Broken Door Mirror Indicator Telltail...
At a guess, it's 3V0949101 and 3V0949102 depending on side. They look to be the LED indicator for a MK3 Superb but as always, I'd suggest double checking....
How to read speed in kph
Or maybe they just plan to drive in Europe at some point?
What's this??
Are you sure it's an electrical connection? To me it looks like cooling fins for something, especially with what appears to be vertical slots cut into them. It is was electrical, pins that wide seem like they could take a lot of current :/
TPMS Reset button wiring
Looks like a 12v pulse when you press the button, at least based on the diagram here: Their wiring seems to match the switch you got too
- Swing RCD310 to RCD330 | Android auto + Apple car play
That seems about right. It's pin 7 for the TPMS button with a MK70m rather than pin 35 as it only has 26 pins on the connector @Leo52 - how are you getting on with the TPMS button you're fitting at the moment?
VCDS options on Superb III
I think adding modes is hard as you'll need the correct FeC to enable it
Jack and tool storage
I think the foam part numbers are: 3V0012115B 16" tool kit bag D >> - 25.05.2015 3V0012115C 18" tool kit bag D >> - 06.04.2015 3V0012115D 16" tool kit bag D - 25.05.2015>> 3V0012115E 18" tool kit bag D - 06.04.2015>> Just as a random example: https://www.ebay.co.uk/itm/143930010601
Few other profiles, not all will be applicable to your car: 0 - Doors open (coming/leaving home) 1 - Comfort 2 - Normal 3 - Sport 4 - Off-road (?) 5 - Eco 6 - Race/Cupra (?) 7 - Individual 10 - Snow (?) 11 - Individual off-road (?) Question marks on modes I haven't got so I can't confirm
subwoofer & SKODA surround for Kodiaq Style 2018
Post your autoscan and adaption maps. Tweaks will depend on which modules you've got so it's hard to give advice without knowing what's fitted
That'll probably be your problem. You have an external amplifier and this tweak is only suitable for the internal amp. When you change from Sound_system_ External_ Most to Sound_system_INDIVIDUAL, you'll be turning off the optical feed to the amp which is why you have no sound Change it back to Sound_system_ External_ Most, clear any error codes and you should be fine again.
Virtual Cockpit retrofit
What are the problems you're having? Might be adding your latest autoscan + adpmaps so others can check for anything obvious
2010 Toyota Land cruiser Prado Speed warning alarm
Welcome. I fear you may have joined the wrong forum. Most of our knowledge is around Skoda's and other VAG group cars rather than Toyota's. You may have better luck on a Toyota forum Maybe start by checking the owners manual: https://www.toyota.com/owners/resources/warranty-owners-manuals/land-cruiser/2010
Sure, can you post an autoscan from before and after your changes? Might also help if you say what you did
Superb mk2 multimedia upgrade
The MK3 radios won't fit or work in a MK2. The best OEM radio would be from a FL Yeti, there is a long thread here: https://www.briskoda.net/forums/topic/409691-amundsen-mib-std2-infotainment-system-with-android-in-superb-ii/ In short, if you want a MIB2 style (as per the linked thread) you should contact @pab567 as he can supply and help with any extra bits you need. There are plenty of aftermarket options too, depends what you want and your budget
Best climate control setting for driving through a Coronavirus hotspot?
Recirculation will obviously help as it shouldn't pull any air (or viruses) from outside. However, the car will only run like this for an amount of time before drawing fresh air in to keep you alive. In the real world, you're very unlikely to catch the virus outside, even less so with the short contact times you're looking at during a typical drive. Especially as your profile pic suggests you've been vaccinated. At least assuming you don't have an 'infected' climb on your bonnet and start coughing towards the cabin air inlet If you're truly worried, take a different route or don't make the journey...
Rear window dash cam cable routing concern
That's horrible! That looks like water ingress or a broken cable just waiting to happen.... I would have run the cable inside the rubber gator and had it appear from behind the boot lid trim. Obviously this means the 'fitter' would need to remove the boot lid trim for access and taken more time which is probably why they didn't!
2018 superb sportline
If your Karoq has no TPMS system, you can probably enable the indirect system by coding as it's part of the ABS module. If you have indirect TPMS and want the pressures to be shown, you'll need to add tyre pressure sensors and the TPMS module. It's not something the factory would fit but leave disabled Not sure if SFD comes into play on a MY21 Karoq as that's going to spoil everyones fun. Some modules may need a code from VAG before they'll accept changes which is going to suck for coding/retrofit.
Cruise control code
If nothing has been changed or replaced, the module shouldn't need recoding... I don't think it's possible to 'reset' the CC either. If there are fault codes, they can be cleared but if they come back then you'll need to find out why. Still, if you really want to try changing the coding, I'd probably try (at your own risk): - byte 00: 14 (currently 6E) - byte 01: 10 (no change) No idea what different that will make or if it's actually correct for your car. If you get odd behaviour set it back to 6E and get the car on VCDS to get a better idea what's happening and what modules are installed.
google maps keeps dropping out
It's more likely to be a failing cable or bad update from Samsung or Google. If you haven't already, I'd suggest replacing the cable as that's a cheap and easy thing to try. Might also be worth posting a picture of the SW version for your radio too. It should be under settings, system information or something like that. For example:
Cruise control code
I think we're gonna need a little more info... There isn't a one code fits all cars I'm afraid. Lets start with: - What happened to the car - Has something been changed/replaced - If so, what are the old/new part numbers - Were you able to read the old coding out - Do you have a MFSW - Manual or DSG gearbox
Front light adjusted for driving on the right hand side - PLEASE help!!
At least in my experience, the following is true for VAG cars. - If the car has halogen headlights, there is sometimes a lever that will convert from the ECE cutoff with a flick up to a completely flat cutoff. - If the car has LED/Xenon headlights, they normally drop slightly and move over. The cutoff doesn't change. I'm not familiar with the Kodiaq but I imagine you fall into the second category and I'd be very surprised if it could change from RHD ECE to LHD ECE cutoff patterns... I think you're gonna need new headlights I'm afraid :(
2014 VRS Infotainment Swap
It just needs unclipping, it should slide out to the rear with little effort. I've circled the clip here, again a small flat blade to move the clip down works well:
OEM ambient lighting retrofit
I'll let you know... I've got the OEM parts to do this sat on the shelf. From what I understand: - run a LIN-bus wire to each footwell light - replace the connectors for each footwell light (2 pin to 4 pin) - move the footwell power source to a suitable live (ideally the fuse for the other ambient lights) - connect the new LIN-bus wire to the same pin as the ambient light LIN-bus - fit new footwell lights - some recoding The only tedious bit is running the new wire as I expect I'll be taking the seats out to make it easier. Not sure if @SashaGrace used OEM or aftermarket parts
Got an image of your connector? I assume it's this connecter and style: You need to 'unlock' it first. There are two flaps that release, one on each side. I've marked one side up in red and I tend to unlock it using a tiny flatblade and sticking it in around the orange arrow. The pin should slide in with very little effort and 'click' into place Once it's unlocked you should be able to clear our any broken bits too.
