  2. might be coding of controller. you should be able to see this with OBD11 and compare to mine. I have no idea if it will be directly applicable but could be a good place to start.
  3. Yassou joined the community
  4. Sensor is working and change values after car is loaded. There is no fault code. Lights are working for sides, but no decrease the snop of light.
  5. Mine is 2016, no DCC. Headlight part number ends in A. Corrector part number 7P6907357D. Long coding is 06DE00003F010000 if that helps at all. Could it also be a faulty level sensor on the back axle? or would that give a fault code?
  6. You can get a hair dryer or heat gun and gnetly warm the area. it will hopefully soften the clips etc to prevent snapping in the cold eather. they can be a bit awkward and stiff but you pull straight forwards in line with the car, not at the angle the trim is at. That seems to be the main issue. I am assuming it is pre-facelift. I am not sure how the facelift ones come out.
  7. Skoda Superb 3 2016, i don't have DCC. Is it possible to do anything with that long coding with OBD11? Regards, Arek
  8. Hi all, has anybody got any experience/advice on how to reset/fix jerky gear changes at slow speeds, affecting both up and down shifts? I.e crawling in traffic speed or slight downhill low speed prompting a gear change is very noticeable, whereas normal acceleration is ok. Any tips greatly received as all changes used to be very smooth. 20month old 2l Diesel with 40k on the clock. TIA. :-)
  9. Ccc1 started following Clunky Gear Changes
  10. Link to donwload MST2_EU_SK_ZR_P0480T sent in PM
  11. So the crash repair is the most likely issue. Might be a long coding issue which tends to tell the car which items are installed. If the car doesn’t think it has self-levelling headlights it might not be listening to any level sensor if that makes sense. What’s the make model and year? And do you have DCC?
  12. Today
  13. Do you still have the VIN? I don't know how the Irish MoT system works or if you can search by the VIN on the Irish website. Maybe @olddog can answer that?
  14. You might ask for @pab567's assistance.
  15. I’m not sure either , i found out that you can fill out a form through the council and find out from them and they will tell you certain details about the car like who the last owner was and what not but you have too prove too the council why you need such information and you need a reasonable yet valid excuse and I’m not sure me saying i just wanna buy the car back is reasonable and valid enough
  16. Might have been. Depends if the owner informed DVLA it was being exported then didnt export it or DVLA records are wrong. Not sure how you would check without v5. Alasdair
  17. I've not come across the word gettered. Is that where the inside of the bulb's glass is covered in evaporated filament? The bulb failure monitoring electronics in the BCM should be quite sensitive, yes. Bugger all to do with the CAN bus though, the bulb clusters have no connection to it.
  18. https://ebay.io/m/62Kr39 Once again will do a discount for any Briskoda members
  19. Need to get underneath it. Think the pipes are around 20mm internal diameter. About to try something this weekend. Will update you if it works
  20. So would you say it’s been moved out of the uk ?
  21. The Export Marker is on DVLA MOT status check under vehicle details. Its usually added to vehicle details if its being or been moved outside UK. Alasdair
  22. I’m not sure what you mean by what you have said , i just hope the cars still somewhere in England sitting somewhere rather than in Europe sitting somewhere i just hope i can buy it back
  23. Back then ye were still in the EU. Lots & lots of used UK cars were bought by people in R of I ( driving on same side of the road 'n all that ) Is it at the back of some farm, a mile or two from Ballygobackwards with a bale of straw in the boot ? .....not a joke.....I bought a '02 UK Elegance estate in '08 'n still have it here on The Emerald Isle
  24. Hello, I'm asking for your help because I've run out of ideas and am starting to lose hope... Recently, I've been driving my Škoda more often at night, and I've been getting countless "flashes" from oncoming drivers. I decided to investigate the issue because the headlights were not lowering their beam when the boot was loaded. Here is the situation: The headlights perform their self-test when the car is started (right, left, down, up). The headlight motor tests are completed without any problems – the motors move the light beams both up and down. Basic Settings for the headlights have been performed, and there are no fault codes. The sensor reading is 46%. When I load the boot, the sensor reading drops to 41%, when two people inside it is 42%, and go back to 46% when empty.... Unfortunately, the light beam moves upwards, and no downward correction takes place. :( I'd also like to mention that the system was working correctly 6 years ago when I bought the car, and I was really impressed with it at the time. Two years ago, I was involved in an accident. The car was repaired at an authorised Škoda service centre, and both headlights were replaced with brand-new genuine units. Additionally, I've noticed that I cannot enable the DYNAMIC CORNERING LIGHTS option in the car's infotainment settings. It switches itself off again after a few seconds. I would really appreciate any help, suggestions or advice you could offer. I'm running out of ideas and would be grateful for any pointers. Thank you in advance!
  25. AroCz joined the community
  26. Nice to have would be my thoughts on this. My 2016 L&K 280 had DCC as standard & I use it quite a bit. I normally run the DCC in Sport mode (fairly stiff setting) but with the DSG in normal D mode. If I hit some bad road surfaces then I change DCC to Normal or possibly Comfort mode for a more compliant ride. I also do this when I have passengers in the car that might not appreciate the stiffer setting. Comfort mode does make it feel very "wallowy" though so I can't run it that mode for too long without feeling a bit sea sick!! As others have said the only downside will be the cost to replace the DCC shocks vs stock dampers. There are some after market DCC damper options now so you are not suck with OEM only. Touch wood, after 10 years my DCC still works fine.
  27. M@G joined the community
  28. Hi all. I've watched the vids that show how to pull off the trim pieces next to the fog lights, but mine seem to be stuck fast. I really don't want to yank on them too hard in this cold weather & risk breaking any of the securing tabs. One of the vids I watched the guy did just that & broke off the securing tabs when pulling on the the trim with a pair of pliers. Other owners have used their fingers but mine are not budging. Apart from the extra chrome bits, are the L&K front fog access trims different in the way they secure from any other models? Are there any hidden pry points etc? If anyone's got any ideas where I should be prying / pulling & with what tool to help get these trim pieces off I would much appreciate any info you can provide. Cheers.
  29. I have it fitted in my 280 but I never change anything, I just use the default setting……normal?
  30. JD52 started following Bulb Failure Warning
  31. The system is pretty sensitive. Pinged up number plate light on mine. Both were working but one had slight corosion. I assume it senses a difference in resistance. Alasdair
