Kamiq Door Handle - Not sure if damage
I'd take a guess that's paint transfer, try a gentle rub with car wash and cleaning pad - or a very gentle wipe with T-cut.
Coolant Reservoir 'Mit Silikat'
If the EV pictured is the one off your vehicle, it was originally fitted with the Silicate 'teabag' - it is possible that it was previously removed if you aren't original owner. I have not seen any other 'mit silicate' tag apart from the one shown on the EV. If that is your EV, strongly recommend replacement.
Fabia VRS. Causes of rear inner tyre wear?
Are you sure there's no toe adjustment? What type or rear suspension does the Mk1 vRS have - IRS or torsion bar? If there's truly no adjustment possible, excess inner tread wear could indicate running too low tyre pressure for load (although wear would normally be on inner and outer) - or something's bent.
OBD Reader questions?
I'm struggling to see any connection between an indicated under boost issue and faulty glowplugs! What was the DTC that was read?
- Sat nav giving incorect info
Clutch pedal not returning when pressed.
Pedal feel and response improving when it is pumped would strongly suggest air in hydraulic system to me. Does the fluid level in the master cylinder look as if it has dropped since the repair?
Rear window spoiler loose on Skoda Superb Estate Mk3
Does an aftermarket add-on spoiler like that not mask the high-level brake light?
Parking sensor problems (2019 Octavia)
While not perfect, testing the voltage at the battery terminals while cranking the engine on the starter motor is a reasonable test of battery health. A high-rate discharge is still the best test, but a dedicated battery tester is a relatively inexpensive and extremely useful tool to have.
Another Tesla Class Action Law Suit - Odometer Fraud
Fiddling the Odo reading on a trip could affect the range per charge by stating that the vehicle has travelled 76 miles per trip, when it was actually only travelling 25 miles. The inflated cumulative distance would make it appear the vehicle was achieving a much greater distance between charges.
Lawsuit filed on Feb. 7 in California, reported on Newswire, published 9/4/25 - action involves a 2020 model Y.
Apart from the warranty aspect, that would also indicate an inflated range per charge.
- Superb Sat Nav Problem
Mannoll 508/509
AFAICS, there is no detriment to using long life oil on annual oil servicing plan - apart from (possibly) slightly increased cost of the product - long life oil will possibly be blended to a higher standard / or contains improved additives to allow for the longer service periods. Provided the oil complies with the required standard, it will be suitable.
Intermittent Engine light and sporadic misfire code
Hello, welcome to the forum. Is a misfire code being logged on the ECU? Has replacing the plugs or coil packs been tried? Unless they were tested under load on a dyno, it would be unlikely to be able to produce the same conditions that trigger the misfire.
Timing belt tools
If it is not actually necessary to disturb or remove the cam sprockets, holding tools are possibly not required so long as the camshafts stay locked in position - but this is a job I would rather pay a tech for. I'll flag this to @ApertureS for advice for you.
Timing belt tools
Hello, welcome to the forum. From some of the cautionary tales I've seen on here after the camshafts have been allowed to move, even only very slightly, because the cams were not completely locked in position, I'd strongly suggest investing in the correct tools for the job. I've even seen instances where supposed professionals have got it wrong.
Mk4 Vrs Seat Covers
So likely just high wear on the front seats then.
Mk4 Vrs Seat Covers
A quick question - do the rubber pads on the pedals also appear more worn than you would expect - or even brand new?
New icon after installing tow bar at factory. What does it do?
How wide is the base (furthest from tow ball) of the triangle? - purely a guess, but I'd suggest it is a guide for trailer, when reversing, to prevent jack-knifing.
Mannoll 508/509
... and slightly lower emissions.
Mannoll 508/509
I've just used Mannol 5W-30 for my recent oil service - it was still certified as VW504-507.
2011 VRS, no power. very slow
@Cubbs Did you get a resolution to your problem?
Photography Thread
My moneys on Duck 2 being a mallard.
Coolant issue
Note, it is possible that when the coolant level falls to a point where the expansion bottle is completely empty, air pockets can become trapped in the coolant passages of the engine - if this is the case, it may take some time for the trapped air to be purged from the system, the coolant level will drop as this air gets purged, mimicking a leak.
Coolant issue
It should not use (lose) coolant at all - as I suggested earlier, monitor the coolant level regularly from now on to check if it is losing it. Take it back to garage if it is.
