  2. 5GE 810 773 B is the part number wirer refers to in his link.
  3. Seems like it is my turn to have this issue. It has stuck closed a few times before, but today I could not get it open... So i used some force, and pryed it open. The actuator rod actually came out, but pressing it in to test it, it stuck again in the closed positition. From what I can figure out, the correct part is 5GE 810 773 B. Is this correct?
  4. It is a little surprising, but just the way things are done in recent decades. The interference fit of the crank sprocket is sufficiently tight that removing the old sprocket may be considerably more difficult than fitting the new one. The tightening of the cam sprocket screw needs to be carefully done so that all the force of the tightening is against the counterholding of the pulley. Having the locking tools in place will not be a problem here, but the cam one particularly is an alignment guide, not a force resisting component. I would imagine that at 120k there would be minimal wear on the crank sprocket, so it could be left original if you struggle. I believe the majority of the wear in the system that is generally thought to be chain elongation is actually just wear of the plastic chain guides, which effectively shortens the path that the chain follows. So make sure those are replaced.
  5. Finding the source can be tricky as you have found out. Oil has a habit of defying the laws of gravity etc. Best option is to clean it up and see if you can trace where its coming from. If its a small area then a can of brake cleaner will do. If its over a bigger area I use Gunk and then power wash. Is it definitly oil and not brake/clutch fluid? Alasdair
  6. To post a topic/question/thread on the site.....this one is simple asked on someone else's thread. I also need to change my address.....as suggested.
  7. About 120,000. The reason I want to replace it (and thoroughly) is that it has been making the "normal" timing chain noise for years, but recently I think it has got worse - in particular, it isn't just noisy for 3 or 4 seconds after starting the engine, but seems to stay noisy until the first time I get the revs up. I'm hoping to not replace the car any time soon, so I believe I just have to do this before it's too late.
  8. mancube joined the community
  9. Thank you. It's interesting to me that they're free floating. I'm not a mechanical engineer, so I don't know enough to have a strong opinion, but I'm surprised that such a critical thing is done in this way - especially as I would think there is a lot of tension in the chain as it pulls the camshaft around against the force of the valve springs. I note from the procedure that when it comes to doing the second stage of the camshaft sprocket tightening (the further 90 degrees after the initial 50Nm), it doesn't instruct to leave in the crankshaft locking bolt and the camshaft clamp. So the camshaft sprocket bolt is to be tightened up purely against the sprocket counterhold tool, and the camshaft clamp T10414 is not in any way intended to hold the camshaft against this tightening - is that correct? It doesn't even say to check the timing again after doing the second stage tightening - so I assume there is no way that the sprocket can slip round a bit during that 90 degree tightening? Again, I want to not mess this up.
  10. All items available for collection from North Lowestoft Suffolk Skoda Bolero multi media stereo head unit. (CD player, MP3 playback support, and SD card slot.) Full working order. Part No: 1Z0 035 156F. £45. Silver and black main surround. Part no: 1Z0 858 069 DF Excellent condition. £25 Silver main surround. Very small scuff on front. (See 2nd from last photo). Part no: 1Z0 858069 RS £25 Bolero black stereo inset surround. Excellent condition. £8 Genuine Skoda octavia vrs Mk2 rubber boot liner. Great condition. See photos for measurements. VAG group car jack and towing eye kit. In polystyrene holder to fit in spare wheel well. Excellent condition. £40. Shell Helix 5w/30 oil and zip up case (to protect car from any leaks). Full bottle, never used. £12. Genuine skoda bonnet badge. Small scuff on surface. Part no: 1U0 853 621C. £10 Genuine skoda boot badges. Great cond. Part no. 3U0 853 621C. £10 VAG group 16 inch spare wheel and tyre. Part No: 1K0 601 027K. £50
  11. Today
  12. Yeah, I heard the other day watching an old(ish) John Oliver show. I will not miss it. I saw it live couple years ago when I was in the States and was utterly unimpressed ... far worse that in the photos, see it / touch it / sit on it ...
  13. leolito started following Cybertruck!
