Dashcam - cigarette socket wiring
Not by coding... You'll need to rewire it to an ignition switched supply You might be better buying a dashcam hardwire kit and using an appropriate fuse rather than messing with the 12v socket.
How to find the odometer reading on 2018 (68plate) Skoda Octavia Hatchback
It's on the instrument cluster. You might need to turn off cruise control on the indicator stalk to show the odometer 😉
LED Indicator on left headlight is lit all the time
Yup, you've blown a channel in the BCM which is likely due to your xenon kit. You either need to replace the BCM or find someone who can repair it
Low coolant warning
My CR140 never needed topping up with coolant in 150k miles. In that time it had a water pump and thermostat done so it would have been refilled twice by a dealer but never by me. Why do you think use coolant during a regen? Sure, the exhaust gases may cause the EGR cooler to get hotter but that shouldn't cause any coolant use.
Change the default Maxidot layout?
That's not a maxidot, it's a virtual cluster or virtual cockpit 🙂 If you turn off personalisation via the headunit, it should remember it, or at least my car does...
Steering wheel angle not zero when centered
If you take it lock to lock you should be able to figure out if it's correctly splined or not
Sasha’s Dads Octavia 2 Workhorse
Nice work, don't suppose you want a pair of xenon headlights for it
Messed up coding on headlights
That looks better, I've had a look through the adpmaps I've taken from other cars and haven't got a match. I'll if I can do anything with it tomorrow. Can I suggest you also flag the 20.12 issue with rosstech? They seem to have a few issues with their latest release looking at some of the threads.
Bizarrely, most of those seem to be empty? They have the header and footer but no data between :/ Not really sure what's going on... ;SW:5Q0-937-084-S HW:5Q0-937-084-S --- Cent. Elect. ;Component:BCM MQBAB M H14 0112, Coding:0F001842424700DB07A04082B10407280000000000000000000000000000 ;EV_BCMCOTNI,011001, ;Thursday,03,December,2020,18:42:47:39744 ;VCDS Version: Release 20.12.0 (x64) Data version: 20201124 DS322.0 ;VCID: 48988362F328BBC48B-801C Elapsed Time: 00:00
Updating Infotainment - a few Qs
The link from Pab is the headunit software including the inbuilt bluetooth and smartlink etc. It does not include maps or radio logos. If there are stability issues or phone incompatibly, performing this update might help but there is no guarantee as it'll depend what the update is designed to fix. These updates are only suppose to be done by dealers as they have access to the files. However, as you've seen, some updates have been leaked and are now freely available. Obviously there is some risk involved with a software update so if you're not comfortable, you might get a friendly dealer to do it for you. These updates are very infrequent so 0253 might be the last update for your headunit. I'm pretty sure they can be performed with any SD card. The maps and radio logos are a separate update. These come out more frequently and are designed to be updated by the cars owner which is why you're able to download them directly from the VW and Skoda portals. As you have an Amundsen, you will need to use a Skoda SD card for the maps. The radio logos can go on any SD card.
It looks like that file has been modified, have you got the unedited version?
Pretty sure that's an Amundsen, I think the latest software for that version is 0253. Not sure what changes there are or if it'll help your issues. Amundsen maps need to be on an original Skoda SD card, despite the Skoda site claiming a 32GB card is required for the Europe wide maps, they will still fit on a 16GB card If you add the picture to this thread, I'm sure Pab will provide a software update if available:
Feel free to post an adaption map from your car and I'm sure someone will take a look
Superb 2 - yaw sensor
Welcome! The position will depend on which ABS pump you have, Some have the sensor pack built in and others have a separate unit. If it is a separate unit, this post might help as it's likely to be in the same position:
The updates via the Skoda website are just maps and radio logos. It won't update the actual software running on the headunit. You can use any of the maps, it depends how much coverage you want and which countries you care about Feel free to post a picture of your headunit, that'll help people identify it and give better advice...
Service intervals.....
Welcome! You might want to add which engine you have
Move settings and functions from main screen to Maxidot
I don't think you can move any settings from the headunit to the maxidot. Is this something you've seen elsewhere or something you're hoping is possible?
Android Auto not working with new phone (Android 11)
It could be phone related? My pixel 2 is running Android 11 and has no issues with AA on the Amundsen in my '18 plate vRS. There might be a software update. Pab is super helpful if you post a picture of the current software version to this thread:
Kodiaq rear fog light replacement
All I can suggest is taking the rear clusters out and having a look to see if there is an obvious fog light bulb. Instructions are in the owners manual on page 308: https://ws.skoda-auto.com/OwnersManualService/Data/en/Kodiaq_NS/11-2017/Manual/Kodiaq/A_SUV_Kodiaq_OwnersManual.pdf If it is a bulb, it would be good to confirm it as other people may find it helpful if there isn't a bulb, then it may be an LED on the inner section but I'm not sure how you'd remove that. Maybe another Kodiaq owner can help.
Just to confirm: - it's a RHD/UK Kodiaq - there are no working rear fog lights - there is a warning on the dash saying it's faulty The owners manuals I've skimmed over only mention replacing the rear indicator bulbs. I've not seen any reference to a replaceable halogen rear fog light I'm afraid
I'm pretty sure the rear fog light is LED on a Kodiaq so if it's gone, you'll need a new cluster as it's not a replaceable bulb. Which side has gone? I ask as you only have one rear fog light which is on the drivers side so it's normal not to have one on the passenger side
Overheating problem
Could be the waterpump, it's a common issue on the earlier TDi's:
Octavia TSI DSG (66 plate) Battery Problem
If you have a multimeter, you can measure the standby current of the dashcam to get an idea of how much juice it uses. A quick google suggests that at least some dashcams consume almost as much power in parking mode as they do in normal recording mode! There is a document about finding parasitic current draw, that suggested that a non-modified car should be under 40mA after it's been locked and undisturbed for 2 hours. It's a few years old but that would work out as a maximum of around 0.5W. Looking around, dashcams in parking mode can use anything between 1 and 4W which is why dashcam users often have a fault code about quiescent current being too high. It might be worth investing in a battery saver or separate battery for the dashcam to avoid these problems
Paint code
Take a picture of the sticker and post it here
Dsg Basic Settings and adaptation with OBD Eleven
Based on this thread, OBDeleven might not be suitable for DSG adaptions as a MK5 Golf should be similar to a '09 Superb: https://forum.obdeleven.com/thread/1127/dsg-adaptation-re-calibration-capability Things may have changed but it's worth asking on the OBDeleven forums as they should know what the tool can or cannot do
