Heater blower stopped. Code 9485831.
If the car doesn't have stop/start, then no coding is needed or indeed possible when replacing the battery
Electric folding wing mirrors retrofit (now with puddle lights when folded)
At a guess, dinamo1990 has replaced the electronic control module but not the motor. That's based on various eBay items where: - 1T0 959 701 T motors are attached to 5K0 959 793 modules - 1T0 959 701 AA motors are attached to 5K0 959 793 A modules From the picture, you can see Dinamo1990's motor is attached to a 5K0 959 793 A module
xenons
The projector bowl is slightly different between halogen and xenon based headlights. Due to the extra light produced by the xenon and the slightly different characteristics, the design is tweaked to make the best use of the extra light. I think it typically creates a slightly wider beam iirc There is potential for drop-in HID kits to cause glare to oncoming drivers, especially with dirty headlights, during acceleration, on bumpy roads or with a loaded backend (and you've not adjusted the headlights down...).
FL Led headlight condensation
You can download it and all other TPI's against your VIN directly from Skoda for a small fee: https://erwin.skoda-auto.cz/erwin/showHome.do Attached a copy that I have but it may get removed:
I certainly agree that misting is normal and should clear out naturally. However, there shouldn't be enough moisture to cause droplets... Based on the image from tdavison, the dealer should follow the TPI and perform a physical inspection to determine the cause of the water ingress. Few snippets from the TPI: The problem is if a dealer replaces the headlamps but Skoda disagree there is a problem, the dealer won't get any money to cover the work/parts: So it's easier for the dealer to say it's 'normal' even when there is a likely issue
If those droplets are in the inside, then I'd consider it excessive. There is a Skoda tpi regarding this, bit more info and pics in this thread:
Wooden Dash insert required (3T1858418B 3T1858418C 5481579)
At a guess, it'll start 3T2 for the RHD version Not sure where will be best to buy them though I'm afraid. Maybe a breaker on eBay selling a similar car?
Fuel sender resistance readings, guage faulty
That video seems to tally in to the rosstech comment, that channel is to adjust the fuel reserve level. Rather than calibrate the sensor through the full range.
For a 2012 Superb, you'll need a genuine VCDS micro-CAN, HEX-USB+CAN, HEX-V2 or HEX-NET interface. The cheapest currently available would be a 3-VIN HEX-V2 at ~£225. That being said, it'll help with diagnostics and fault reading but despite J.R.'s comment, I don't think it can 'calibrate' the fuel gauge... Having looked a scan for a similar vehicle, there is an adaption channel named 'Display correction of fuel gauge' but that doesn't seem to do what you'd need: https://forums.ross-tech.com/index.php?threads/28648/#post-242725 VAG seemingly haven't implemented that functionality as the fuel senders should all be close enough as not to need it. A quick google suggests that: - 50 ohms is full - 160 ohms is half full - 350 ohms is empty/reserve No idea if that's correct for a Superb but it's the only obvious info I could find
Cost of Factory Options
I've attached a Nov 2017 brochure with a Jan 2018 pricelist: octavia.pdf Based on that, I'd guess at: ex-VAT inc-VAT [K1K1] Velvet red metallic £604.17 £725.00 [RA3] CANTON sound system £420.83 £505.00 [KA2] Rear-view parking camera £316.67 £380.00 [PJC] Temporary space saver spare wheel £87.50 £105.00 [7X2] Front and rear parking sensors £295.83 £355.00 [WUB] Black design package plus £612.50 £735.00 However, if your car was a 245 'edition' the standard spec included parking sensors and black design package plus along with heated seats, folding wing mirrors etc...
Can you visibly spot the VAQ diff with car on the ground?
