Past hour
Skoda Superb IV 1.5 TSI iV PHEV β DSG hesitation / jerking at low speeds. Has PV5 update fixed it?
I have mine Superv iV 1.5 plugin hybrid since Sep 2024. Had jerk problem snd they have replaced mechatronic in the gearbix.. However, there is till an issue which is very annoying. I wonder if you observe the same - with auto hokd On, stop the car and wait 10-15 seconds. Then press accelerator to drive - just like in normal traffic. In my car there is a strong jerk - even when accelerating slowly. . Surprisingky, if car was stopoed for just few seconds - there is no jerk and car is tarting to move smoothly. At dealership, they were unable to fix tthis.
What have you done to your Kodiaq today?
Itβs crazy how time flies. We are now down to just one child seat and our eldest is just 3 years away from the age at which my wife and I met!
Phone symbols on infotainment screen.
There's only one phone linked to the car. There's no difference if my wife's phone is in the car or not, it still normally shows the digit 1. FP
Hi, I've removed the last kid seat of my third child π. And 2027 should be time for the older one to start driving our car π±. A new step further in the family life. π
Today
I get this once in a blue moon, particularly when starting moving from cold - hasnt happened for a little while but when it does it's one big jolt then everything fine. On a early 2026 1.5 L&K combi. Haven't had any updates.
Octavia Scout with emerging oil issues
At the start of a potentially sad journey with my Octavia Scout. Bought it second had six months ago, all looked to be going well, very well, until the glow plug light came on and the car went into limp mode. Took it to a garage today who recommended a specialist as his diagnostics showed a blocked strainer. He said a couple of disconcerting things including '[sharp intake of breath] what's the history of this car?', and 'It's got two brand new oil sensors'. Taking it to a specialist next week to have the sump removed and the strainer checked, but feeling like there are enough small red flags to show I might be in for an expensive pre-Christmas period. Anyone have any similar experiences here or can offer any advice?
Fortress53 started following Octavia Scout with emerging oil issues
Garage Labour Time Per Job....
I can do one in about an hour and a half on most VAG cars without rushing, I'm not a qualified mechanic and that's working on a jack on the workshop floor. I'd be seriously impressed by anyone who hits the 30 minute mark. I'd say about an hour per side. Bear in mind, labour rates have gone up a lot in the last few years.
Squeaky door fix
After 18 years of Skoda ownership I thought I could sort all the little annoying noises. Each Octavia, Superb and Karoq has had its own rattle or quirk. Both of my Karoqs have developed the same binnacle rattle in the cold. However I was stumped by my current car's squeaking driver's door as it opened or closed. Door strap and hinges hav been coated in grease and silicon spray etc to no avail. My friend has a new Karoq SEL and immediately knew the source. On the door's bottom inside edge is a black rubber strip, it's front tapered end runs along the door sill. A dab of grease stopped it.
Redboy started following Squeaky door fix
MIB3 Preh β VCRN Showing 1234 on All FECs β What Could Be the Cause?
I noticed something interesting. In the standard FEC details menu, the VIN appears to be incorrect, or as you mentioned, it may be hidden by the MIB3 system. However, in the MIB3 Engineering Menu under Activation Keys β Activation Key Details, the VIN is displayed as a hexadecimal string. When decoded, it turned out to be my actual VIN. It seems the unit knows the correct VIN but simply doesnβt display it properly in the standard FEC menu. Unfortunately, I couldnβt find the VCRN on this screen either. I wonder if the actual VCRN would also be displayed correctly here if it were available. You mentioned earlier that you might check this screen on your Preh MIB3. I was wondering if youβve had a chance to take a look. Does your FEC details page look the same, and is the VCRN hidden there as well?
Fortress53 joined the community
Elroq Vrs Road tax.
As a diversion - I'm going to pay much less than the advert - for a new car on PCH. But I'm not in a hurry. Just a thought.
Cairus's Leon FR
Do you have two phones? Maybe answer is: "The number 1 or 2 indicates which device is connected in order. Ε koda infotainment can hold two Bluetooth devices at the same time."
zzeelljjkkoo started following Phone symbols on infotainment screen.
About an hour per side for the CV boots then more time to check the alignment. Thanks. AG Falco
AGFalco started following Garage Labour Time Per Job....
All Terrain tyres non AWD.
Don't think you will find AT tyres in that size. If it is through the tread there is a possibility of a puncture repair. Thanks. AG Falco
Lound chiming and flashing white car image
Thank you. That sounds like a logical explanation but it wasn't open. Could there be a reason why the warning system thinks the boot is open?
- Ε koda Approved Used β should outstanding scheduled maintenance have been completed before sale?
JD52 started following Lound chiming and flashing white car image
- Activating SmartLink on Swing 3
It sounds like it was telling you that the tailgate/hatch was open.
daveo138 started following Lound chiming and flashing white car image
Ashbe89 joined the community
It's possibly the so-called safety system warning you of some danger it imagined.
I was driving peacefully along when a loud chiming started, along with a flashing white image of the car body which seems to be highlighting the rear window. This was 5 minutes into a journey. My fuel range was showing 210 km. I stopped and turned off and checked that all the doors and boot were closed. They were. I started up again, same thing. Any suggestions? Thank you.
Passenger side mirror wonβt unfold
Just scanned for fault codes and got a few come up. It feels like it tried to move a bit but is stuck. Will try to take cap off tomorrow and see if I can see why itβs stuck or anything obvious.
Snow socks
They would only be used on snow, have had chains before so no difference . Car and hence tyres are new and donβt intend to buy a new set of tyres yet hence looking at socks in case they are needed. Last street we lived on had speed humps on a hill and when the snow froze they were e impassible unless you were going so fast that it was dangerous.
LongDitton joined the community
Coolant warning again
The Toyota and Hyundai will have had closed pressurised coolant loops with a separate system. one for the petrol system and the other for the power control unit, inverter / converter. The hybrid battery with Toyota and Hyundai uses cabin air cooling.
- VCP
- S3 owners - electric tailgate / hatch closing from inside
