Pete's Rescue Roomster
No further trouble with alarm, roof blinds were gaffer-taped together for a while. Now fixed a little better, but still a bit bodgily with hotmelt glue fixing the four magnets in their correct orientation. Front two shown here: This has had the extremely welcome bonus of eliminating a very irritating buzzing/rattling that seems to have been the result of these magnets being loose under their plastic rivet fasteners. This has made me very happy.
@Alasdair1 I checked it now and it is around the range you mentioned. It is around 12.3 and 14.5 when running. I read a lot of comments that also the ABS sensor causes this issue, but what I noticed it, I could be wrong but when I use the rear wiper washer, or when wash the car or a lot of rain. I removed the rear cover to find a little leak which was fixed, but still the problem persisted. I already had the ECU changed 6 months ago. I ordered the ABS sensors and I will change to see what happens.
- 23 replies
- mk3
- octavia
- start failure
- tdi
Tagged with:
Scala factory sound system upgrade
Has anyone got or had a Scala (or Kamiq) with the factory sound system upgrade? I’m particularly looking for information/photos of the subwoofer/spare wheel/tool arrangement if anyone has that information please.
