  2. On 8 October on @Sklinda's original enquiry about her car's behaviour, you asked her whether the car's motor was a TSI or MPI type. You asked again on 13 October and her reply was "It's an MPI". (And. of course, she said "mpi" in this topic's title.) I can't see any persuasive reason to think that @Sklinda's reply might be incorrect. But, if she has any doubts herself and has the vehicle's EC Certificate of Conformity, her car's motor's maximum net power will be shown at 27.1 on the Certificate's 2nd page and, if it has the MPI motor, the entry will read 59.00 at 6300 As the TSI motor has a turbocharger, there are visual differences between that motor and the MPI one - but I can't find any online images of the engine compartment of a Fabia Mk4 that has the MPI motor that could be used for easy identification purposes. Using' logic,' if @Sklinda's Fabia Mk4 has an a DSG automatic transmission or a 6-speed manual gearbox, then it must have a TSI motor. But, if it has a 5-speed manual gearbox, then it could have either a MPI or a TSI motor.
  3. Hello, brake lights have stopped working on my Fabia Elegance MK2. Both bulbs are fine. Brake light stip on top of the boot door has never worked. Would appreciate how I can these working again, many thanks.
  4. D1ckieBoy started following Brake lights
  5. What you need?
  6. The upper and lower rear spring seats are the same for lowered ride height, standard ride height, and increased ride height. Rear stop buffers 3C0511359B is the rear 118mm buffer for lowered ride height 3C0511359 is the rear 133mm buffer for standard ride height and increased ride height LLLPARTS has a superb mk2 parts diagram, but their security system can make it difficult to enter. If so, then access the website using "https://www.lllparts.co.uk". Then you may have to press the refresh button. Then enter "https://www.lllparts.co.uk/catalogs". It should be plain sailing from there. The lowered ride height front springs are about 10% to 15% stiffer than the standard ride height front springs, so it might be better to go up two in the hierarchy with the standard ride height rear springs to 3C0511115AF. Sachs 994 364 matches 3C0511115AF standard ride height rear springs. Bear in mind that some owners find the standard ride height rear springs on the Superb MK2 to be on the soft side, especially if a lot of weight is carried in the back.
  7. Will find some time and we need to talk 😊
  8. Today
  9. https://a.aliexpress.com/_EvvwEfk Works like a charm!!!
  10. Just got a warning letter for a Seat Altea XL 1.9tdi. Its been sorned for four years and is 2008 plate!! I am supposed to contact Seat for repair. Thats a 18 years old car. Will need to fix brakes,wheel bearing,EML and a list as long as your arm for an MOT so I can take it in to get airbag replaced? By the time I did the above it would cost me more than the cars worth. Only reason I kept it was its the same engine as my old Skoda plus other compatible parts and thought when I have time might fix it. Wonder how long I have got to get a free airbag. At 18 years old I doubt they would go off anyway. Alasdair
  11. Acapop joined the community
  12. I expect this is a case of 'the newer the car the more intrusive and unavoidable the safety features get'. You won't like the solution of changing it for an older car, I suppose.
  13. I have 75 reg 1.0 Monte Carlo auto. Almost every time I drive the car the "Lane assist" feature switches on at low speed and cannot be turned off. I thought the lane assist wasn't supposed to kick in until you were driving at 30+ mph and that you could disable this feature if you didn't want it. Mine cannot be switched off and comes on at very low speed. Has anyone else experienced this problem and is there a solution?
  14. I got the same for SWMBO’s CitiGo.
  15. Elivum joined the community
  16. I think that’s the issue, just looked at both parts and the base is very slightly different, I think Skoda main dealer gave me the wrong part, car is a 2015 model, the part I got looks like 2016 onwards model. I’ll have to go back to Skoda.
  17. Bet
    Bet replied to Bet's topic in Skoda Fabia Mk4 (2021 > )
    Scuttles are clear, it's been suggested that it could be linked to a damaged windscreen wash pipe problem
  18. The blower isn't working on my wife's 2012 Roomster but as its a Fabia in disguise I thought I'd post here. I'm resigned to a bit of work to get access but need to know if there is a difference between the blower on cars with the Climatronic system and those with the basic 4 position rotary switch for blower speed. Thanks for any advice.
  19. Thanks again for your help. I've found a very good deal on two SACHS 994 337 standard-height rear springs (1K0511115DE) and two SACHS 311 346 rear shock absorbers (3C0513049CP), costing Β£140 altogether. I'm leaning towards this setup now. Do you know whether the GreenLine and standard-height rear suspension use the same upper and lower spring seats, bump stops and shock absorber mounts? Are there any other components I would need to change when converting the rear to standard height whilst retaining the lowered front suspension for the time being?
  20. Timsskoda joined the community
  21. Both the Octavia MK2 Scout and Octavia MK3 Scout use oversize tyres, eg. 225/50R17 instead of 225/45R17. So if you use 225/45R17 that the non-Scout versions use, they will be undersize, ie. have an outside diameter that is too small...as shown in the chart below. Outside diameter of tyre 225/45R17 634.3mm (3.4% smaller outside diameter compared to 225/50R17) 225/50R17 656.8mm
  22. Carlston started following Advise on wheels
  23. I don’t want to invest the time right now to spend hours searching for and comparing documentsβ€”not when the vehicle isn’t right in front of me, or at least virtually connected to my laptop. For AFS to work, the assistant must be enabled in the MIB under "Vehicle Setup > Lighting," and the light switch must be set to "Auto."
  24. ☹️ Hi. My 1.5 dsg is prone to wheel spin when trying to accelerate a LITTLE briskly at low speeds. Eg when joining a roundabout from stationary or pulling out from a junction. Never encountered this in over 40 years’ driving. Skid control doesn’t even engage. Any thoughts. Still under warranty Cheers
  25. Dixy1266 started following Pluscenter radio
  26. Hello I have purchased a plus centre radio center and I have got to fit it, I’ve disconnected the old screen and found it has a multimedia unit behind. Is there any tips on how to remove the plug so I can plug in the new screen. Thanks
  27. Dixy1266 joined the community
  28. Bob hasn't visited the site since June 2020 so it's unlikely he'll reply.
  29. Get hold of a VAS 6154 and I’ll help you remotely.
  30. To tag a user out the @ filled by their name. E.g @Cairus
  31. Hello Guys, @Cairus could you take a look at my data??? I am loosing my hope... Today my 4b and 09 controlers were updated via ODIS to the latest version of software and still nothing..... One interesting situation: at LONG CODING "DYNAMIC AFS LIGHTS" are ENABLED, at LIVE DATA :DYNAMIS AFS LIGHTS" are OFF As i mentioned, i am loosing my hope....
  32. Thankfully the instruction manual that came with it is more detailed than the one I was sent a few months ago. I was just after some clarification regarding the spacers, but I think my questions have been answered by the manual. I’ll drop you a message if I get stuck - thank you! Should go well with my black spoiler.
  33. Yes. 5x112 standard was adopted in the early 00s
  34. OccyVRS started following Advise on wheels
  35. JoxSkoda joined the community
  36. Mine focused primarily on fixing things that were broken or worn due to age and mileage. And then from reading forum posts migrated into what was available cheap from AliExpress. And then morphed into more major projects. All doable in a weekend. Nothing too long term as it is my daily. Certain persons are bad influence on my impulsive nature…. @JR RS @Cairus @Kosin πŸ‘€
