Fob dead locked out? What if?
If it won't open you're doing it wrong, or you have a different key style.
ms star started following Skoda Octavia Mk2 (2004 - 2013)
- Yesterday
OTA updates
Should be fine to go from 270. Click on the link at the bottom of my 3rd reply in this thread to get the software, then follow the process in my 2nd reply. Download, unzip files to root if a USB-C card. Download and update them one at a time. Let us know if you have any issues.
Kessy on drivers door not working
When my car was new in 2024 kessy on the drivers side was patchy. But the last 1.5 years it has been working flawlessly.
Auxiliary Coolant pump
Thank you so much. That was really helpful. I bought a Bosch replacement (the original was Bosch) but the new one is a bit smaller. Apparently Bosch has changed the design of the pump! It was good to know I was looking in the right place. The difference in size means the clamp doesn't hold it in place any more. No problem. The pipes hold it in place. The fault code is now cleared and all seems to be well.
Fuel smell - 2 days into ownership
Just noticed Hoping it was a simple Fix But I’m not sure Was in 3rd Half throttle and around 2.5k revs to 3k wasn’t smooth increase So think there’s more to it
That is possible too.. (response on other thread)
Petrol leaks 280ps
The sharp edge of the internal metal flap can drop into one of the notches or ridges on the underside of the nozzle when filling up,someone pushing and pulling the pump nozzle to get it out could displace the pipe from the seal over time
Stonekeeper started following Petrol leaks 280ps
OTA updates
Hi all, sorry to open this up again, and thanks for making these files available. Is there a way I can confirm if the files are suitable for my mk 3 superb? Screenshot below. Also on a slightly related topic, does anyone know if a firmware update will make YouTube available on Android auto? I hear it's being rolled out but I'm not sure if it's more to do with the phone app getting an update, or maybe my 2021 superb will never get it? Thanks John
jk89 started following OTA updates
Did think that But now wondering if it was the fuel cap not sealed properly due to the rubber part being up the filler neck
If the previous owner had consistently overfilled the tank they could have broken the evap system The EVAP system is strictly designed to handle fuel vapors. When the driver frequently clicks the pump to pack in extra fuel, liquid petrol flows directly down the vapor lines and floods the canister.
Stonekeeper started following Fuel smell - 2 days into ownership
Amundsen MIB2 Firmware Update
What is this 00:00 glitch?
- CarPlay crackling issue, software update fix?
negative_entity joined the community
Removed whilst I was trying to take a photo and workout issue
Petrol leaks 280ps
Mine looked like this I’ve pushed it down Hoping it was that which was causing my smell But what causes it to ride up?
RogueFabia started following Petrol leaks 280ps
Mk 2 skoda octavia vrs 2009 Cr manual
Hi what mileage is on the car now ? Thanks
Why is there no fuel filler cap in place ? Is that how you received it at purchase ?
Warrior193 started following Fuel smell - 2 days into ownership
All In - anyone cancelled shortly after having a service, did you have to pay extra?
I wonder if it's because the all in plan includes warranty so cannot be started until the warranty runs out?
I tried buying the Ain1 plan online in the 30 days before my Karoq was 3 years old but it wasn’t possible, my dealer tried on their system and they couldn’t set it up in advance either. Then a couple of days before the end of the 3rd year it became possible. I’d already had my Karoq MOT’d separately. I think Skoda are missing a trick here the All-in plan should include the first MOT when taken out in the 30 days before the end if the 3rd year.
Adaptive grille ahutter
I should have stated 1.5 engine & DSG transmission !
Rear Seat Release Mechanism Issue
I have this issue on my superb. Going to give it a go tomorrow to try and fix it.
Binx1310 started following Rear Seat Release Mechanism Issue
MikeTheThinker started following Wing mirror adjuster stuck/broken
jpokorny started following CarPlay crackling issue, software update fix?
jpokorny joined the community
Timing stuck at 38
Hope it cures it. Cant be as bad as my sons Fabia mk1 console bolts. Thought an hour a side maybe two turned into a day and a half a side!! but managed it with a lot of patience and releasol. As said hope it helps and cured prob Alasdair
What is the difference between a 40 kw and 50kw Skoda 1.3 mpi engine?
Some maybe by mistake give it 9.7:1 https://www.autoparts-24.com/engine/code/136m/15047/ (Note: While some technical databases occasionally round this figure up to 10.0:1 for late-model variations, the official standard for the Škoda 781.136M high-output block is 9.7:1) Although https://www.ultimatespecs.com/car-specs/Skoda/5623/Skoda-Felicia-13-MPI-68.html https://www.scribd.com/document/956290892/Skoda-1300-Manual Compression Ratio 10:1
It's 10:1, it's literally written in the pic which is official material from Skoda. Anyway, I forgot to write translation of non-obvious terms in the picture, relevant to the valve timing: Saní otevírá před HÚ - Inlet valve closes before TDC (top dead centre) Sáni uzavírá po DÚ - inlet valve closes after BDC (bottom dead centre) Výfuk otevírá před DÚ - exhaust valve opens before BDC Výfuk zavírá po HÚ - exhaust valve closes after TDC
Got my superb estate 2 days ago Filled up with £50 on weds Came home could smell fuel Same again yesterday Got home from a trip and could smell fuel Noticed a wet patch on my fuel tank Went to the garage today They inspected it and said there is no active leaks They had it in a garage with the doors shut and running and couldn’t smell anything But when I’ve had it back this evening Absolutely stinks Soon as you open the fuel flap it’s as if you have your head in the tank It’s so strong Did a few searches and there’s tons of info online One think I don’t know Is There seems to be a gap between the plastic and the fuel filler neck Is this normal? Also just pushed the rubber boot back down, would this cause the fuel smell? Or can it be pushed up with tank pressure? Possibly from a faulty evap or n80?