I think all 245's had the VAQ fitted as standard? Still, a dealer should be able to pull up the original build spec, I believe PR-1Y2 is the VAQ diff If not, try using OBDeleven or VCDS, if you can access module 32 - Differential Locks, then it certainly has a VAQ fitted
Stereo Surround replacement
That's an aftermarket item but if the AC cutouts and colour matches your existing trim, then excellent There are a few versions here: https://www.cars-equipment.com/en/shop/plastic-trims-52/ edit: There is also what looks like a bolero size to double din adapter: https://www.cars-equipment.com/en/shop/plastic-trims-52/plastic-trim-for-2din-radio-skoda-2/
Might be worth adding a picture of your old surround along with the full part number including colour code (stamped on the rear). Should be relatively easy to figure out from that.
Gearbox flash tool by DtuK
It's still a gearbox remap so should effect your warranty much like any other gearbox remap. The only difference is you effectively flash it yourself using their tool rather than having someone else do it... No idea if it's any better/worse than other companies...
Hi guys.....................here's johnny......lol
Should be able to. At a guess it'll be: - 4 new sensors + paint - replacement parking sensor module - a front buzzer - extra button to turn the sensors on/off - wiring to connect it all up - coding the car
PTC retrofit - "dumb" version
It's very unlikely the wires will be present, you'll need to add them
Fog light issue
Nice, that should sort it for the mot! I'm out in Swaffham so if you want to take a closer look at the coding etc in the New Year, we can sort something out. Just drop me a PM 👍
Fog light issue
Based on that, it does feel like the car coding has been messed with for some reason but the wiring is fine. Depending where you are in Suffolk, if you fancy a trip to Norfolk I can take at the cars coding and lighting configuration for you. If you want to fix this with wires, don't connect both sides together, instead, run a wire each way to swap them over. A better plan might be changing the two pins at the BCM, T52aa/6 and T52ac/47, not sure if there is enough slack to make that super easy or not.
Should be possible assuming your ECU can drive the relays for it
How to update system version?
Not given that amount of info... Based on your other posts, you probably have a MIB2 Amundsen...? In which case, try this:
Fog light issue
Completely depends how good the dealer or independent is and what the problem is! First thing to check is how the tail/fog lamps are connected. At least on my old 2012 hatch it had a P21/4W bulb with the 4W filament disconnected, it would always use the 21W filament but dim it using PWM for tail light use. You can easily check by: - counting the wires to the tail lamp, 5 wires suggests your car does the same, 6 wires suggests a separate tail light feed - looking at the working side, does it use the same filament for both tail and fog This will hopefully help narrow it down between wiring and coding Coding gets a bit more interesting, quick bit of background, the BCM (body control module) is responsible for the external lighting on this age of Octavia. As the same module can be fitted to various VAG cars, the lighting configuration is adjustable to support the different lighting options used, it's mostly controlled by byte 18 in the BCM coding. The problem with the Octavia is that none of the byte 18 values match it's lighting so it's normally set to 00 which a 'custom' configuration applied using dealers tools such as ODIS. This means that most independents won't have the tools or knowledge to correct issues in the light config. A dealer 'should' be able to reset the config using ODIS but again, training can be patchy so you'd need to find a dealer with at least some clue.
Fog light issue
From factory, only the drivers side rear fog light should work. It feels like someone may have messed about with the cars coding or something to get this behaviour... - Any history or previous work done to the car? - Have you had it long? - Have you got any error lights/bulb out warnings etc?
conversion from xenon to led
The 'bluer' the light typically means the useful light output decreases. I wouldn't bother with the CBB, the CBI is probably better but I used Night Breaker Unlimited and was very happy with them.
Aren't the Osram kits only designed to replace halogen H7 bulbs? So won't fit or help the OP with xenon (D3s?) bulbs...
Yes, having the wrong light source in your headlight should fail the UK MOT as "4.1.4c light source and lamp not compatible". The guidance is aimed towards the more common HID/LED in a halogen headlamps but should apply equally to LED in HID headlamps as the headlamps will only be type approved for HID light sources Not that it relevant to the OP as they are in Spain...
