  2. For recoding you can do this easily as a diy job using an app called carscanner and an obd dongle for about £30.
  3. Binx1310 started following Start Stop Stall
  4. Heron91 joined the community
  5. Buy from skoda-parts.com is the right way to go never had any problems with the parts or service contitech belts are the OEM prodùcer for Skoda and INA tensioner are OEM If you can freely spin the tensioner òr the idler pulley they need replacing as there should be slightly difficult to spin
  6. ian-inhome replied to ian-inhome's topic in Skoda Karoq
    Thank you for the reply mumpsim. That is all as clear as mud. I can't see many average owner making use of that feature
  7. Thank you Alasdair. Will call Kennys Monday for a quote. Graham.
  8. lui19 joined the community
  9. I have pretty much the same issue, from another post I have the impression changing the battery should solve it. I've bought a 2017 TSI around 18 months ago but no idea of battery age. I'm now slightly concerned your stop/start issue has returned with the battery reported in good condition. I'll keep looking for answers on the forum, so far I understood it was an issue caused by a failing battery (AI search also suggested this), your experience is making me wonder if there's anything else causing issues.
  10. Hello, I'm new to Briskoda and I'm having the same issue, stop/start doesn't operate at all until I have driven for quite some miles, operates normally then suddenly after stop/start driving the engine stalls when the system tries to restart the engine. The central info screen says restart manually but takes several attempts to get engine to run. Even attempting to rev it doesn't appear to help, it just brings up a comment on the info screen that I'm wasting fuel! From the sound of your postings, I need to replace the battery and have the system recoded. Thanks, your post and the replies are exactly what I have been searching for.
  11. I'll also add that the whisling noise doesn't change whether the tank is full or empty, same when the fuel tank cap is closed or open.
  12. I'd like to echo Pete's comment. Hope you're going to stay for the chat 👍
  13. Today
  14. Chalmers garage inverness havent used them for years but heard there still pretty good. You could also try ROM garage walker road just along from them for another quote. My old mechanic garage owner Robert brown when he retired put his customers there as he reckond they were good. Did my MOT a few weeks ago and very helpful old school garage. Another to try is Kennys autos on seafield road. They are vw/skoda specialists and have a good rep. Alasdair
  15. JFH joined the community
  16. KedarCZ joined the community
  17. What follows is the result of a AI Overview based on a GOOGLE image-search using the image in this topic's original enquiry. The Volkswagen T-Roc Forum and Skoda Kamiq Forum references come from these links https://www.trocforums.co.uk/threads/number-indicator-at-top-of-infotainment-screen.3387/?utm_source=google&utm_medium=organic https://www.kamiqforums.co.uk/viewtopic.php?t=149 (As my religion prohibits me from using a smartphone in a car, I've no idea if the above information is correct.)
  18. I'd love to know what that means. I have my doubts that they'll even have opened it. Who checked the chain timing and how? There are two aspects to investigate; crank to cam, and cam to cam. Cam to cam can be readily checked DIY from above, crank to cam is a bit trickier.
  19. Our Karoq 1.5l petrol 2018 60000 miles went for a service this week. The report said "Vacuum hose off inlet manifold has damage to connector and will not clip into place. Advise this is replaced". Car seemed to drive as per normal with this 'failed' part after service The part has now been replaced - separate visit - part details off the bag are "5Q0 612 041 BM Brake booster vacuum hose with a non-return (check and pressure sensor". So I am wondering how often this part fails and requires replacement? Perhaps this connection tab suffered from plastic ageing? Does this part require disconnection as part of a normal service which included the spark plugs so the plastic top engine cover has to come off, etc.? Photos below/attached: old part on the drive which shows is wiggly shape - yellow arrow indicating failed connector offside of engine bay with hose identified in red nearside of engine bay with hose identified in red. Yellow arrow indicates failed connector failed connector, shown with red line - the 'push' tab seems to have broken and is missing non failed connector with green showing the bit of the tab that has come off
  20. That's the bit i'm after - the 4 digit code for the key blade - if it's stored somewhere I must be able to request it right?
  21. Good luck Dave, hope you'll not disappear completely from here. 🙂
  22. After 27 years of Audi/Skoda ownership I've deserted to Toyota and a new RAV4 GR Sport.
  23. Latest info looks like this one "1.0l petrol engine with start/stop system , DKLD,DKRC,(7L6) From November 2019" Only difference is in cars with adaptive cruise control where the green/yellow wire goes somewhere else: * For models with no adaptive cruise control (ACC) *2 For models with adaptive cruise control (ACC) Not totally clear to me whether that extra connection is instead of the one to the BCM or as well as; the former I think. J533 defined as - J533 Data bus diagnostic interface. Does your car have ACC?
  24. Put octavia mk1 breaking into ebay and came up with a few. Not sure on 9102 colour but theres a 1.8 vrs on there with what looks like good passenger wing in silver https://www.ebay.co.uk/itm/116190808688?_skw=skoda+octavia+mk1+breaking&itmmeta=01M7ZE485CMYGCK3NGT778AVY9&hash=item1b0d830a70:g:~yMAAOSwLppmTc24&itmprp=enc%3AAQALAAABACHNgUiiE%2FjQhlDTaMiAde%2FME5jbBWz7MU%2BzjpBQSDwKFqcEKz7KvJMpF4w9SKFTcEy4enazCzUrEgrcOScYP9nyuI9O2hv3O57u%2FF5%2BswkaCzE2DbYLDfxt5c9LZ6GZUU%2Bciz2Ax88hX430uJ9u24F6zSAFq8bkuqsFP9vi7GspmWU7w7xiRQnuiEf0SJv%2BrEzSdv7QQgxZqm%2BTZ0RFSzLOHq6ntsIXDR9GDVPfa3fUqKLcGHRdBtY8ZK0OLrdyI1R%2FdYz1mszXTqQnKh6d5Y6s0zq7qXTisizMqAuCSwBPku%2FKVP4Vk8I5g33mzkeqGhCgcTmQ3TEh4j5hSJJBiv4%3D%7Ctkp%3ABk9SR4SDke6_aA A few others but nothing in silver. Alasdair
  25. Which engine? Htp 6 valve, 12 valve or something else?
  26. Hi, thanks! Do you know if updating to SW 0742 fixes the Android Auto connection issues with the Samsung S23+? Also, can you confirm that 0741/0742 is compatible with HW 033?
  27. this is a known issue on kamiq/scala/Fabia 4 with the clutch master cylinder make sure you get the latest part number wich is 2Q0721405C . if you go with OEM, you also need the plastic pin 6R0721152 and the seal 6R0721410 If you choose the SACHS M6284600775 , the part has already all the hardware needed
  28. Where can I find my latest software info update on my 1. 5 tsi infotainment system and what should it be. I have done a search but can't find it. Cheers Andy
