Warrior193
  1. Hello Henry, you say oil pressure is 100 bar - are you sure about that? - that equals more than 1400 psi!
  2. Hello Henry, welcome to the forum. Have you checked the oil level on the dip stick - if so, is the level correct? Do not drive it until you check this.
  3. In my opinion, I would consider replacement of the Turbo might not be necessary - the presence of oil in it just shows how the excess oil has been 'blown' out of the engine - unfortunately, I can't say the same for other engine components (pistons, connecting rods and crankshaft) These are all major parts - and there is a possibility of damage to them by the pistons contacting the excess oil. - plus the catalytic converter will probably need replacement after being contaminated.
  4. Welcome to the forum. You have not made it clear if you added 5L of oil to the engine while it already had oil in it - or were you in the process of refilling with oil after draining old oil (oil change) ?
  5. This may not remain the case - it seems that fully fly by wire systems are in development - with no mechanical connection to steering or brakes. Apparently in a move to fully autonomous driving capability.
  6. Agree that prime suspect will be the change immediately before the problem appeared.
  7. That looks identical to my Amundsen MIB2.
  8. Is it trying to do a DPF regen - does 2007 TDI have DPF?
  9. As @jeallen01 suggests, the noise could be only while the wiper motor is loaded - try putting gentle hand resistance on the wiper arm while it is operating away from the glass. If no unusual noise while doing this, I would suggest using a pot scouring pad (not brillo!) - the type with sponge on one side, and a very gentle abrasive pad on the other - start with dish washing liquid and work up to meths, or alcohol. Good luck.
  10. I've used winters with approx. 4.8% gearing increase over standard - they were fine, gear ratio-wise, and the speedo reads damn near exact according to GPS.
  11. I'm wondering if item 8Q5 'headlight range control' is the reason why HB assist is unavailable to adapt - perhaps someone with LED headlights fitted can advise?
  12. @ddan1275 typing in capitals is considered to be shouting.
  13. Are you able to post an image of a headlight bulb, taken through the glass - so that the bulb envelope itself is visible?
  14. I have seen from other posters (although never experienced it myself) that some screen contaminants are extremely difficult to remove - even sometimes requiring a (very) mild abrasive product. Use extreme caution if considering this. Personally, I would only recommend some type of solvent like (in ascending order) white spirits, thinners or acetone - but keep all of these well away from paint!
  15. @smelly -no, I mean do you have halogen, led/matrix or HID headlights?
  16. Have you tried lifting the blade off the rear window (so that it's in the change/wash position) and operating the wiper - is it still noisy then?
  17. Faith and Begorrah, it's a miracle - the noise is gone!
  18. Whatever you do, don't accept their 1st settlement offer if you consider it too low given the vehicles condition and mileage immediately before the incident. Unfortunately, you may have to spend more time providing comparative prices for similar vehicle.
  19. Hello Adam, normally, random faults after a battery replacement clear themselves - I suggest getting a diagnostic plugged in to check for any fault codes, then clear them.
  20. Hello Sam, the engine cylinders are numbered with cylinder 1 nearest the cambelt (or chain) On Skoda's, this is normally the left end of engine when standing in front of car.
  21. Is the higher, second reading with the engine running?
  22. That's interesting - does the off-side door have one too?
  23. That sounds very likely - was the brake servo working correctly before the job? Late now, and an early start in the morning - but I will take a look at my 1.4 booster setup tomorrow. If a vacuum line is off, engine should run like cr*p too.
