  2. I’ve returned to standard wheel without paddles as the airbag fits properly. Now got this one for sale!
  3. Dunno? It's only done 72,500 miles and the bearing itself was absolutely fine. No roughness or play. The ring doesn't appear to be bonded to the bearing in any way at all. It's just held there by its own magnetism. I can peel it off and stick it back on anywhere. No evidence of any kind of adhesive behind it? I'm hoping VW have done their sums properly on the three screw fixing. just intuitively, it doesn't look like a bad arrangement. There's a spigot on the bearing housing that locates into the upright. I imagine that and the friction from the tightening torque, will take most of the load, rather than the screws themselves?
  4. Another query along same lines - is a dsg diesel skoda better or worse for towing than a std manual diesel ?
  5. Yes, ticking time bombs, they will consume the wheel sensors though while breaking up. The wheel sensor ring is a series of small magnets, so the sensor reads them as pulses as it is a Hall Effect sensor. Edit:- I blamed the failure of the RHS front one on my 2011 Audi S4 on the fact that the bearing was not "handing out" any oil/grease to that area so rusting was to blame, in your case it looks like it is a crap bearing manufacture that is to blame as there is very little sign of serious corrosion - and so that maybe bonded on, series of potted magnets, has started to de-bond from the inner face of the bearing and end up lifting up into the path of the stationary ABS sensor "arm". I'm surprised that a car of this size has just the smaller version of wheel bearing, ie the 3 screw fixing version - maybe that's "progress".
  6. As previously mentioned, unzip the files and you will have 2 folders and the info file. On GPSpower.net you will find the latest version of maps, version 450. Click the link for Columbus and install after unzipping of course. Speed camera files can also be downloaded from there or on Briskoda. Not forgetting Radio station image files too. For Firmware there is a very good guide in this very forum under "guides".
  7. Replaced original wheel without DSG paddles today. I hardly used them and I would rather a proper fitting airbag!
  8. Cool thank you. Not many options looking online! 👍👍
  9. ^^^ No you need to have them fitted. I broke the valve top off of one on my EV, not a Skoda, i got a repair valve and it coded it,s self and then the sensor stopped working. For the MOT in the UK this month none of my pals could code it, so i went to Halfords Tyre Centre who take £100 to fit a new one. The MOT station i am going to is charging £80 to fit one before the test. You have to be extra careful when you have the TPMS Sensors / Valves fitted, i broke one once before on a BMW and it was £150 to replace.
  10. Today
  11. That would work (if it isn't faulty), but up and down would be reversed relative to switch movements. Can be swapped back by rotating the metal motor housing 180°.
  12. Changed the front brake discs and pads this morning to try and finally cure the brake wobble. Seems ok so far but let’s give it 200 miles or so to reappear like it did before. All went without drama using the excellent @Bap33 guide Here. I also swapped back to my standard wheel without paddles. For the small amount of instances that I used the paddles I would rather have an airbag that fits properly!
  13. Changed the front brake discs and pads this morning to try and finally cure the brake wobble. Seems ok so far but let’s give it 200 miles or so to reappear like it did before. All went without drama using the excellent @Bap33 guide Here. I also swapped back to my standard wheel without paddles. For the small amount of instances that I used the paddles I would rather have an airbag that fits properly! So if anyone wants a round leather wheel without DSG paddles that fits the newer style airbag, I have one for sale!
  14. No, they're different fasteners. There are three smaller screws that hold the bearing pack to the aluminium upright. Those are "a" - the "70 Nm plus 90 degrees" ones. Then there's the big M16 x 1.5mm screw that goes through the wheelbearing and into the end of the driveshaft. That's "b" - the "200 Nm plus 180 degrees" one. To be honest, both felt "about right" when I was tightening them.
  15. @dejvic when the unit works, are you able to modify sound level from steering wheel? Are the buttons illuminated when you turn the lights on? @olnime you have download link in PM
  16. @Breezy_Pete I read after you mentioned. But there is no sensor which send info to car's system.
  17. Wheel alignment was a long way out, may explain tyre wear. Replaced with Goodyear Eagle F1, will see how they get on.
  18. Hi, I have just bought a 2020 fabia with the same CarPlay problems, could you please send me the firmware? Many thanks
  19. Hi, thanks for the advice so far. Does the motor need to be a skoda one? Can find a vw but code is slightly different. But for drivers door. Image attached. Thank you
  20. Make & Model: ŠKODA Octavia scout 2.0 TDI 4x4 184hp Colour: Not exactly sure Mileage: 27635 Price: £14000 open to offers Description: Private Sale. Not owned for very long, an ex police administrators vehicle. Great car with super low mileage, has cosmetic damage which is reflected in the price. Dent on drivers door , bumper damage and requires a plastic trim and wheel arch. Condition: Used Service History/Receipts/Recent Service work: Police service history, recently had oil service for my own piece of mind however no receipt unfortunately. Extras: Not sure if these are extras for the scout but heated seats, heated steering wheel, front and rear sensors etc Mods: None Shipping: Collect only Collection: Yes, from manchester
  21. Is it possible to downgrade via USB, so install the version beforehand? I would say that Skoda failed the update if it is not an isolated case, the visit to the workshop would be pointless
  22. Aftermarket TPMS system is usually stand-alone, with its own, separate display. OEM system is integrated into vehicles infotainment system.
  23. @pab567 I saw you have been a lifesafer for quite a lot of people by now! I would appreciate if you could help me as well, since I'm looking to get the 6276 firmware somehow. Skoda Supberb 2014, C14 Columbus. HW: H23 SW: 6270 Part-No.: 3T0035686H. Thanks!
  24. olnime started following Firmware 6276 source
  25. Hello and welcome Owen.
