Everything posted by ords
OEM SATNAV
What system do you have at the moment?
Electric Window Switch On Driver's side Faulty
Switches are for sale on eBay
Does the window work with the key fob using convenience mode?
Temp Gauge of Terror!
What about the tensioner, re-use or replace?
Many threads on this subject. Sounds like the water pump.
Rear Lamp light questions.
I don't think so. Matrix headlights were first introduced on the Superb in 2019/20. I think you will just have HBA which automatically dips the headlights instead of you doing it manually.
Headlight alignment
Change the setting and see what the difference is.
2.0d rattle after alternator replaced
https://www.youtube.com/watch?v=lza04G53Evc https://www.youtube.com/watch?v=EcS3qqJ_wCY
Wiper problems
The wiper fuse is inside the car behind the glovebox, not in the engine bay. https://fuse-box.info/skoda/skoda-octavia-mk3-5e-2013-2016-fuse-box-diagram
Bosch Battery life - 5 years?
According to the manufacuring code, my Varta battery is 10 years old next month. Hasn't given a hint of trouble. It's regularly had long periods of discharge (2/3 months) and never failed to start the car. Stop/start has never been a problem. It's just pure luck with batteries.
Why don't you turn the box off until you next need to use the car (at least 24 hrs) and see if that makes any difference?
Skoda Octavia 2014 5E
What engine do you have?
SKODA OCTAVIA VRS CHALLENGE TSI - Snow driving advice please
I guess you are a new and inexperienced driver to be asking such questions . You're just now thinking about winter tyres for the future when winter is already here, but you want to keep them in your husbands "man cave"? I assume you mean to keep them there during the summer months?
Strange smell and noise from 1.5 TSI
Get it looked at under warranty
Alternator
Are you experiencing starting problems, warning lights etc? What made you check for voltages?
Octavia mk3 Cabin air is not flowing toward feet
Try this first.
Water leak
Start searching the many threads on this subject
Need help understanding if the engine noise is okay on a car with 27k miles
Maybe someone with the same engine could put up a video for comparison?
Great difficulty to do a simple job of checking a fuse.
It's only because of the right hand drive conversion that it's behind the glovebox.
There are also youtube videos
The rear 12v socket is on the same circuit. Check that has power or not.
Škoda Octavia MK III TDI - Overheating after coolant flush
Look inside and see if you can see the silicate bag.
Rear window heating
Mine stays on constantly when in use. Doesn't seem normal. Why would you want a distracting flashing light?
DPFs for Dummies
You're right, I've never had that happen.
Coil Light Flashing… possible causes?
How many miles?