  14. Hello! Is it still possible to receive the update file?
  15. Try it, absolutely! You will get a feel for the different way the car behaves.
  16. leolito started following Is DCC important?
  17. Kristijang joined the community
  18. keviiow joined the community
  19. Wife managed to get her Samsung S23 into the wireless charger with the phone base flush with the charger surface, and still in its protective case. The phone then charged slowly, but commensurate with the claimed 15 watt wireless charger rate.
  20. Sabri joined the community
  21. farny2511 joined the community
  22. Yep, diesels are now less reliable than petrols and cost a fortune to fix. With all the emissions systems either petrol or diesel put out virtually nothing anyway, and the taxes on them are just money making scams, or at best virtue signalling, all the time driving UK economy downhill.
  23. Both crank and cam sprockets are free floating. You fit the crankshaft sprocket 'wherever it lands', then the cam sprocket and chain are fitted loosely. Locking tools fix the correlation between the shafts, then the cam sprocket screw is tightened to make the alignment permanent.
  24. Im gone anyway. Not wasting my time here anymore.
  25. I suggest all involved 'wind their necks in' otherwise people may find themselves taking a short holiday.
  26. People like you stop people like me trying to help others. Been here before. Wind your neck in. Your triggering me now I am drawing a line now, want nothing to do with you in future.
  27. Says he who is doing exactly that
  28. Nothing special about any of it. It’s you saying it’s not possible, all doable with enough time and effort. The point is, I can get the missing features working on the car one way or another.
  29. I have a 2015 Seat Toledo and my engine is a 1.2TSI CBZB. I will be replacing the crankshaft sprocket when I replace the timing chain and oil pump chain. This is the double sprocket that drives both chains from the crankshaft. I have downloaded all of the relevant official procedures that I can find from the ERWIN system. I cannot see any mention of this sprocket, but I believe it is the correct thing to do to replace it at the same time; it also comes in the HEPU kit that I am buying, which indicates it should be part of the replacement. I haven't yet got the kit, as I want to add all relevant parts and tools to my order. Therefore without having the replacement sprocket in my hand, I can't see whether it has any kind of keyway to align it correctly to the crankshaft. I have watched the few videos that I can find where this part is replaced, but I can't see details of the alignment. I know it is an interference fit, and I understand how to pull it off and press the new one on, including warming up the new one to about 100 degrees to make it easier, but I am nervous about the alignment of it, and the fact that I don't have any info available in advance, as I won't want to mess this job up! Any information, experience, or photos would be appreciated. Thank you!
  30. What is special about that? This is not the right place to figure out who has the "longer" one—or whatever else you might be thinking. The purpose here is to have a professional discussion on the topic. And do not underestimate the competence of the other users here.
  31. As I’m not allowed to mention other vehicles, you will never know. You my friend have no idea who people are on here or what they may or may not be capable of. At the risk of triggering, it seemed to work on my wife’s A3 MIB 1 to 2 retrofit recently. Never came with that system and all working as if it was factory fitted. Was a right pain swapping over the illumination LEDs from white to red to match the old colours
  32. StuMyl joined the community
  33. I used to retrofit LED headlights to T6 vans, I made my own looms and used genuine sensors lights and modules. I haven’t done an MQB platform retrofit so they may only have one at the back (that’s progress if they do) so I apologise if this is the case. If it reacts by going up when the load goes down, the sensor must be upside down. Try jacking the car up, does it go down then? If it does, that confirms it. I used my beam setter to dial in the basic setting first. Ah I thought it went to word 55 or 4B for the later LED type. Point taken re other cars. What I was trying to help with regardless of system, the input changes, and he is seeing a reverse action. Something is coded wrong or the wires are crossed. If he jacks up the rear of the car and the lights now go down, he will know it’s something crossed/upside down. If it still doesn’t move has the light reached its limit cos they set the lights without placing them in the basic setting first. They may have adjusted them to its limit stop, now it physically can’t go down when the suspension is deflected. Either way it’s not working and simply trying to help regardless of the system used, the principle is similar and simple. Should be easy to sort out.
  34. Good advice, thanks for the info.
